Charge conserving Capacitive Spring.
  • #76
    I found a link for home-made super caps which caught my eye.
    If we rotate the plates the capacitance will jump from a very small value to a f***ing huge one (The author claims 25F. Even 1 Farad would be awesome but 25!) While mechanical it still could yeild very large changes in capacitance very quickly (well depending on the RPM of your motor). Anyone else's comments would be very much appreciated as part of me still feels like I can't believe what I am seeing.
    • #77
      Originally posted by Armagdn03 View Post
      This is an excellent question to brainstorm! I really think the hidink method is great, but requires very high voltage.
      Ideas???
      Ill get the ball rolling,
      Think electrostatic speaker used in reverse. acoustically drive the capacitor, rather than using the capacitor to create an acoustic signal. Flexible membranes at the end of a tube driven at resonance.
      I had never heard of an electrostatic speaker until you mentioned it in this post. Its physics of operation sure makes you wonder how mainstream science pushed the dielectric field into obscurity.
      Does anybody have an electrostatic speaker that would be willing to do some compression tests on to figure out the the general range of capacity?
      Can you describe in a bit more detail the youtube video that you posted: YouTube - ‪Armagdn0303's Channel‬‏
      There may be a page somewhere describing this, but I just don't see it. How is that capacitor tube hooked up to those meters? Where are you feeding your voltage to? What materials are you using?
      • #78
        Re:Home made supercaps - UltraCapacitors.org*-*Ultra Capacitor - Super Capacitors - Super Battery?
        I'm confused where you saw this? I read the whole thread and didn't see anything about rotating the plates. But as far as doing that, in my opinion there would be a variance in capacitance because of vortex/centrifugal/centripetal forces on the electrolyte, and with charged particles/ions rotating there are magnetic fields set up adding completely new parameters to the system.
        • #79
          Unless I'm confused the capacitance comes from the black material. So simply rotating the plates like a variable cap will produce a variable super cap. I may have missed the mark but that was my analyiss on how it worked.
          Raui
          • #80
            The construction of the tubes in that video are very simple.
            Take the tube, paint with adhesive. Place two sections of tin foil covering each half of the tube so that they are electrically separate (the black tape shows spearation). And now you are done!
            The capacity meter is connected to the two foil sections. When the plasma is active it acts as a parallel plate capacitor, when not active, it shows the the free space capacity of the plates.
            The volt meter is connected across the tube to show the various breakdown voltages.
            It took me 30 minutes to make about 8 tubes.
            • #81
              Andrew,
              I just got a new job traveling the country working on automated packaging equipment so I've been slow to get to replicating one of your solid state switching tubes. I just finished replicating a tube and got some different results.
              When you reached your breakdown voltage of 175, did you measure the current into the fluorescent tube?
              My tube breakdown voltage happens when my 4 uF cap charges up to about 500V. Once the gas is sufficiently conducting, the voltage drops to about 50 volts and draws about 150 mA for a power equaling 7.5 watts. Unless I can find a way to vastly increase capacitance variation, I don't know if this tube can be considered practical for our purposes.
              I used approximately the same size tube and sections of foil.
              My capacitance is right on the mark with yours as far as variation goes, but I'm curious how you got light from that tube at 175 volts. What brand tube did you use?
              Did your power consumption vs. capacity variation seem practical?
              I would test this myself but am not sure I have the same type of tube as you. Does paralleling multiple tubes cause an x-fold(2x,3x,4x,etc) increase in current?
              • #82
                Andrew,
                fantastic questions.
                Really all that remains here is an engineering work-through.
                When the tubes activate their plasma, the region between the electrodes becomes immediately conductive. This causes your capacitor to dump its load to a point where the plasma is no longer able to sustain. However, it is not necessary to discharge all that built up charge. Really we just want to oscillate our voltage around the region of most change in capacitance per volt. Note where the largest change occurs, then build a circuit which oscillates around this voltage.
                For example, imagine a 1 uf cap charged to 175 volts (breakdown or plasma) when the threshold is reached, it discharges all 1 uf worth of charge.
                You could reach the same 175v much quicker using a 1mf cap. The discharge would be much much quicker, less charge expended per unit time, and so frequency would rise also. You get more oscillation around the region wanted, for less charge per unit time expenditure.
                think about all the variables and what changing each does. Think about how little energy is expended using a one way tank circuit like shown in Imhoteps radiant oscillator thread to light CFL's. Just re design so that you are not going for max lumens, rather max capacity change.
                • #83
                  Check out patent US Patent 4127804
                  This patent belongs to the feds.
                  Electrostatic energy conversion system
                  This is the exact same mechanism as Chris Carson's Device, a variable capacitance generator.
                  This patent was granted to Onezime Breaux based on "research" from John Trump from MIT.
                  From William Lyne-
                  So Trump was able to see all of Tesla's work after he died, work that is still classified to this very day above atomic bomb information.
                  Tesla as shown earlier also did work with electrostatic variable capacitance generators (circa 1890).
                  You have to conclude this device is Tesla's child, stolen from him by John Trump as he went over most of Tesla's papers.
                  • #84
                    • #85
                      I found a fairly lengthy report from John Trump about this technology. The first paragraph reads;
                      "This report describes an investigation of the electrical
                      engineering possibilities of machines depending on electrostatic
                      forces and principles and utilizing high vacuum as the essential
                      insulating medium. This combination of electrostatic devices and
                      vacuum insulation makes possible, it is believed, a new type of power
                      system - capable of all the functions of modern power systems, but
                      possessing unusual ultimate advantages in power capacity, overall
                      efficiency, distance of transmission, reliability, and economy
                      I recommend it and it is avaliable here; Vacuum Electrostatic Engineering - John G. Trump
                      Peace,
                      Raui
                      • #86
                        Great link Raui.
                        Here's a patent application that is once again the same mechanical variable capacitance generator. This one has actual data in it and claims 12 kW of power at 1600 Hz (see page 8). I'm sure it takes less than 12kW of power to rotate the rotors at 1600 Hz
                        United States Application US20090066298
                        ELECTROSTATIC GENERATOR/MOTOR
                        There is some very interesting data in this patent.
                        AGAIN, this patent belongs to the DOE. I wonder why the Feds find this technology so interesting. LOL!
                        • #87
                          Peace,
                          Raui
                          Really interesting document, I have read about the first 50 pages or so, and have had alot to think about. Let me read the rest and get back.
                          • #88
                            Originally posted by SilverToGold View Post
                            Great link Raui.
                            Keep up the good detective work, all good examples that can be suited to this purpose.
                            • #89
                              Whenever I conceive of a concept, I pay a mental game, and re evaluate the concept by imagining its inverse.
                              For example,
                              If we take a capacitor and separate its plates, we decrease its capacitance, but we DO NOT INCREASE its energy state.
                              If we take a CHARGED capacitor and separate its plates, we decrease its capacitance and INCREASE its energy state.
                              Similarly we can change the permeability of an inductors core, and we DO NOT change its energy state
                              But we can change the permeability of a CHARGED inductor core, and affect a change!
                              Let me elaborate on this concept.....
                              • #90
                                For example,
                                One can charge an inductor (with core) by running current through the windings which will be a dynamic process. Changing the core permeability during this dynamic process requires specific timing, too difficult.
                                We can create a static magnetic tension in the core using magnets.
                                In the image below, you can see the core charged with magnetic lines of flux,
                                Creating a change in the permeability of the core (reduction in this case) causes a change in the amount of flux the core can physically hold. I in the photo below, I have drastically reduced the permeability of the core. Notice that the flux lines no longer overtone to create a unified magnetic field, but rather circle around themselves to create two magnetic fields. The flux density of the core is drastically reduced.
                                By changing the permeability of the core, we have affected the coherent flux density within the core of our inductor.
                                Here is another photo to show this. In the first photo, 4 loops of magnetic flux are supported within the core.
                                Now we change the permeability of the core so that only two flux lines are supported. The remaining two circle around their respective magnets rather than over-toning.
                                Notice in the image above, I have included the windings of the inductor. When the permeability of its core changes, the coil sees a change in magnetic flux with respect to time...and EMF is induced.
                                Now think about this....The Lenz effect, is still present, but it is pushing against static magnets, the change in flux was not caused by the relative motion of conductors and lines of flux, rather through a change in flux density by altering the permeability of the core.
