Pyramid
  • blackchisel97
    I see.
    With that I think you shouldn't left the bottom square too and apply copper wall as well. The square should interact with the triangle.
    I wonder if it has to be solid wall, what if you use wire wrap? Tedious job surely....
    After winding transformers, Henderson's, Rodin's, Starship's and cones wrapping each side doesn't scare me However, I think it should be solid. Either copper sheet/foil or double sided pcb board. I found some 12"x9" copper sheets, 0.01"thick and reasonable priced but it will take some time until they arrive. I was looking around for some roofing copper but it is quite expensive and they don't stock that either. I think that pyramid has to be enclosed = all surfaces covered.
    Energy field can be felt as far as 12" outside from each wall. Around the center (apexes) is warm. Over the pyramid apex feels like a narrow cooler breeze/beam. Near each corner (inside) on the distance of 1/3 length from the base quite intense, almost piercing.
    Vtech
  • sucahyo
    Originally posted by blackchisel97 View Post
    My flood is just a minor inconvenience. Pump is taking care of the problem. It was coming in a rate of 1gal/min. Poorly made basement. Good thing we're only renting this house.
    I see.
    The way I suspect is that pyramid walls as triangles should interact with Aether causing to respond.
    With that I think you shouldn't left the bottom square too and apply copper wall aswell. The square should interact with the triangle.
  • blackchisel97
    Thank you.
    I wonder if filling the cone inside with a bunch of small coil or crystal fragment can make a difference.
    I now suspect that if there is hole in the cone apex, the apex will have more potential and the base has less. So I see your configuration as the cone suck energy to power the rodin coil.
    I hope your flood will pass soon.
    The way I suspect is that pyramid walls as triangles should interact with Aether causing to respond. Therefore, what may happen is vortical movement within each wall and concentrating at its peak. This energy should get "sucked" by the upper cone. There should be also another stream entering and traveling up the lower cone. Both should look like vortex. Their culmination point would be a gap between both apexes. What I hope to detect is a spherical energy field in this area. Now, if I can figure out how to interact with this sphere, possibly trough an oscillation. Possibly by energizing (ringing) cones with small vibration but through one of the power points; either apex, King Chamber or Lower (underground) Chamber. It has to be done with respect to the harmonics and resonance I don't have any suitable material (copper) to cover the walls atm
    Thank you
    Vtech
  • sucahyo
    Thank you.
    I wonder if filling the cone inside with a bunch of small coil or crystal frgament can make a difference.
  • blackchisel97
    Thanks for the update Vtech . Can you sense its energy? Judging from the arrangement, the meeting point is positive and outer is negative?
    Will there any change of energy if rodin coil or star coil is hanged on the pyramid? I can't get them to communicate this way
    The way I imagine will be that one apex will become a positive and other negative. When bases are connected there will be conical Aetheric field emanating from each apex. When apexes are connected there will be spherical Aether field in and around the gap between them. This is the one I'm after.
    Energy field is very weak in terms of measurable DC/AC etc. It is present and it can be felt. I need to cover frame with copper. In this stage I'll not see anything significant. I had to deal with basement flood for couple of days and couldn't get anything done except winding coils.
    I hope you guys are ok. I live on a small island but off the coast of Atlantic, not Pacific Ocean. We have 1 - 1.5m surge once in a while but that's nothing to compare to 7-10m wave. I have uneasy feeling about that trench.
    Vtech
  • sucahyo
    Everyone, all the mountain in Java island is already erupting, a very rare event, usually it is only one at a time, not all at once, indicating that there is big land movement happen. That prediction is not surprising for me, since it is already supported by the evidence so far. But we will see if it is correct.
    No one know how wide the area of the next sudden big land movement to happen, so any clue would be good. We use the clue to make sure of survival, not to terminate our life. We must verify the information, also on any succesive one even if the first one is true.
  • blackchisel97
    I made 2 cones, cw from their bases. That was quite fun to wind. Trying to figure out how to energize both. I tried feeding them from sin generator ( hot of gen to the top, apexes wires connected together and bottom to the ground of gen.) and connected one transistor oscillator ( John Bedini circuit) to one of my Rodin Coils placed in between (this is the suspected area of Aether concentration). I was able to get 3V oscillator LED very bright by connecting only one wire from the oscillator to the Rodin coil. Second end of toroid isn't connected to anything. Doesn't matter if I connect positive or negative of oscillator. Other short wire acts as an antenna only. I had to go quite high, over 600kHz to find this spot. Also, there is a mA meter in series with oscillator which isn't detecting any current.
    This isn't really related to the pyramid but I found amusing.
    I'll have to wait for copper sheets to cover it. There isn't enough energy from the frame shape only.
    http://i29.photobucket.com/albums/c2...l/IMG_0397.jpg
    http://i29.photobucket.com/albums/c2...l/IMG_0398.jpg
    I tried to move away to capture entire setup but oscillator is in the right lower corner and LED is fully lit.
    Vtech
  • robur
    @ Sucahyo and All:
    I think we should all prepare. I hope for your sake that he is very wrong, but I fear that he may know something that we don't. I am also near a big fault line, part of the Ring of Fire.
    I had thought that nothing happened in my area, but I was wrong. In the norther part of the Costa Rican coastline at about midnight last night, a unexpected wave hit 7 hours or so later than expected tsunami wave. The midnight wave reached the shoreline taking out a peer and some boats with it. The tide was very, very low at that time. The wave was supposed to impact at 4:40 pm (High Tide), but hit the norther part of the country at midnight. Other strange things happened also. Like the tides going up and down every 10 minutes or so for a while.
    Whether it is being caused by Solar Flares, Nibiru's approach, Haarp, or the over-amping of the whole univers, as we reach towards the predicted date in 2012, is a matter of discussion
    We are at the end of a 28000 year tectonic cycle activity.
  • robur
    @ Sucahyo and All:
    And moredoom and gloom theorys. These preachings always were here. in 999 monks said we wioll all die when in 1000AD sky will fall.
    On eve of 2000 another wave of predictions.
    Since then here were hundreds and hundreds for every year. I read in 2003 Atlantis will rise and united kingdom sinks. This and that and when it doesn't happen what do preaches do? They say they have consulted with spirits more and they clarifyed a new date.
    So what do you sudgest? We drop everything and go dig a grave?
  • robur
    Thanks NickZ, my place is shielded by other Island from Japan. But there is another warning from psychic:
    Topic: EMERGENCY - Tidal Wave and Tidal Surge - Orgonize Australia
    SO it predicted more will happen. Seems to coincide with Piers Corbyn warning too..
    True or not, I think I should prepare.
    Oh boy. More predctions. One of my good friends is beleivinga religious group about north pole shift on march 15th. They are preching to committ suicide on the even of march 15th. He wants to to do and I cannot say anything tyo stop him from doing it tryed everything now.
  • NickZ
    @ Sucahyo and All:
  • sucahyo
    Originally posted by Rayce
    Please let this be known.....so people can be made safe.
    20 March 2011 - A fracturing of the North Continental Shelf in the Indian Ocean, north of north Western Australia will create a north-north east bound tidal surge.
    22 March 2011 - A simultaneous fracture will occur along the Java Trench, creating a northbound tidal surge.
    23 March 2011 - The Tidal surge from the North Continental shelf will speed up into the Makassar Straits and become a Tidal Wave in the Celebes Sea.
    20 March - North Continental Shelf fracture - approximately 800 kms
    Effects:
    4 metre surge will go North, North East - affecting southern coastlines of Sunda Island group, and half of Timor.
    Expected time 9 pm
    22 March - the Java Trench fracture. 2 areas.
    First fracture 500 kms in length
    400 kms south of eastern end of Java, to Christmas Island
    Second fracture 2,400 kms in length following the Java Trench.
    200 kms north of Christmas Island to two thirds up Sumatra
    Effects:
    Christmas Island may not recover. As it is 40 kms from the expected fracture point.
    6 am 22 March. 30% Land mass displacement. (May appear as earthquake)
    4 metre Tidal Surges northwards - for all north of Java Trench coastal areas.
    10 am 22 March from Malang (Java) north west to 20 kms south Sibolga (Sumatra)
    Including all islands.
    And inland of mainlands approximately 3 kms will be affected.
    23 March - Tidal Wave for South Philippines island Mindanao.
    The North Continental Shelf surge will gather speed up the Makassar Straits and form a 10 metre tidal wave in the Celebes Sea.
    Effects:
    It is expected to hit the coastline between (20 kms south of) Gan Santos and 40 kms east of Cotabato at 3 pm 23 March, and have an effect 7 kms inland of that area.
  • NickZ
    Sucahyo:
    Thanks for your answer about the plastic coating on the cans.
    Were you affected by the events last night?
    No problem here yet, but the wave is coming here at 4:40 this afternoon. It probably already hit your area, right?
    The worst quake in Japans History.
    Earth changes are something to prepare for. Those that do will fare better. Those that don't think they need to... well... I know that people will not believe it, until they see it. That is normal.
    Those interested can read the -9 Mayan Profecies-, Mayans were the Time Keepers.
    And knew more about this, than maybe anyone else.
    I will make a couple of cement - beach sand batteries to test, as soon as I can. If I'm still here this afternoon.
    There are worst things than dieing. Like living, with no means.
    Back to waiting for the Tidal wave, for me.
    If you don't hear back from me, you'll know I'm out of commision. I don't think that we'll be affected here, this time around. You never know.
    NickZ
  • sucahyo
    Is sanding the plastic coating off of the inside of the cans really necessary?
    This surprise me. Do the inside of the can have a plastic? It seems mine don't have one, but I don't notice it. I just pour it full...
  • NickZ
    robur:
    Good to see you back. Sorry to hear about the problem. I hope that things get better for you.
    I'll try the compass on my pyramid and see what happens.
    I have bought the cement and copper tubing materials for my beach sand - cement batteries, and soon will start on them.
    Blackchisel- did you make the Big Bertha battery out of a plastic container? I have a one gallon jug (plastic) I was also thinking of using. To see if the bigger size has anything to do with increased voltage.
