More thoughts and updates
I did run some tests with pyramid. Despite couple mistakes I was able to get some scope readings which look promising.
First of all; My cones were done on multilayer paper form laminated with polyester resin. Coils were sealed the same way. Well, it was a mistake. What I did was a result of conventional thinking and sealing/insulating/securing wire but..I encapsulated entire coils in resin which will diminish any effect of Aether upon. They should be made with bare copper (or gold ) wire, close to 1mm thick. They will be easier to wind and easier to secure without gluing entire coil. Nylon fishing line can be used to separate turns from shorting. There should be a gap in between both apexes (assuming that we're working with "hour glass" setup - bases of cones outside) of about 2-1/4" -2-3/8". This is expected Aether concentration area. I did some tests on this gap last night/early morning by placing 6 magnets in a tube, just big enough for them to fit inside and #18 wire wrapped around. Tube was placed between apexes and scope connected. Environmental 50Hz disappeared and I noticed much higher freq. oscillations in range of 35mA.
I also set another experiment for the night in attempt to see the effect on water. I have two cones, separated and sitting on their bases. Base wires are connected to a 6V battery. Apex wires not connected to anything (I did check them with a scope and there is a sin like wave of 5kHz with what appears to be harmonics going up in MHz range. There is no presence of environmental LF ). There is one shot glass sitting on the apex of one cone and other inside a second one. Both are filled with water. There should be an effect on the water. What I expect is that Aether will have an effect on matter and is capable of transforming it.
I was working until 6:30am and had to get up couple hour later. I need a nap before doing any more work but I'll provide more info later.
I couldn't resist checking: Water from the top (apex) of the cone has fluid shapes such as petals, balloons or something similar in shape to the little fan children attach to the handlebars of their bikes.
Water from inside a cone has defined geometric shapes; triangles (nets of triangles/diamonds) hexagons. There is a blue color in aura. Also, while holding hand over there are pulsing effect in other parts of the body. I'm freezing samples in hope to see something trapped in ice and... I need a break lol
Vtech
Vtech
