Originally posted by sucahyo
I wonder what happen if we wrap the outer side with paper. Orac - pyramid....I was thinking about that but came across W. Reich note saying that any more than three layer orac should not be used by inexperienced people. Also, I should clarify what I said about metals; they absorb energy at first but release and reflect. Not sure if we actually need a multilayer pyramid. I'm waiting for some copper sheets. As soon as they arrive I'll be making one or two and run some tests. This theorizing only(mine) and looking for answers gives me headache
Any idea for CW or CCW winding?
Not yet
I highly believe flat spiral coil will polarize energy, based from freezing them on ice test.
Yes, I agree. Pyramid collect more energy if exposed with sun light or moon light.
I kept thinking about spirals, ferns, fiddleheads (plants), nautilus etc. You know where I'm heading
My question was WHY this is happening? Also, many of those great designs were used throughout centuries in various man made structures (Did a man stood behind a drafting board and designed each and everyone of them? - I doubt) Was this just an admiration or fascination or there was actually a purpose? We know the answer don't we
I know and did various experiments based on the resonance. This can be very powerful effect but also, when done on very subtle level allows to interact while using even more subtle energy. I was going through fact such as estimated weight, Pi, Phi, location etc. of Great Pyramid and I believe it was designed to resonate with Aether, just like everything as we know it. Certain shapes such as spirals, cones but also 2D can "disturb" Aether and cause to flow or create 3D forms as a response. I think what we need is to find a way to create interaction within local Aether/Orgon/Zero Point Energy (whichever name we want to use it) field but in certain way so Aether will respond creating vortical flow/motion and we need to guide it onto desired path. Spirals are good, maybe conical spirals are better? Aether naturally travels on curves not a straight lines.
I think neo is not good too. People from different community report some bad effect of neo magnet if placed on device that manipulate aether. I was thinking of employing them to magnify energy for the purpose of measuring eventual electrical potential, not for health related purposes. I think crystal can replace neo, and I believe flat spiral coil too or SBB coil: Yes, crystals may be even more powerful as long as their placement is correct.
From my experiment, I conclude that that coil above will emit male energy to viewer direction, to you.
I found alumunium produce male energy which currently not what I need.
Good luck with the test
How about this meter:
Experiments with the Life-Energy Field Meter Cannot afford atm.
I think even electroscope should give some reading. I'm going through John Keely and Dr.Wilhelm Reich notes, research. Looking for more clues. I found some interesting things, probably known but I'll try to summarize them all and see if we can draw some conclusions - hints.
Not yet
.How about this meter:
Vtech
[/IMG]
[/IMG]
