Hi Guy's, Here is a pic of a rough tower coil I whipped up last night. It has three joins.
I made it from an old quadfilar coil. If it works good i'll wind a much better one.
It's 450 turns .5 mm wire The primary is 13 turns 1 mm wire I have two of those if I need them.
I plan to use a stingo with it's transistors mounted on this heat sink- And pulse a car coil, then put the HV through the 13 turn primary around the base of the tower.Bottom wire from the tower will go to ground the top one should be hot. For lights.
I hope.
Hope to build the Stingo tonight.
I made it from an old quadfilar coil. If it works good i'll wind a much better one.It's 450 turns .5 mm wire The primary is 13 turns 1 mm wire I have two of those if I need them.
I hope.Hope to build the Stingo tonight.
. If the corona maker was durable, I would keep using it.
