Thanks Farmhand !
Well, now i must to put you a few questions..
That ignition coil, where i should search to provide that ?
Volcano coil, that is something homemade i suppose ?
In that drawing there is no 3 to 1 transformer, you should add that too
for us suckers !
And how to recognize 3 to 1 transformer, could you express it in voltages ?
I hope too ,you are making something really marvellous !
for us suckers !
2.
Yeah Volcano coil is what I call it, its a Bifilar conical coil. I made mine from a garden solar light lenz, then wound the coils on it, just roughly one at a time, glued with hot glue. best results to keep the coils about 10 mm apart.3. The three to one tranformer is one I made, it's a Quadfilar coil (for windings) One as primary and the other three serise connected Tesla Style Positive to negative. I will add it to the drawing tonight. The next video shows it working in the recovery mode. I do things a bit backwards I make it first then draw it I can't draw every stage of evolution.
I can see it will self run but not sure if it will charge the source battery over 12.9v or so I don't think with the recovery method i'm using that is possible, but it is very interesting and promising. And Can be fun when the juice is turned up.
I have it now using maybe 180Ma t0 240 Ma it;s very hard to tell, without a proper analogue meter. Video soon !!
Been winding it about 2hours now. Hope I did not use a thick gauge now
Pots and all should fit on there, like what 7imix did.
