Attention to all Gravity and Aether Researchers
  • #91
    I have a question for anyone that can answer it - Harvey, anyone?
    It takes 1 joule of energy to lift a small apple to 1 meter.
    Over how much time? Let's just say 1 second and lets
    say it is in a vacuum so air resistance isn't even a factor.
    How much does the apple weigh? It would weight about
    1/4 pound or 4 ounces - or whatever weight is necessary
    to require 1 joule to lift it to a meter in a second but it should be
    fairly close to that.
    My question(s) is this:
    How many joules of energy will it take to lift the exact
    apple to 0.75 meters over 0.75 seconds?
    same apple to 0.50 meters over 0.5 seconds?
    same apple to 0.25 meters over 0.25 seconds?
    To this day, thousands of people have not been able to
    answer this simple question.
    If it requires more information to calculate the answer,
    let me know what more is needed,
    Wikipedia's Practical Examples
    Last edited by Harvey; 08-22-2010, 09:42 AM. Reason: Fixed typo was .50m is .25m (Thanx Aaron ;-) )
    • #92
      relative to the Earth's surface. That value will be the differential between his potential energy at a specific altitude and the potential energy he has at ground level.
      • #93
        calculating work
        Originally posted by Harvey View Post
        • #94
          potential difference
          Harvey,
          I get that the distance from the center of the Earth plays a role.
          But I would see that the rock is not what has any potential value.
          I don't see it as a matter of semantics either. The "value" of potential from
          the center of the earth in my opinion should be assigned to the
          gravitational potential itself and not to an object that is subject to that
          gravitational potential. Of course the properties of the apple will be taken
          into consideration but that in and of itself has no change, reduction,
          or increase in any amount of potential being "stored."
          Also, the apple in free fall is near motionless relative to the flow of
          the gravitational potential
          . It achieves an equilibrium of sorts when it
          cannot accelerate any faster.
          Under acceleration, the aether is pushing it down at a speed with the
          apple resisting a certain amount meaning the apple is not moving as fast
          as the gravitational potential. If the apple got to a point where it did not
          accelerate any faster, it would be at an equilibrium with the flow of the
          gravitational potential - just to keep the example simple.
          When the apple hits the ground, there is resistance the apple encounters
          and the aether pushes on the mass of the apple with a certain amount
          of real force - force in the literal sense of mass being acted upon.
          The resistance of the apple to the flow of the aether from free fall is the
          potential difference and that resistance is work. There was a bit of
          work with air resistance but not as much as a direct impact.
          If we have a 6 inch pipe of water pressurized at 100psi and put the apple
          in the flow it will accelerate until it is at the speed of the water or
          at least close enough depending on how much the apple resists the
          movement - lets just call this free fall.
          If that pipe is 10 feet or 100,000 miles long, the potential in that apple
          isn't changing - assuming the water is the same along the entire
          length, lets just compare that to 9.81. If it traveled 100 feet or 1 million
          feet, there is no change in the potential in that apple.
          The apple isn't feeling a push on it when "in the flow" so for all practical
          purposes, there is no potential difference at all - (no matter how far
          or close to the grate it is - there is no difference in potential).
          If the water goes through a grate and the apple can't get through,
          it is then and only then that the water exerts a real push on the apple
          and that push is from the resistance of the apple resisting the
          push from the water.
          So essentially, none of the potential from the water was usable by the
          apple UNTIL it was able to resist it. Then and only then was there a
          potential difference and then work was manifest.
          So an apple in free fall is in near equilibrium with the aether. It is not using
          any of that potential and there is no potential difference relative to the
          falling apple. When the apple hits the ground, then and only then does it
          resist the downward push of the aether on the mass of the apple.
          Then and only then does that free gravitational potential supply the
          source potential to cause actual work in measurable joules of energy.
          Again, I don't see it as semantics. When lifting an object, that doesn't
          create the potential difference and it doesn't address what the actual
          source of potential is.
          The higher it goes, it has more potential in the abstract form but not
          in the actual.
          If the rock is further from the surface, I say it has access to less
          potential, and I am correct in saying that because that does not
          include any variable of the rock having more distance to fall. In that
          time and place that an object is sitting STILL at a higher altitude,
          there is less local potential it has access to.
          Any reference to the concept of something "having" more potential
          implies a local phenomena of more potential gathering, having, storing,
          increasing, etc... when in fact, the local nature of the potential the
          object has access to in it's locale is actually decreasing at a rate
          at whatever proportion to the distance from the earth.
          That picks at the "storing potential" concept more than anything but
          does not take away from the fact that you are correct that there is
          more "potential" the further from the surface. Again, that is why I state
          that the higher an object is, the less potential is there at the object,
          which is completely opposite from the idea that as an object is raised,
          it "stores" more potential.
          But the "more" potential the higher up part I think in aetheric terms is
          to state that the higher an object is, the longer it can be in the
          flow of the dynamic river of gravitational potential in order to build up speed so there is a greater "potential" difference upon impact meaning more
          work is done - resisting air, impacting and damaging the object, whatever...
          I'm not trying to
          correct you Harvey, I'm just paraphrasing in the perspective of an
          aetheric gravity model - mine at least - everyone can state their own
          based on their model.
          You make a good point about the dirt being removed from Earth and
          thereby reducing its mass overall. But of course for all practical purposes,
          it would be insignificant - or minuscule as you mention.
          The apples has quite a bit of "potential" that far from the center of the
          Earth - assuming there is even a gravitational pull there. It could get
          lighter and lighter down there for all we know if we get close enough
          to the center.
          Again, using the surface as the reference point or "ground", the higher
          up the apple goes, the longer it would have access to gravitational
          potential if it fell and there is no intrinsic increase in potential in the apple itself,
          meaning there absolutely is no greater potential "stored" in the apple
          the higher it goes.
          It is AFTER the apple falls that more of anything is realized but not before.
          The text book definition of this is seeing it backwards and is not a matter
          of semantics. It is like saying the universe revolves around the Earth.
          All the calculations to show what is doing what will still work out to
          determine proportions and relationships when but seeing it for what it
          is - it is the Earth that revolves around the sun, which revolves around
          the center of the galaxy, etc...
          • #95
            Epic post Harvey. If you don't teach for a job, perhaps you should.
            "An interesting experiment in this regard would be to lift a ball 1m and drop it inside a quarter-pipe of 1m radius and see how far it rolls on ice horizontally - maybe 9.8m? Does it matter how fast we raise the ball to the starting point?"
            Sorry for highlighting the one thing that doesn't seem perfect in your post. If a drop an objec from ANY height, onto a quarterpipe and level exit of ice (low drag) surface, the resulting horizontal displacement until the roll is over, is, In my understanding indefinately. No specific value it to be expected, in any multiple or fraction of a gravity constant, in any unit of measure.
            Furthermore, the radius of the quarterpipe is irrelevant unless friction is greatly pressure dependant.
            Or, I misunderstood your explanation, in which case I apologize.
            More likely, you were just messing with our minds with your example, in which case I didn't fall for it.
            My simple understanding of raising an object vertically has always been tightly connected with velocity change. If yo first accelerate the apple upwards, say 0.5m at 9.8m/ss, and then let go of it, another 0.5m later, another same amount of time later, it has reached 1m, with Vend=Vstart.
            If you put in the joules for the first 0.5m of constant accelleration, you get a bit of extra height "for free". In case of matching gravity, inversed, in my little logic, you get the same speed and distance, making it easy even for me to comprehend.
            Would you accelerate at only 1m/ss, you'll need to raise to much closer to 1m high, in order to get to that 1m with a small free end lift, where vertical velocity is exchanged for height until it stalls.
            • #96
              Hi Aaron,
              There certainly is a particular issue associated with the local perspective of gravitational potential energy. The issue is akin to a conversation I once had with a fellow on You-Tube named Desertphile with regards to magnetic potential energy and my first You-Tube videos entitled "Magnets Doing Work".
              The issue has to do with creation and transference and it really underscores what you are saying about how things are perceived.
              In my conversation with this fellow I posed a question to him regarding magnetic potential energy - I asked him, if I create a new magnet, and the magnetic field is said to be infinite by classical terms, then does this create potential energy with respects to every magnetic material in the universe? He refused to answer but instead turned the conversation to gravity.
              So, in trying to help him realize that we live in an 'open system' we call the universe, I asked him what the potential energy was for an incoming meteor and asked when exactly was that potential given to the meteor. For some reason he treated me as some sort of nemesis.
              But that is the reality of it. Every object in the universe contains a potential relative to every other object in the universe and that potential begins at the time that energy is converted to matter (or matter is transmuted).
              So we can say that lifting a spaceship off the surface of Earth imparts potential energy to the spaceship but it is entirely subjective. Because the potential is only measured against some reference. When that exact same spaceship reaches Jupiter do we assume that some magical transference has occurred and now the spaceship embodies some special energy field that increases it's potential by 318 times? No. And there is the other problem - transferring our reference. The simple act of moving our reference from Earth to Jupiter somehow causes all this potential energy to manifest itself.
              Similar things happen in electronics. You can have a split rail power supply and measure both positive and negative voltages relative to the power ground reference. But as soon as you move your reference from ground to the negative supply, now you get the sum of the two supplies added together. So while it may seem like we just doubled our supply voltage, the reality is that the potential was always there and all that needed to be done was move the reference. It may surprise us to discover that all of the voltage on both supplies is a negative voltage when we move our reference to Earth ground.
              So while we may perceive things a certain way, it does not mean they are as we perceive them. We may lay on the ground looking 'up' at the stars when in fact we may be hanging under the Earth looking 'down' . Try that sometime and imagine you are hanging under the Earth We say that energy can be stored as potential energy because it is how we perceive it. In reality the potential has always been there and we are simply moving to the other potentials relative to a specific reference. Fortunately in electronics we can determine what a true zero reference is because it can be demonstrated chemically to show a zero charge. But how do we do that gravitationally? What is our reference or touchstone for true zero potential?
              • #97
                gravity = natural teleportation?
                First post here:
                thoughts:
                to move an object, requires pushing, or pulling.
                With gravity, objects move without pushing or pulling.
                To teleport an object, you need to give it "imaginary momentum', so that it "switches off gravity" (by creating its own space-time continuum or "gravity"?)(----------), and "imaginary displacement" (so it switches gravity on only relatively- it will then "jump" to another location where a complimentary pattern of vibration has been created to the pattern generated in the object at its initial location.....???).
                How and why a ball bounces is related to how to levitate something- if instead of "bounce" you get "a jarring action", this is one-step below that needed to teleport.
                Partial teleportation (i.e. where part of the movement of an object is via a teleport-factor), and partial levitation (where part of an object's state on the Earth may be levitation (so it presses less) may be quite common.
                (Shockwaves in rocks in multi-collisions could "factorise their mass (at least partly) causing the rock to develop "a rare-earth charge" (or gravito-electric/magnetic 'charge')(gravity = imaginary electro-magnetic effect?)(electro-magnetism fits apparently the idea "juxta-position" (abc -> acb); imaginary juxtaposition fits the idea "square is the distance") so press less on the Earth?)(A spring-weight measurer does a similar trick so cannot be directly used to detect if this effect is occuring?)
                "Natural (partial) teleportation" may occur in some rocks in multi-rock slides, but only be detectable by looking at the relative positions of many rocks vis-a-vis the boundary of the area they end up in. It would show up as "extra displacement" not able to be accounted for by traditional physics, but measuring the field of rocks via conventional physics would probably discharge the effect so proving it would require a different way...?
                • #98
                  • #99
                    Hi GB,
                    Sorry for my late answers to your questions below. I knew that the Wave Structure of Matter (WSM) model that I use the most had some answers but I had to go learn what they were, draw some diagrams and then check it with the folks who make the model (not me) and then wait for confimation. Note that when I use the terms "space" or "vacuum" you can just substitute the work "aether". They all just refer to a medium in which stuff happens. I'll use aether here since it's the one you seem to prefer.
                    Originally posted by gravityblock View Post
                    Thanks Aromaz,
                    Does anyone have anymore "What if's" to add to Aromaz's theoritical gravitational model? Please post your own personal model, so we may all learn together. One of the models or combination of models may be correct. It wouldn't be a surprise if gravity is due to a variety of effects and causes interacting with each other.
                    GB
                    The simplified, complete answer to what is gravity along with pretty diagrams can be found here:
                    That's my own website, even though the model isn't mine.
                    But since not everyone looks at webpages, in short: gravity is a movement of particles from lower density aether to higher density aether. In the WSM model, the aether is filled with waves what are constantly being exchanged back and forth between particles, which are themselves composed only of waves riding on the medium, aether. A wave is emitted from a particle with a certain starting amplitude but that amplitude drops the farther it gets from the particle. Waves arriving at a particle arrive with increasing amplitude. So basically, the farther from the particles, the lower the wave amplitude. And conversely, the closer to the particles, the higher the wave amplitude.
                    The Aether density, really the Aether energy, at any one location is calculated as:
                    density = mc^2 = hf = c x sum_for_waves_from_all_particles(amplitude^2 / distance_from_particle^2)
                    So basically the density is proportional to the square of the amplitude of all waves from the universe at that location.
                    If you have a large mass of particles like the Earth then the amplitudes of the waves contributed by those particles will be relatively high and so the density, and hence gravity, will be high. If you are far from any mass then the wave amplitudes will all be smaller since the amplitude is lessor the farther they are from the originating particles. So out in the middle of space the density, and hence gravity, will be smaller.
                    The reason particles move from lower density aether to higher density aether is because, as I said above, particles are really just made up of the waves that arrive at and leave the particles. Waves moving through the higher density region move more slowly than waves moving through the lower density region. So the waves arriving at a particle from the side of the particle closer to the Earth will be moving slower than the waves arriving on the other side of the particle, farther from the Earth. Since particles are really just made up of these waves, by definition the particle is now closer to the Earth. I'll try an attach the last diagram on the above webpage to this post; it shows it well.
                    Thanks Aaron and Harvey.
                    I think this thread is moving forward and in the right direction. Thanks to All. Keep the information and ideas flowing. Can gravity be controlled, manipulated, reversed, negated, or turned on/off to our benefit? If yes, then a theory for how?
                    GB
                    How can gravity be manipulated? As I said above, the Aether density is really Aether energy. If you look at the above formula again you'll see that it's even equal to mc^2. The amount of average energy at any location is equal to the mass of the universe (m) x c^2. And it's really the energy in all those waves. If you tap into that energy, then you decrease the amount of energy i.e. the density. Since gravity is a movement of particles from a lower density aether to a higher density aether, and you've just reduced the density by stealing some of that energy, you've just reduced local gravity!
                    Where'd the energy come from? The waves. Those waves were headed to some particles and now those waves are diminished in energy. So whatever energy exchange that was going on between the particle that emitted that wave and the receiving particles will be diminished. So if that exchange was making the partiticles vibrate, i.e. heat energy, you've just cooled them. If that exchange was attraction of a negative charged particle to a positive charge particle then you've just stolen some of the electrical power (current, voltage) in whatever circuit was doing something.
                    When John Searle allegedly fired up his SEG and connected a load to it, two things happened. One was the machine got colder and the other is it flew. So he may have been tapping Aether energy. David Hamel's allegedly created a plasma and then took off (more on my particle creation idea below.) Floyd Sweet, at the prompting of Tom Bearden, also measured a weight loss when his device was running. And then there are all those reports of car's stalling close to UFOs.
                    So how to tap the energy so you can get the side effect of manipulating gravity? My idea is to convert that energy to particles, i.e. particle creation. My webpages describing it are at:
                    But as a result of doing this research so I could answer your questions, I realized the calculations on those webpages are wrong. I should have been using the above formula for density instead of just summing the amplitudes. So I have to go redo the calcs. However, with the way I was calculating it before, I couldn't see where the net energy gain was coming from. In terms of the math there was no net gain, all the waves from the universe just cancelled each other out since I was just summing positive and negative amplitudes. But now since I'll be squaring the amplitudes the gain is very clearly from all the waves from more distant particles not involved in the device. So I seriously owe you a big thanks for asking these questions and causing me to look more closely again at WSM! Now, hopefully the new calcs will show that it's doable.
                    -Steve
                    http://rimstar.org http://wsminfo.org
                    • Originally posted by light-travel View Post
                      First post here:
                      thoughts:
                      It is interesting that we can move objects with electric fields, magnetic fields and gravitational fields in very similar ways.
                      Electric fields can be unipolar - but to push or pull it needs to have a same or opposite pole and the force between the two can be measured and cause action at a distance.
                      Magnetic fields are always (so far) dipoles and like the electric fields they must have a same or opposite polarity magnetic field to interact with in order to push or pull. These to can be measured and cause action at a distance.
                      Gravitational fields are always (so far) unipolar. But unlike Electric and Magnetic fields - the Gravitational field will act on any mass regardless of the Electromagnetic state and it does not need an opposite or same polarity to cause the pull. It too can be measured and cause action at a distance.
                      Young children learn early how to cause an action at a distance when they blow out a flame on a candle. So intuitively, they learn that action at a distance can be caused by moving air locally and having that move to the object and cause the action at a distance from the source.
                      We know that water flows in the turbines at a hydroelectric plant and yet by using wires that can cause an action at a distance where the energy is applied.
                      We know that if we turn on our water hose, we can move leaves with the stream. Or we can use a blower or compressed air etc.
                      So intuitively, we understand the concept of using a medium to transfer energy from a source to a load. So we rationalize that if a magnetic field is like wind or water that we can put energy into and get an action at a distance. And likewise, we can view Gravity in similar terms as a fluid like field that we can put energy into and get that energy to move to a distance and cause an action. The moon puts energy in and moves our tides from a distance. And interestingly, the Sun has a greater gravitational force than the moon at our location here on the Earth. But the gradient for the moon is steeper than the gradient for the Sun, so a larger potential exist across the Earth and this cause a greater differential to exist for the water to align with. Interesting stuff
                      There is one thing you mention that is quite worthy of evaluation: "a jarring action"
                      There is a way to look at this that is not easy to explain in simple terms, but I will try.
                      I will say that there are five states of position relative to time and each higher state is a rate of change of the lower state. In Calculus, each state is called the derivative of the prior state and is given a notation which we call a "Prime". The symbol for Prime is the single closing quote. So if we were to say P-Prime, we would write it as P'.
                      Zero state: Position. P
                      This is a single motionless point in a coordinate system relative to a reference. There is no lower state, thus this is not a derivative.
                      First State: Velocity. V = P' (spoken "P prime")
                      Velocity is the rate of change of Position and is the first derivative of position.
                      Second State: Acceleration. a = V' = P'' (spoken "P double prime")
                      Acceleration is the rate of change of Velocity and is the second derivative of position. It is also the first derivative of velocity.
                      Third State: Jerk (or jolt). j = a' = V'' = P''' (spoken "P triple prime")
                      Jerk is the rate of change of Acceleration and is the third derivative of position, the second derivative of velocity, and the first derivative of acceleration.
                      Fourth State: Jounce (or snap). s = j' = a'' = V''' = P'''' (spoken "P quad prime")
                      Snap is the rate of change of Jerk and is the fourth derivative of position, the third derivative of velocity, the second derivative of acceleration and the first derivative of Jerk.
                      There are two other facetiously added progressions to this pattern that are called 'crackle' and 'pop' but I see no reason to extend this out that far.
                      Let us evaluate a real world situation where all of these things can occur:
                      The Drag Race - The car sits on the line waiting for the tree to turn all green. This is Position, P and velocity is zero.
                      The light turns green and the car begins to move. For a few short inches we have a change in position, P' aka Velocity, V.
                      But very quickly that Velocity begins changing, and the car begins to accelerate, a. This means that there is a compound change in position, P'' and a change in velocity, V'.
                      In a couple of seconds the engine tach's out and the driver must shift gears. The momentum of the car keeps the car in acceleration during the shift, but the power curve gives the driver a sudden burst of energy after the gears have meshed and now we get a noticeable Jerk, j as there is a rate of change in acceleration. Right in the middle of that Jerk, the tires lose a minor about of traction and you may even hear a chirp, but when the grab you get . . .
                      The Snap, s. While the acceleration was changing somewhat consistently during the tire chirp, the Jerk itself has a rate of change as the tires transit from slipping to grabbing. And thus we get the final state.
                      If each of these rates are known for the precise time they become active, you can accurately identify precisely where the position of the Dragster is at every instant in time.
                      So what is "a jarring action"? Well, it is most likely a Jerk, or even a snap. Ever watch a child pull a wagon over a tree root and the wheel gets stuck? What does the child do, intuitively? Since the tire stopped with a constant velocity, the child automatically initiates acceleration by rolling the wagon back a bit and accelerates it. The wagon pops up in the air and falls back trapped. So what does the child do now? Rolling the wagon back and then accelerating it, just as the root and the wheels meet they give the handle a little jerk. Presto, problem solved.
                      This jarring action is a very good application of energy and can have some unexpected results. It is a way to concentrate a lot of energy in a very short period of time.
                      Case in point:
                      Recently I wanted a single slice of individually wrapped sandwich cheese. After consuming my snack I had the plastic wrapper in my hand and I thought I would snap it and play with my cat a bit. So holding it between my fingers and thumbs, I crossed my hands and then spread them out quickly expecting to hear a loud audible pop. Although I was holding the material in just a small 1" diameter area, to my surprise I found myself holding two pieces of wrapper with a clean break that looked like a scissor cut perpendicular to the direction of the pull. "Must have been a weak spot in the plastic" I thought. I tried it again - same thing, clean precision break straight across the entire width of the plastic. A third, fourth and fifth time all resulted in the same type of tear. So I pondered, I wonder if I gradually increase the pressure over time if there is a breaking point that will result in this behavior. I pulled the plastic with gradual increasing pressure and soon it began to deform. It stretched and stretched until I had huge bubbles surrounding my thumbs, but no tears or breaks.
                      While this behavior is specifically related to the ability of the plastic to change shape under pressure in a certain amount of time (I forget what we call that ) the experiment does illustrate how effective the 'Jerk' or 'Jarring Action' can be. We apply this in our daily lives, opening jars, sliding doors, pushing a grocery cart over a clump of gum on the floor, loosening a nut with a wrench etc. And it is one of the reasons for multistage rocket engines that needed to reach escape velocity.
                      • Potential and Sound
                        Potential:
                        I think we have a description problem here. Similar to that between Photon and Light. Potential as word is suppose describe the maximum potential. A 9mm bullet has the potential to kill a 100Kg human over distance of 30 meters; but while lying on the table it cannot even kill a milligram of mosquito.
                        Physics description is:
                        Sound waves:
                        • Thank you David for the kind words and encouragement
                          Whether or not the Aether can act on itself has been the subject matter of discussions I have had recently off forum. It must be able to, I think. Otherwise, I don't think a wave could propagate using it as the medium.
                          I watched a cat in a zero gravity environment where it was flowing at the same speed as the Aether in the zero gravity craft and I noticed that there is a clear connection between matter and space time because as the cat attempted to land on its feet through inertial maneuvering, it actually began to accelerate in the spin. What was the cat pushing against when it was spinning? So there must be a binding between matter and space-time that we interrupt when we accelerate matter.
                          What would a disturbance in space-time be like? Perhaps a vortex:YouTube - underwater tornado in Aruba
                          Or rushing wave:YouTube - Pearlies
                          I imagine it would be a longitudinal spherical wave. Of course so did Oliver Heaviside :The State When the Speed of Light is Exceeded
                          • fifth dimension...
                            Thanks Harvey;
                            I have limited computer access- will need to print your reply-
                            some quick comments:
                            an experiment was successfully carried out on the T.V. program called Top Gear". A snowmobile drove at high speed (70 mph I think) and continued from land on to deep water, and travelled across an expanse of water without sinking. At rest, the snowmobile would have sunk. (There is also a lizard that can "run on water").
                            I think the "Hutchinson effect" is like "catching": to catch something "it mustn't "jar" (i.e. mustn't 2-d bounce?) - ther shock waves must disperse back-and forth in a relatively "random" way (or star pattern).
                            A square-shaped magnetic field could cause an object to "jar "externally" (part-levitate?).....
                            The 'Searle effect" I think is like "bouncing": to "bounce" an object must (in some degree) "square up" (or refuse to jar- i.e. not line-up its internal and external structure-support). A star-shaped magnetic field I think could assist an object to "bounce "externally" ("jar" wholy internally- so creating a strong push from its surface(s) on surrounds- again would look like a levitation tendency...
                            I think the inverse of electro-magnetism (of "slip" or "area differentiation")
                            is "magno-electricity" (or "grip" , "volume differentiation": a constant "jarring" (bounce))
                            (e-m as "a jarring constant" ).
                            A "grip field" (ability to change between different grips) = a (virtual) gravitational field.
                            The inverse electro-magnetic state (the magno-electric state or "grip-state") of an object could interfere with a local gravity source (or "the internal structure of an object" could resist gravity (in other words, "an archway")....?
                            An archway doesn't "fall down", it "falls up" ....???
                            RE: your very interesting analysis:
                            my thoughts are (I left velocity as you wrote it, the others I have depicted somewhat differently (perhaps from a 2-d math perspective (Imaginary category, or "jump" perspective (Partial differentiation perspective?)(?) .....)
                            ..or non-position ...?
                            what is the difference?
                            Need a triangle (triangulation) to decide...?
                            Second State and third states: Acceleration.
                            Second, Third, fourth State: Jerk (or jolt).
                            +- Fourth State: Jounce (or snap).
                            5th (------------) crackle
                            6th (------------ ---------) pop
                            Sorry about the gaps- potential value (Re: new technology I'm thinking about) saying that (not states as such)
                            (Gravity, "5-d", pre-math Einstein General Relativity, are all the same pattern, is my impression)(= "+ - fourth; "state" ")........
                            • a cat in space
                              thought:
                              the cat "pushes against itself"- but cannot do so effectively without rotating (about one (or more than one ?) fixed axis
                              A spinning object (try walking towards (or away) the center of a merry-go-round) stacks to-away from the center of spinning; by spinning the cat can slingshot its paws (get extra resistance to propel its legs outwards?)
                              (conserving additional angular momentum so do not have to conserve (all) of it- so can retain some leverage ...?)
                              Thoughts: to set up an axel jump in ice-skating, one makes "an imaginary step" (raises one foot up as if to walk a step on the ice) - on putting that foot down the other side of one's body tends to lurch forwards- but as one lurches anyway deliberately to make the spin, the other lurch-effect dilutes the lurch-for-the-spin, allowing a measure of control to be achieved re: the spin (It becomes a mass-integrated spin or moment levitation effect- add jumping to this and you get "a controlled landing"- add "a controlled landing" to this and you get a slight imbalance- add putting one leg out on landing the axel--jump and you get "Neutral density bias' (or a gravitational 'transistor')
                              To make a double axel, the same pattern but with more force although less momentum (create a slight sideways-frontways uncertainty leading into the double-axel ?)
                              • Hi Harvey, light-travel,
                                If I recall correctly, jerk is what propulion using and detection of High Frequency Gravity Waves (HFGW) are supposed to use. I think the main researcher is:
                                Funny enough, I did a google search on High Frequency Gravity Waves to find some links for you and the first that came up was a US government paid for report saying the whole HFGW idea is fundamentally wrong. Of course that didn't stop me from keeping looking to find the above link and wouldn't you know it, their first document is one refuting the US government one saying that they were looking at the wrong effect:
                                So if you see the US government one, ignore it.
                                -Steve
