Originally posted by vidbid
SR 193 / SR193 - Study of the Device, Theories, Diagrams, Schematics & Experiments
The flyback is here, and is modulated IN SYNCH with the main oscillator, becuase it's easier to do the two separately with a small battery powered device like this, but they work together as if 1.... If you were to use a neon sign trasformer as your oscillator for example, you would not need a separate high voltage. That's what the 'Kapagen' strives to do, but it doesn't look like the windings are designed so well, and a MOT doesn't make quite high enough voltage to work as well as it should.
Staying With SR193 Device
Originally, I made many posts about the SR193 on the "my smith kapanadze replication" thread. I came to the solid conclusion that the device used a frequency generator to drive a push-pull amplifier. I was aware of the high voltage module, but I didn't have any reason to believe that the HV module was linked to the frequency generator.Originally posted by SuperCaviTationIstic View PostThe flyback is here, and is modulated IN SYNC with the main oscillator, because it's easier to do the two separately with a small battery powered device like this, but they work together as if 1.... If you were to use a neon sign transformer as your oscillator for example, you would not need a separate high voltage. That's what the 'Kapagen' strives to do, but it doesn't look like the windings are designed so well, and a MOT doesn't make quite high enough voltage to work as well as it should.
I got as far as I could get with the SR193, and so I started a Kapagen thread. Basically, I gave up on the Kapagen because I found that it will only deliver about 96% efficiency.
I went back to the SR193 design, started this thread, and started studying the Russian forums and found that they knew more about it than we did.
I plan to stay close to the SR193 design, which incorporates a flyback. Smith used a neon tube transformer in his design, but Smith never actually did a live demonstration where you could also observe the circuitry of his device while the device was operating. At least, SR has done this type of demonstration.
I believe that the elements involved with the SR193, among others, are high voltage, high frequency, radiant events, and energy propagation.
VIDBID
Vertical Pickup Coil?
I'm trying to determine the function of this vertical coil. I'm thinking it may be a vertical pickup coil. Maybe it picks up the frequency coming off of the output coil. Then again who really knows except SR, and he's not saying.
VIDBID
SR193 replication ?
YouTube - РЕПЛИКА СР.wmv
Can someone please give us a translation of this working SR193 replication.
Kacher
Vidbid,
Thank you for all your hard work - it is most helpful.
Question: What does a kacher coil do or what does that translate to?
I tend to agree with you that the sine wave is modulated but possibly a different way. I found a video that was made for Tiger by someone that may have been a mentor to him that shows a circuit with changing phase of two square waves. There are several ways to accomplish that using things like a NE566 or some OP Amps doing level triggering. That part of the circuit is just simple puzzle solving and no problem. The part I am am having trouble with is the actual coil magnetics / winding.
The early SR coil did not have that second layer that ran the full length and stated and ended in the middle. That seems to make no sense to me.
I also agree with you on the gapped core. Utkin described a "apartheid capacitor" separation capacitor which is what a gap in a core basically does - store energy. regardless, Utkin stated a counter wound coil is needed and I don't see anyone doing that. Any thoughts on the counter wound coil?
Me thinks there is a cold electricity part of this that we are missing and that SR device may be misleading or not fully understood. One thing is for sure, lots of people are working overtime to suppress this.
you can take this for fundament:Originally posted by mlurye View PostWatch second movie
(this is the ground of this on what all are bouilding on)
Static magnetics field or ionisation - called also as Dead Magnetic Field, but we can convert this field to meka a work (This Is The Point Where Need To Be Focused)
That way it can be started from a 9volt battery easely to in final give out 5 killovatts (for example)Last edited by Guntis; 04-24-2011, 10:31 PM.
