F.M.Chalkalis gravity system a donation!
Hello World,
Keeping my promise on informing you of any news on F.M.Chalkalis Energy multiplier, I would like to bring to your attention the following letter that was posted on Mr Chalkalis page about two week ago.
Link: F.M.CHALKALIS ENERGY MULTIPLIERW32
No serious replications yet seen on this forum. The design of Mr. Chalkalis is probable to big for most of us, but why not trying to replicate it on a smaller scale ?!. You can get all his drawings on his blog F.M.CHALKALIS ENERGY MULTIPLIER
I'm going to try to replicate his device using his specifications, as much as possible, for the materials I have available. I am sick and tired of all the thoughts and math discussions, mixing it sometimes with other devices. Lets build the damn thing and see what comes out. Then we have something to discuss. So, now you all can sit back and wait for me. If I fail, I will accept the title 'loser' no problem.
Dear Knovos,
Since you are following the F.M.Chalkalis thread, you must already know I am a supporter, because I honestly believe it can change our world. Unfortunately I do not have the ability to build a copy myself.
Reading your post:
Originally posted by knovos View PostNo serious replications yet seen on this forum. The design of Mr. Chalkalis is probable to big for most of us, but why not trying to replicate it on a smaller scale ?!. You can get all his drawings on his blog F.M.CHALKALIS ENERGY MULTIPLIER
I'm going to try to replicate his device using his specifications, as much as possible, for the materials I have available. I am sick and tired of all the thoughts and math discussions, mixing it sometimes with other devices. Lets build the damn thing and see what comes out. Then we have something to discuss. So, now you all can sit back and wait for me. If I fail, I will accept the title 'loser' no problem.W32
Dear W32,
Thank you very much for your encouragement. Yes I know you are a big fan of mister Chalkalis his device. And yes, I have read as much as I can about all the information that for building this device. This evening I made a start by making the first drawing for the smaller scale replication. I decided to make a replication that is 25% from the original. My first concerns are how to make two weights each 5711 gram and the motors that I want to use, maybe they are not strong enough. But that are problems that can be solved I'm sure. This device is really simple to build but it must be accurate in the dimensions. Yes the forces will be huge so maybe thats the reason why Mr.Chalkalis did not used bearings. Bearings are no problem I think as long as they are build for the forces. I really don't understand why there are no serious replications yet. Talk to you later.
Kind regards,
Knovos.
Chalkalis Replication pics
Hi all, just to let you know, I posted some pics here at overunity.com. I go by ae_vector in that forum.
Chalkalis Gravity Wheel
-brian
A thought.
Hey Brian,Originally posted by n84dafun View PostHi all, just to let you know, I posted some pics here at overunity.com. I go by ae_vector in that forum.
-brian
Here in California we use plywood as sheer-paneling for earthquakes.
Instead of more 2 X 6s try using plywood cut to the O.D. of the frame and nail it along the outside of the frame.
This will strengthen it substantially.
Just a thought.
StephenPotential, is a terrible thing to waste.
Great idea Stephen! For now I need the front and back open for easier prototyping, but eventually the plywood idea is something that I'll use for the final build. Thanks for the tip.Originally posted by Stephen Brown View PostHey Brian,
Just a thought.
Stephen
-brian
Just watching ...
Not working on this but very Interested and following, No comment but just a point that caught my attention 1st is Mr Chalkalis's device which started this thread pleasewatch it again. (I'm sure youve watched it a 100 times)
This is a "screen shot" from "energy from the vacuum" floyd sweets secrets
The rest are obvious
New Free Energy by George Mitchell - YouTube
ThaneCHeins's Channel - YouTube
Great thread Ashtwerth hope all is going well in other regards.
Best wishes DuncanWhatever you can do,or dream you can,begin it.Boldness has genius,power and magic in it.Begin it now.
Motor installed for RPM control
Here's a new video of the first motor test. The input is approximately 30 Watts and calculated kinetic energy is about 102 Watts. Not sure how much input will go up when loaded yet.
Chalkalis EM Replication First Motor Test - YouTube
Good job! I look forward to seeing whats next.Originally posted by n84dafun View PostHere's a new video of the first motor test. The input is approximately 30 Watts and calculated kinetic energy is about 102 Watts. Not sure how much input will go up when loaded yet.
I think the plywood that was mentioned before could be give you some more stability. The plywood does not have to be solid to work, you could cut out the center like a frame...
Keep up the good work.
Equation
I got the equation from his blog: F.M.CHALKALIS ENERGY MULTIPLIEROriginally posted by Matthew Jones View PostHow do you calculate the 102 watts of kinetic energy?
Matt
Watts Equation: Wt(kg) * 9.8 = Newtons * Radius(m) * rpm / 9550 = KWatts
The specs on my replication:
Total Center weights 7lbs = 3.18 kg
Diameter = 30 in, Radius =15 in
Location of weights from axis = 15 in * 45% = 6.75 in = .171 m
(Center weights location are 45% of radius)
Plugging in the values:
(3.18kg) * 9.8 = 31N * (0.171m) * (180 rpm) / 9550 = 0.100 KW = 100 Watts
