for the record
please be careful...Disclaimer and Limits of Liability
The demonstrations and procedures described within this thread are derived from the research and personal experiences of the author. The author is not responsible for any negative or adverse effects or consequences from the use of anything suggested, demonstrated, or discussed on this thread.....david
gravity waves found
I have no idea what that is, but one of the posters early in this thread stated that he was just about 30 minutes away from Coral Castle and could go there to verify things if needed - I wish I could remember the nameOriginally posted by david lambright View Postcan any one tell what it is around Eds machine... concrete? is there any thing else IN it?...just curious.....i cant tell from video or pix....maybe some oxide of metal or mineral ???does Ed mention any thing about minerals in his work??? .....david
Looking at the material, I would guess it was put there purposely. It does not look to me as though it is the result of some operational build up. I could be very wrong on that assumption. It does look as though it has been eroded to some extent so it may not have been all that smooth when he started with it. It looks too light and to course to be concrete. In fact, it looks more like Stucco which is more workable than concrete. Ed may have fabricated it himself from dust and particles left from hewing out the coral.
Magnetic Aluminum
I just wanted to comment on this as it has been on my mind.
Aluminum is ParamagneticGiant Paramagnetism in your Aluminum.
@Warren,
Great work on your rig
I actually like that 'Saturn-Ring' ledge you have there, very nice.
I can see some movement on the video, but really cannot determine precisely what action is occurring. However, I did notice the outer compass was tracking in a way that when it came near whatever those long lines are on the ground, left of the device, it would deviate from its radial indication - radial that is to the axis of rotation. The inner compass appeared to be tracking Earth North with some viscous hysteresis forcing it around on each turn. This would be even more pronounced at higher speeds to the point that the pointer may become motionless relative to the body of the compass. Conversely, if the speed was much slower, the viscous effect would be minimized by a greater degree.
Here are 3 things I would take into consideration relative to the experiment:
1. The elements are Ferromagnetic:
This means they will be continuously updating their internal domains to align with the Earth's field (as the rig turns) and those changes could be detected by the compasses.
2. Being Ferromagnetic, the elements will retain some magnetism:
This means that those portions of the elements that are most effected to become permanent magnets (like the element used to lock the ring), those elements will have a stronger attraction than the Earth's field - but at some angular position will be aligned with the Earth's field. As the two fields deviate from that position of alignment, the compass will track the stronger of the two, but with some vector differential between them.
3. Compass Turning Errors:
Something we are forced to acknowledge when learning to fly, is that a compass is not a compass when the aircraft is turning. This would also apply in your case if the compass were trying to track Magnetic North of the Earth. The Magnetic Dip can be quite problematic if you live far from the Earth's Equator.
What type of reactions do you get with the compasses stationary off to the side while the device rotates? What if the Marine Compass were placed with its axis directly over the rig axis? Those would be interesting tests as well
Cheers!
Video
Here is a video of an anomaly in Dave's wheel. I have two compasses mounted on the wheel and they BOTH are acting independent of each other. You'll have to look close to see the movements because of the glare on the boat compass.
There is definitely something radical going on here! I think Dave has discovered a mechanical magnetic gate, for whatever my opinion is worth.
EnergeticTube.com*-* Where technology goes LIVE!
Warren
has anyone tried a mobius strip rather than a normal circular core?
David, keep up the good work. Whether this device is location sensitive or not remains to be seen, although, anything that is location sensitive should also work outside the zone of influence,only to a lesser extent. There are many things we do not know about, so explaining the phenomena should be the last thing to be concerned with at this point. Proving the exidence of the phonemona should be the top priority. Ed first built his coral castle at a different location,then moved it all to this one where it resides today. This in itself says that he could have built it at any of one of many locations.Although many ancient sites of worship and or whatever other activities were practiced there, were built on these energy grid lines,it does not mean that they couldn't have been built on lesser grid lines, or far away from any grid lines altogether.Whatever the outcome from this experiment proves, it may be a device to tap into the aether/gravity of the universe.I think aether/gravity/magnetism, are all linked together in a way to make a complete system.What that system is is anybody's guess.Good luck. Stealth
hi there david and all other folks on this subject.
i have a couple of question that poped to my mind and want let go after following this thread.
1. based upon Leedskalnin device, in almost every embodiment of your devices and other replicas, i see again and again the usage of segments and not continues full path ( be it round or curved ) exapt some videos where you show the locking of circular rings by a jolt from the battery.
i have studied Leedskalnin device and what the mechanics and behavior of "magnetic current" might be and i dont see any reason for segmentation.
2. have you been documenting the ratios of your setups in which you saw the effects ? did you see any correlation between the sizes and the effects ?
other then that, keep up experimenting and updating this thread
Thank you for understanding and being super nice about it. I will be doing some tests and will report back once i come to a conclusion.Originally posted by david lambright View Post....you are not forgiven...welcomed, embraced, needed is more like it!!!...i am my biggest skeptic...i realise there is nothing conclusive in those videos ....they suck! what i see in the bottle is the steel wool particles forming small vortices as they fall..also i can see the same wave form that is seen above my device..... all of my "expirements" were done with what i either had [junk] or what i could get cheaply...i have repeated these exp. over and overand i am still skeptical...i know what i can do when funding comes..
your comments are welcomed..i still can not believe it...well almost...i hope you will continue posting.... your vids helped me get to this point ....again...YOU ARE NOT FORGIVEN...wanted, needed, embraced, etc. thank you....the demo this saturday might answer some questions, but raise more......your skepticisim is welcome here!!!........david
skeptical?
....you are not forgiven...welcomed, embraced, needed is more like it!!!...i am my biggest skeptic...i realise there is nothing conclusive in those videos ....they suck! what i see in the bottle is the steel wool particles forming small vortices as they fall..also i can see the same wave form that is seen above my device..... all of my "expirements" were done with what i either had [junk] or what i could get cheaply...i have repeated these exp. over and overand i am still skeptical...i know what i can do when funding comes..Originally posted by uusedman View PostIs anyone on this topic being skeptic to at least question or challenge what has been presented. Thank you David for sharing, however, until now it is all based on a single observation. The videos don't prove any statements being by David.
There must be more proof. The last video with the steel wool and baby oil is not proof. It can be that the steel wool is dripping from top to bottom, Show to the whole bottle and then zoom in.
Even though I am FE enthusiast there must be scrutiny.
My words are to enlighten and spread knowledge. Please excuse me for being to straightforward.
foil
i used off the shelf reynolds wrap...the magnet is N-50 neo,my brother Paul bought for me....the magnet will react with the foil, as it should, moving it due to eddy currents etc....i can not pick it up though.....after "treatment" in PMH, the foil leaps to the neo mag.....when i can get some copper foil, same thickness as al foil....i believe that this will work too....what about GOLD foil....way too expensive yet......and every body...thank you all for helping get this seed growing....without forums like this, this might have remained obscure....i hope i worded that correctly....in any case thanks....cheers........david
LOL
David, it might just be the foil itself. I tested a piece of aluminum foil and sure enough, it is attracted to a strong magnet, not very strongly attracted, but it sticks to the magnet. This foil was new, no manipulations with it.
My Build
Thanks David for starting this thread. If nothing else comes of this It will at least have gotten me to build a replica of your build.
All the pictures so far are here; Leedskalnin pictures by mrbreau - Photobucket
magnetic aluminum?
just a thought...a sample of this foil could be tested to find out why...i am still checking on research funding....if you think this might help, i can get you a sample...less expensive than sending pipe to latvia!!...i can almost taste the beer!......CHEERS!........david
