gravity waves found
  • I just rememebred a 105 years old experiment.
    Does anyone know the type of material used in your galvanized pipes?
    Normally it is Lead, tin zinc ??
    In reference Gustave le Bon had very interesting reports on the 'disociation' of the atom particular with regards to such 'radiation' from Lead with traces of tin.
    Such disociation does expel A,B,G and other energies. That it is possible this can be used to disturb the gravity sounds interesting.
    Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
    • Well, the John I know is a bit eccentric, self taught and has an extreme flair for the theatrical. He loves to amuse others with his technology. He also comprehends in a full measure the danger involved should the real truth ever be put to use by those with evil intentions. So he passes himself off as a bit of a crack-pot to keep that monkey off his back. I shudder to think of what could happen if his device were ever focused on our airplanes.
      His Ark video was really a staged show for an entertainment company. But he does enjoy the paranormal group because they seem to be easily convinced of what they see - and he even seems to feel there is a connection between this and extraterrestrials. Strictly speaking he's right, because both Angels and Demons are not from this planet and according to the definition of terrestrial, these Biblical creatures would be extraterrestrials. Personally, I think these demons have a lot to do with the paranormal and this is one reason I distance myself from it.
      Apart from the reproducibility of his experiments (which he has done for many audiences), I take most of his theatrical flair with the grain of salt with which it is intended. Just look through some of his recent videos on you-tube and you will see that he has a interesting humor about his presentations that side step the technical realities. So, John is a great experimental physicist in his own rank with effects he has claim to. And he is an interesting showman.
      • Yep
        Yep....EXACTLY
          Originally posted by SuperCaviTationIstic View Post
          Laugh it up....
          Pretty evident your mindset since you provide no opinion but only insult.
          You don't even address any other sources of THE SAME INFORMATION, only John. I know John knows the real way to harness this stuff...he only shows people an unstable way of doing it, in order to protect the true knowledge. He has 2 opposing field that are on the same plane. They interact between each other, and therefore boch wall moves continuously.
          Look at RODIN's coil. Thats the way to build it. The opposing magnetic fields are concentric. It folds in on its self. THE SAME SHAPE AS THE FIELDS MADE BY LEEDSKALNIN'S GENERATOR. You just have to spin it because in the rodin coil the pumping of current through the perfect geometry of the windings makes the rotating magnetic field.
          Don't knock it till you try it.
          If you bothered to read my quote carefully, I actually went out of my way to give John his dues.
          It seems it is YOU that has taken an insult where none was intended. Grow up.
          TP
          • I appologize. Growing up is a never ending process.....at only 22 I know I have a long way to go.
            I have a lot of frustration because so many people I talk with are so resistant to opening their minds, and I know how much this type of knowledge has been suppressed in the past. I'm always suspicious because I've encountered many disinformation agents in many forums.
            • All good
              No worries
              We are all learning no matter how old and decrepid we get.
              TP
              • jet
                Hi all.
                Sorry for the late reply.
                I tried to make the resin/iron powder mix as thick as I could and poured it into a U shaped mold, no coil at this time. I wrapped a coil around this core and tried to get it to lock but it did not work. Even if 5A of current is flowing through the windings, the core poles do not show any magnetism at all. If I pulse much higher current through the windings in a fraction of second, my pole identifier briefly sees the poles becoming magnetic. Unfortunately even at this high current pulse no lock is happening. So I don't think this whole resin mix idea works.
                Jetijs
                ......what kind of DC power supply do you use? did the mail come yet?...for the U core i used ferrite and epoxy like brucetpu...iwas able to get lock on my rig fairly easily....it does work.....david
                  It could be the materials are as critical as getting the metal hot and/or vibrating it during grinding.
                  I believe David also did clean the Galvanization off the mating surfaces.
                  As long as the flux has a good path to follow, you should get the pieces to lock and stay together at least well enough to get them taped up and zip-tied.
                  I would suggest putting each element in the coil and giving each of them a good pulse by themselves and then try and get the lock again. This could help orient the domains back to the desired patterns. Observe the same polarity in each case.
                  In Davids configuration, the flux should follow the path of 24 parabolic curves facing away from central axis all joined midpoint on the elements. So if the flux has any influence external to the element, the compass needle would follow the edge pattern of the elements if placed directly above them. In a well behaved system, the flux should stay within the material. External interactions could extract energy from the flux and cause it to lose lock.
                  I think failures outstrip successes at least 10:1 - and besides, Harvard's Law (Number 48 here) always seems to apply to machines whether biological or mechanical. Hang in there
                  leave the zinc on..
                    I have an adjustable voltage/current power supply that goes up to 30V and 20A. This is what I use when testing the electromagnetical properties of the core, I pass some steady current through it and see if magnetic poles appear on each end of the core. If when using steel I can put some 1-1.5A through the coil and already see strong poles appear, then using the iron powder core I can't see any poles and any attraction to metal at all even passing 7A of current through the coils. Of course there can't be any lock with such a material. If I tap a 12v battery with the coil leads for a short pulse, a much bigger current flows through the coil at that instant, and then some weak poles appear, but not strong enough to create a lock.
                    The steel pipe has not arrived yet, I will inform you as soon as I get it
                    Jetijs
                    • Whats that noise in between frequencies? What is it called?
                      • is there
                        is there a link?....
                        • David,
                          In the past when I observed a neodymium magnet drooped down a copper tube I was seeing a blue type of energy wave.
                          This was a few years ago and I do not recall the exact size copper pipe (1/2" or less) or the exact size or Gauss of magnet. Different compositions of neodymium may produce a different result as well.
                          Thought you might find that of interest to check yourself as it relates to your ability to see the waves off of your PMH.
                          Give it a whirl and see if you see the waves.
                          Then film it to see if you see them on the film as a comparison.
                          Examples of others doing this:
                          Strong magnet falling in a copper tube
                          YouTube - Strong magnet falling in a copper tube
                          magnet copper tube
                          YouTube - magnet copper tube
                          IndianaBoys
                          • Originally posted by Vickers View Post
                            Brownian noise - Wikipedia, the free encyclopedia
                            • Wondering????
                              Did this meeting take place today?
                              Originally posted by thekubiaks View Post
                              David,
                              Looking forward to meeting you Thursday, email sent. For those that are monitoring and experimenting with this discovery, please list what kind of tests you would like me to run and what questions you would like answered. You can PM me with the questions you would like asked as well as tests to run. Cheers.
                              • cat
                                no he had some business to attend to......saturday market will be good..a chance to let other people describe what they are seeing ...heat, vortex, pouring etc...i will try to get people on video, without prompts, to tell what they see or dont.......more schlieren soon...david
