gravity waves found
  • Broli, this works best with a steel that is magnetic and retains some magnetism after magnet is removed, I also tried this with non magnetic stainless steel tube cut in half, there is almost no attraction when the coil is pulsed and no locking and residual magnetism.
    Thanks.
    • Hi David,
      Was wondering if waves might show up better in vids, if a black light were present when filming, just a thought. Very interesting!
      Gene
      • Pulse Polarity
        Hi David,
        When you pulse the coil does it matter which side of the battery is connected first and which polarity is pulsed? And have you tried a coil made with iron wire?
        • Just remembered the mass effects that this guy talked about when
          bringing together equal poles of 2 magnets by force (@ 5 minutes)
          YouTube - Boyd Bushman Part 1
            as far as i can see and feel, because this wave must mimic IR light.this wave must absorb and radiate just like heat.Magnnetisim is a wave form so this new wave must do what magnets do.....i predict that this discovery will unify physics!!!!
            I AGREE. It's amazing stuff. I've been working on this all day and have only got as far as the shape that you're using - or that Leedskalnin used. It's brilliant. From what I see its actually also the same shape as cody used - Post 98 (I'll try and post a link here after this.) But by giving it that loop you actually increase the surface area available to enhance lthe attraction. Hence that 'lock' as you describe it which cody didn't get. It's given it a magnetic strength which is not available in Cody's.
            I wonder if Jetijs' configuration isn't perhaps weakened by the solder between the gaps? Just a thought? It may just change the magnetic distribution.
            I'm CERTAIN that this is gravity that you're identifying. But - in as much as it's an induced magnetic field there may be some current flow inside the material. Is there any way you could put an amp clamp around the structure and check this out? If so, then you've definitely got new physics there David. Really something remarkable. We all know that light bends inside a gravity field. Your light is doing all sorts of things. We know that weight distribution is determined by a gravitational field. You're finding anomalous weight distribution. You're also finding 'hot spots' which is proof that energy is being dissipated - but no evidence of a weakening of the field. These are EXTRAORDINARY results. Very, very interested in this - from many levels. I think it's VERY IMPORTANT that you try and get as many people to witness this as possible. Well done David. And many, many thanks for sharing it. Can't wait to hear more.
            • Hi all.
              Today I did not have much time, I only managed to cut a 90mm tube with 3mm wall thickness into 12 pieces each 5cm long. Then I sandblasted the rust off and sanded the outer surface of the rings smooth. Then I cut them in half and now I have 24 pieces. Tomorrow I will compress them a bit using a vice just like David did and put them on a rotating platform. Stay tuned
              • Today i got my ring to lock. Not as strong as i would have liked, but still it works now. I had to spend some more time getting the connections sanded flat. However i havent seen any effects from it. I tried crystals, metals, spinning and not spinning and still nothing Maybe its not strong enough yet, im sure it could get better if i spent more time on the connections. My other model using the pipe has taken a setback. The pipe mated together very nice when i cut the length sections, however when i cut them in half the heat from the cut distorted the metal enough that the connection isnt very good anymore. May have to not use the chop saw and go with something more like a hack saw.
                • Originally posted by broli View Post
                  @Jetijs is your steel magnet? ie does a magnet stick to it. The best pmh I've seen are NOT magnet including david's setup.
                  @David, have you tested this at different places, does the effect remain? Can you be really specific about the type number or so of the galvanized steel pipes.
                  I like your openness and impatience it means the truth will unfold fast.
                  @all, has anyone taken a magnet to coral castle and tested if the wheel was magnetic and/or affected magnets or others pieces of metal strangely. Call it on site experimentation . It may be that the wheel needs a pulse (however that's done) like a pmh to show its true self.
                  I think Ed's rig was definitely ferromagnetic. Most non-magnetic steels, like stainless, are made that way because of the higher carbon content which bonds to the iron atoms and prohibits Weiss Domain reorganization which is a crucial necessity of ferromagnetism. In other words, the atoms will not align with the induced H field. Another clue to this is that Ed's device rusts. Most non-magnetic steel do not rust. All metals, including Gold, will oxidize, but Iron is the most evident; possibly because of the red color.
                  Galvanized water pipes in the US are ferromagnetic.
                  The locking effect demands ferromagnetism in this application. The greater the permeability, the better the lock.
                  Q. Do we see evidence of a coil system on Ed's rig?
                  The stabilizer (concrete?) Ed used to surround his magnets could have had a three fold purpose (or more).
                  1. Prevent flexing of the magnets that could have resulted in loss of flux
                  2. Prevent ringing vibrations in the metals which would result in loss of energy
                  3. Add weight to increase the angular momentum of the rig when turned.
                  • The concrete might also hide a more complex pattern in the plates as they form the ring. They are 5-way stacked, it seems? Why not from one piece each?
                    Not impossible that they'd overlap pags and possibly also meet nearer to the centre axis.
                    A random thought I had, is that cold-setting the pipes or plates might even enhance the properties sought there. Atoms are alined there. With casting, you don't get that. Cold-set steel is known to be stronger than that of identical dimensions, CNC'd from a solid block.
                      I agree it's getting very interesting. Just to note as far as Jetij's build I'm fairly sure from what I saw that he welded the pieces together in his first setup shown here rather than soldered. So I believe the welds were on top (and possibly bottom too) rather than in between the pieces. I'm not sure what effect that may have but I do wonder if the material Ed used between the pieces had anything to do with the strength of the effects? It's been a while since I've read up on the Coral Castle stuff so I'm really not up to speed now. I will look forward to FuzzyTomCat's evaluation on this.
                      • i have only you to thank...and a curious mind!!..............david
                        • Hi Harvey, there appear to be no real "Coils" there to be seen in Homestead, only some loosely wrapped wire around what appeared to be old empty wine bottles. It appeared to be about 16 to 20 gauge, and did look like single conductor electrical wire of some type. There were several of those wire-wrapped bottles there.
                          But it is pretty hard to say if they were meant to be air-core "coils", or simply his way of storing the wire... or something else entirely we can't even guess at yet.. Why use a "bottle"? Maybe because something was inside it? Difficult to say.
                          One thing about Ed from all reports was, he used old automotive parts from junk yards whenever he could... So it is very possible that the multiple stacked bent steel bars were just because he had an available supply of something that happened to be that size.
                          But with Ed, who knows.. He was truly unique, and i almost will feel a bit sorry if his secrets are ever revealed (lol but that wont stop me from wanting to know them)... i've heard about Ed nearly my whole life; first from my Grandfather who was very interested in Coral Castle... He was a 32nd Degree Mason BTW; although i have no idea what the "connection" is, if any. He passed several years ago and i never asked him about the secrets of Masonry ("32nd degree" is actually far from "33rd", so he probably knew very little about it anyway). I mentioned that because some folks believe there is a connection between Masonry and Coral Castle, specifically that certain designs seen on the wall decorations of Masonic Lodges may show a "schematic" of the device.. But the evidence for this belief is pretty slim so far, imo
                          • Hi Jibbguy,
                            I have no doubt that Ed used a flywheel and a stack of magnets from the old 'Tin Lizzy' Model T:
                            Here is a fellow who has the original magnet charger:
                            Model T Ford Forum: Magnitizing magnets while on flywheel
                            Here is a place that you can by the magnets pre-charged:
                            Recharged Magnets
                            Here is a pretty good shot of an assembled flywheel:
                            Model T Ford Forum: Photos of 12 roadster Magneto and magnets with drill spots...
                            Does this look like the handle crank thing in the middle of Ed's rig only horizontal?:
                            Could Ed have been using this for EDM of the Coral?
                            I'm looking forward to the gravity experiments
                            • i know how he "transfered" this energy...
                              • Still to mention, that there was a interruptor at he Lizzy, what interrupted the Circuit once per Revolution.
