gravity waves found
  • Originally posted by Stealth View Post
    In the first couple of videos I could not see the distortion. Only after looking at some of his later videos did I finally see the effect. I found that for me, If I looked directly at the distortion, it would dissapear. I found that by using my periferal vision, I could see it more clearly. It may help some to use their periferal vision also when attempting to see the colors and wave like distortions. Good Luck. Stealth
    This is true.
    Peripheral vision is much more sensitive to motion and low intensity light. I tried this technique last evening with by little triple cylinder and blue light. I even put it right under a green fluorescent display of four hyphens (- - - -) all night long so that in the darkness, if there was any thing there perhaps I could see it or perhaps some distortion on the straight lined hyphens. But nothing
    I think I will cut them today and try to do a PMH lock on them. Perhaps putting some low permeability material in the gap . . . hmmm, copper is less than air - wish I had more supercondutor
    Well it may tell us something anyway.
    • hi spiral
      thank you for taking time to build your replication!!...as you experiment, you will discover that this a "force"....if you take a mirror and hold it at the equator, you will feel a repelling force....also, the fog or haze you see, is it like purplish?...i notice that glass takes on that the same haziness near the device....where do you live?.....any way thanks again for taking the time to replicate my device, and see it through to the point you have....my mail [email protected] again, many, many thanks...david
      • Originally posted by Harvey View Post
        Rather than leave everyone hanging - and since a picture is worth a thousand words, I thought I would put this up:
        Zoom Picture
        You will notice that in the first layer we have a single circle.
        In the second layer we have six circles around the first layer. A true circle can be plotted through the center of each of those circles using the first layer center as the larger circle center.
        In the third layer however, the real geometry emerges. Here we find that we cannot plot a circle through all 12 third layer circles. Some have a different distance from the group center.
        In the forth layer we learn that the geometry is scaling. From here on, it will be a larger and larger hexagon as noted by the RED line.
        Note that the Blue Line is an equilateral triangle. This is true of every layer from two onwards. You will notice that the number of circles for any given side of the triangle increases by one for each layer. So, the second layer has 2 circles on each side of the triangle, the third layer has 3, the fourth layer has 4 and so on.
        So in answer to my questions above, you now you know the unique geometry and why and also know that the circles will not fit nicely into a circle arrangement because there are gaps along the hexagonal faces and the superscribed circle.
        I forgot to mention the third layer does not double as one may mistakenly assume since the third layer doubles the second.
        But instead, we see a mathematical progression where there are always 6 vertices on the hexagon. Since each side of the hexagon represents an equilateral triangle, we find that the vertices are shared. So the formula for any layer is the six sides of the hexagon, times the quantity of circles for a side, minus six (because of the shared vertices).
        For example, on layer 1 we have two circles per side times six sides = 12 minus 6 shared vertices = 6 total circles.
        Sides x Circles - vertices = total circles in the layer
        Layer 2: 6 x 3 = 18 and 18 - 6 = 12
        Layer 3: 6 x 4 = 24 and 24 - 6 = 18
        Layer 4: 6 x 5 = 30 and 30 - 6 = 24
        Layer 5,000: 6 x 5001 = 30,006 and 30,006 - 6 = 30,000
        You may have noticed the other sequence as well. The number of circles for any given side is just one more than the layer.
        Sorry to have neglected this before.
        EDIT TO ADD:
        Pipe is purposely bundled in this configuration because it stacks very nicely hexagonally - too bad the yard hands didn't realize that here .
          Cloxxki, the whole purpose for this onepiece setup is that it has no gaps and thus almost no resistance for the magnetic flux flow. Channeling info suggests that the better and bigger the contact area is, the stronger the effect will be. So this will prove if this is indeed true.
          Harvey, this is some regular steel, not mild steel, it wont retain much magnetism, so it might be that precharging the V shapes using a custom PMH wont give a desired effect. So I thought that maybe adding little neo magnets between each V shape would do the same, like in the attachment. The flux will rather travel through the magnets than through the steel ark closer to the center. This way I can get the magnetic poles on the V shapes just like Ed has on his generator. Also I have seen that magnetized PMH flux also likes to travel through magnets, you can put a magnet close to a magnetized PMH and then break the lock by pulling one side of the steel bar off the U shape and sending flux through the magnet, then you can put the steel bar on its previous position and remove the magnet and the lock will still be there
          I haven't looked into the exact particulars, but I know there is a point where the length of the flux path plays a part in the total reluctance and the flux will simply jump out of the material and take the air path instead because it is shorter even though the material is more permeable. So this could perhaps happen in that configuration
          I was thinking that sticking magnets on the ends of the radials would essentially mimic Ed's arrangement, but the ring flux would not make the turns for a PMH lock and instead would be sucked into the magnet and that could mess it up.
          Now, if there was a tiny micro horseshoe on each end to essentially connect one V end to the one attached to it, a magnetic button could be between the horseshoe and the V tip and that would keep the flux inside and routed through a-la-David ring flux manner but using the entire metallic path (including the external horseshoes on each end). The buttons would happily coexist next to each other but the conjoined V ends would be a dipole, not a uni-pole as in Ed's case.
          • @Jetijs
            Ive just used some magnets to look at their pattern on an old monitor and with one magnet i got this pattern.
            With 2 magnets (same poles, so they are trying to push away from one another) side by side. I got this pattern.
            With 3 magnets (again all same pole direction) i got this pattern. Looks to me like equalatral triangles in the centre.
            Just thought id post this. It may help someone somewhere and maybe significant to how leedskalnin needed his magnetic field
            Adie
            Always thinking outside the box!
            ASUS M4A87TD motherboard
            AMD Phenom II x6 Turbo Core 2.8/3.3 Ghz Overclocked to 3.5 Ghz CPU
            RIPJAW 4GB 1600Mhz DDR3 Memory
            Gforce 9800GT 1GB Graphics
            Windows7 64bit OS
            20" LG LCD 1680x1050 Monitor
            • Hello everyone. I just thought I would post this again since I saw no response at all. There is a lot in these vids, 6 all together. Hope it helps
              Wrench76YouTube - The Secret of the Universe 1 of 6
              p.s. just click on the next vid at the end of each one
              • Earth's gravity
                Earth's gravity in HD;
                BBC News - Goce satellite views Earth's gravity in high definition
                Cheers,
                s.
                • These are from a talk show,a lot of interesting stuff about Ed and coral castle.It starts at 7:30 before that is about the Bermuda triangle(also interesting) . There are 8 vids on coral castle
                  YouTube - Bermuda Triangle & Coral Castle - C2C 7/14
                  p.s. how do I post multipal links?
                  • Originally posted by wrench76 View Post
                    Yup, watched them all . Was meaning to watch them again at some stage, now that i know a little more about Leedskalnin.
                    Originally posted by sturgeon View Post
                    Nice, im gonna have to see how this all pans out with my gravity theory. Thanks for the link.
                    Yup listened to that one too lol, This one is very interesting to listen to.
                    Adie
                    Windows7 64bit OS
                    • Originally posted by sturgeon View Post
                      Ive just read it and they are calling it gravity because its the height of the surface as its been squashed by centrifugal force (spin of the earth). This all depends on the depth of the earths crust which allows centrifugal force to squash/squeeze the earth by different amounts over the globe.
                      So gravity 'it is not', i disagree and yes it still coincides with my theory. Wooohooo!
                      Adie
                      Windows7 64bit OS
                      • @Harvey, thanks for the elaboration.
                        @Adie, wow, those patterns are so distinct, thanks for sharing!
                        It makes no sence. The 6-fold flux pattern that Adie's second picture shows, from 2 opposing magnets, that seems so pure and significant. Yet the Lambright device seems to have 4 poles. AND Ed has a 4-clover shape atop his magneto's.
                        If indeed Ed's setup that all opposing V-magnet poles locked together, against the natural flux path of the magnets, that might offer interesting effects? Who knows, all the flux may take the shorter route through the air in resentment of the opposing poles? Pure speculation.
                        Would someone be ready to put a 4-clover type second part on top of their replication? Or are the Lambight devices and replications too far removed from Ed's setup to even consider that route, with the wine bottle coil etc to go for a full monty Ed device?
                        A last thought for now : how would the image of a Lambright device held close to an old monitor screen look like? Or could the equatorial Lambright glimmer jump to the screen for interesting effects? Please be safe!
                        • Originally posted by Cloxxki View Post
                          Youve just given me an idea on this. Gonna come back with a diagram which may shed some light on it.
                          Adie
                          Windows7 64bit OS
                          • OMG guys, Cloxxki has defo just given me a great idea here (i hope)
                            I first thought of the idea to do a diagram and as i was doing it i realised something that shocked me. I maybe wrong but this is my thought....
                            Ed Leedskalnin has a device that makes 24 PMHs on his flywheel, but there is no metal bar that locks the points as we all understand the PMH's to have.
                            Gimme a few more mins to finalise my diagram and see if ive hit onto something after youve all viewed it.
                            BRB
                            regards
                            Adie
                            Windows7 64bit OS
                            • OK here it is... i used Jetijs image just cos its easy and i had the image editted already on my comp.
                              The double poles joined to one another force the magnets over to their corresponding opposit poles. In effect creating a PMH effect in each and every gap of each magnet. There will most likely be magnet waves all around but got no idea how they would look at this stage.
                              Am i right here?... have i found the missing link? i do hope so
                              Adie
                              Windows7 64bit OS
                                Thanx Wrench, I've watched these before - very interesting math especially regarding the pyramid angles. So many of us thought that slope was some malfunction of odd degrees turns out the Egyptians understood those special ratios very well, as do the Masons and no doubt Ed.
                                However - I saw a picture of Ed's immigration papers somewhere that had that number on it - . . .
