Trevor James Constable's Etheric Rain Engineering
  • #16
    Rose send me your address via email ill get some info to you, BTW Trevor is 84 years and knows of yours and Glen's work.
    OOO
    Ash
    • #17
      OOO
      Ash
      Ash - just email me the appropriate links. It's good. I can get it printed here. Thanks.
      • #18
        If you need more, I have an extensive file on FE and OU, and all other aspects of self sufficiency related topics. I could post specific related information upon requests. I can't post all of it,but most I can post here.I have orgone accumulators and cloudbusters and other related materials.I have been collecting information for over 20 years and have extensive files in my library. I am poised to start releasing some of it shortly. I just need to get it organized first. I have magnetic,gravity,electric,solar,hydro-electric,anti gravity,Aetheric,heat engines,hydrogen engines,air engines,mechanical engines,hydraulic engines,plus some I have designed myself. I have not patented anything I have designed or built, so I could opensource it. I have been waiting for the right time to release it.Some of the material I have is no longer available in print.Some I have purchased over the years from different sources. Some I will have to check before releasing to avoid any problems. Good Luck. Stealth
        • #19
          WOW Stealth. I think we need to duplicate your references and then clone you. This sounds great. I'll see if I can find a way to reach you off forum. I'll get back to you on this
          • #20
            If it's water related go to Air Wells, Dew Ponds and Fog Fences: Methods to Condense Atmospheric Humidity You will find almost anything you need to gather,store or make water available on a single family or entire communities. Some of these methods are being put into use around the world to secure fresh drinking water for towns and communities from South America,South Africa and Asia. Peru was the first to experiment with these due to lack of water.Some towns had to haul water for miles to other towns and communities. Now those communties can,not only supply themselves, but can actually haul water to other locations. Good Luck. Stealth
            • #21
              many thanks indeed Stealth.
              • #22
                Rose check out the cloud busting course on
                Panacea University - Home
                • #23
                  And of course Trevor's famous book, and a very good read
                  The Cosmic Pulse of Life, by Trevor James Constable
                  This book presents evidence that UFOs are mainly invisible and consist of both physical craft and living, biological creatures.
                  The author convincingly shows that our atmosphere is the home of huge, invisible living organisms that are sometimes confused with spacecraft when they became visible. Mr. Constable has photographed both types of UFOs with infrared film, some of which are reproduced in this expanded and updated edition.
                  Despite his bold leap into the future, the general public and official ufology have a hard time accepting the evidence. In more recent years teams of engineers and technicians in both Italy and Romania, unaware of Constable's earlier discoveries, obtained virtually identical infrared photos of UFOs, which were published in Italy.
                  In 1996, NASA used ultraviolet-sensitive videotape to record swarms of invisible UFOs that looked like Constable's earlier photos. Examples of these photos are also contained in this book. Also covered are earlier pioneers into important life energies that play a big role in this research, including Dr. Wilhelm Reich, Rudolf Steiner, and Dr. Ruth B. Drown. Recommended for those interested in UFOs and higher realms of physical reality.
                  Regards, Mike R.
                  • #24
                    Aetheric Rain Engineering
                    Here is a compendium of Trevor Constable's work on
                    aetheric rain making technology. Much of the material
                    is released for the first time!
                    Trevor Constable
                    • #25
                      Not just rain, we can expect periodic rain, clear air, bird chirping and better sleep . But, becarefull because we can easily get the opposite.
                      • #26
                        Be cool to call it what it really is ...DOR removal
                        • #27
                          Someone may claim that making hole in the sky is always DOR removal. I believe that DOR can be used to cast away cloud too. If it not accompanied with more bird around or other healthy effect, then it should be considered as DOR polluter.
                          • #28
                            I believe the studies of Reich and Charles Kelly my friend they have all the proof that its atmospheric self regulation and DOR removal, even Trevor says it returns the ether to natural pulsation.
                            Doing studies with drought conditions and DOR removal with a vacuum tube orgone meter is one way to emulate what Reich, Kelly and Trevor have observed. This is what we trust and will be doing.
                            Ash
                            • #29
                              orgone meter?
                              Ash,
                              Do you have details on that particular tube orgone meter?
                              • #30
                                Ash,
                                Aaron,
                                This may help:
                                Elementary Orgone Machines
                                Elementary Orgone Machines by Jon Logan
                                IndianaBoys
