Inertial Propulsion
  • #31
    Ford Gyron
    The Ford Gyron was a futuristic two-wheeled gyrocar first shown to the world in 1961 at the Detroit Motor Show as a concept car. One wheel was at the front and the other at the rear like a motorcycle and the car was stabilized by gyroscopes. The two occupants of the vehicle were seated side by side and, when the vehicle was stationary, two small legs appeared from the sides to support it. The vehicle was created for research and marketing purposes, with no intention to put it into production.
    Ford Gyron - Wikipedia, the free encyclopedia
    Al
    • #32
      Short youtube segments showing gyro-aether connection:
      YouTube - Gyroscope
      YouTube - Buzz Aldrin Gyroscope Demonstration
      YouTube - gyroscope ufo propulsion ? part2
      Al
      • #33
        More gyro-aether connections:
        YouTube - Ionel DINU - Experiments with Cylinders Rotating in Water
        YouTube - Example of SOUND GENERATED GRAVITY AND HARMONICS COUPLING
        Al
        • #34
          You guys are wasting your time using mechanical oscillators to propel objects. Even if they worked (none of which I've seen here are anything more than friction/vibration machines), the power to move them forward are too large to be of any practical use. If any of them were practical, the results would be OBVIOUS, not just some questionable feeble motion.
          TESLA used electrical means to propel his crafts, he is the one that discovered the most efficient (and enormously overunity) means of using electrically transferred momentum to move objects of any mass at practically ANY speed without concerns of g-forces on the occupants.
          The ratio of electrical force to gravity is about 10^40!
          That means your gain in energy is 1:10000000000000000000000000000000000000000 !!!!!
          To put this simply, you use the power of a single LED to raise a mass the size of say this...
          Mount Everest... then you collect the energy on the way down from gravity and you could power ANYTHING.
          William Lyne lays it out very well in his book Pentagon Aliens.
          There are no aliens or alien technology. There is only Tesla science and this is what all these UFO's use that are ALL ran by the corrupt HUMAN secret government running this planet. There are NO aliens.
          They don't use gyroscopes to propel these ships but Tesla electrostatic momentum transfer technology.
          All the rest is just nonsense to mislead you into fruitless pontifications and endeavours.
          • #36
            If you say so...
            Vtech
            General D.Eisenhower
            http://www.nvtronics.org
            • #37
              Originally posted by elias View Post
              Inertial Propulsion is apparently not needed anymore:
              Keshe Space exploration
              Keshe foundation
              Apparently not, however the Earth still travels on "ellipsoid spiral" and the Universe is not at standstill.
              YouTube - Earth Rotation & Revolution around a moving Sun
              In the "Iran is Building 'Flying Saucer' Technology! Part 2" William Alek interviews Mehran Keshe, it passes quit quicly.
              Vortex Network News
              Al
              • #38
                Vortex Network News
                Al
                Thanks for the link I'll listen to it.
                http://blog.hexaheart.org
                • #39
                  My X is an alien. We definitely have out of this world conversations.
                  • #40
                    I believe Edwin Gray hinted that his technology can be used to create inertial propulsion WITHOUT any of the electromagnets moving!
                    YouTube - E V Gray 1986 Promotional Video Part One
                    If you watch this promotional video from the 1980s at about 7:30 they show a drawing of a space craft with a series of electromagnets stacked in two groups. They are drawn as alternating colors. I propose those alternating colors are alternating polar alignments of the individual electromagnets that make up the series array of electromagnets. The inner two have the same alignment, as do the next set out, and the outer sets... but the individual sets are in repulsion. If done right, the outer field will cavitate around the middle, and that around the inner, and the inner and outer fields are the same. I propose this is also the configuration of the Egyptian Djed pillar type devices from the ancient times, drawn with alternating bands of color representing the alternating magnetic fields.
                    Eelectro-Magneto-Hydrodynamics?
                    • #41
                      Hi SuperCaviTationIstic, thanks for sharing the information.
                      Any way you could explain more how this djed propulsion idea could work, like a drawing or something.
                      I also feel that the djed is a technological device and an individual once pointed this out to me in a very unusual way and circumstance.
                      As if this individual was possessed by some other influence, to show me that the djed has significance.
                      The manipulators of this world it seems do not want people viewing certain egyptian glyphs, as they must contain valuable information that we can use.
                      Grebennikov CSE (cavity structure effect) effect is also interesting.
                      He said the honeycomb structure created levitation effects.
                      That is interesting considering a pyramid shape causes an energy field to emanate or accumulate.
                      Victor S. Grebennikov: Insect Chitin Anti-Gravity & Cavity Structural Effect (CSE)
                      peace love light
                      tyson
                      • #42
                        From page 48:
                        Look carefully as the wheel precesses and see
                        if you get the same unusual physical experience
                        as I do. Things just don't behave like that . The
                        gyro weighs over 40 times the tower weight, yet
                        the wheel precesses around the tower, not the
                        light tower around the wheel, as elementary
                        mechanics would suggest or require that it
                        should. Let us assume that friction between
                        tower and bench is responsible for this effect and
                        repeat the experiment with a tower base set in
                        ice and free to slide on melting ice, when the coefficient
                        of friction is about 0 .02, and let us use
                        an old-fashioned wheel made of lead (over 400
                        times the mass of the tower) . Still the tower
                        hardly moves, yet still we might be deceived, for
                        if true it should be possible to start the gyro from
                        one end of a diameter and catch it at the other,
                        thus displacing mass through space . Once displaced
                        it would be a relatively simple matter to
                        push it back again by ordinary mechanised
                        means and thus progress the experimenter in any
                        chosen direction
                        Let us repeat the experiment with a much
                        larger wheel (18-lb mass on a 6-lb shaft) on a
                        stand, as shown in Plate 4.9 . If I release the wheel
                        from a position where its axis is horizontal it performs
                        curious dipping motions called 'nutations',
                        as illustrated in Fig . 4.7. These are the
                        equivalent of transients in an electric circuit that
                        occur on switch-on . The nutations soon die out .
                        Now it costs but little effort to stop the precessing
                        wheel, large though it is, for its momentum
                        is only apparent, and to lift the shaft through a
                        fraction of an inch stops it dead .
                        If I now set it precessing again and apply
                        torque to the shaft to try to increase the precession
                        rate, you will see the spring beneath its
                        central pivot block (see Plate 4 .9) expand
                        momentarily
                        This is Inertial force deviation propulsion system !
                        Welcome to force
                        Al
                        • #43
                          The following is from:
                          3.Composition rotating coordinate system
                          1.The turning coordinate system
                          If Mr. B moves more complicatedly , delay condition of watch of Mr. B becomes more complex.
                          And, the complex delay of time causes inertial force deviation.
                          2. Rotation in turning coordinate system
                          This is inertial force deviation.
                          Force difined as two times differentiated deformation.
                          A force made of small time differentiated becomes big.
                          And Mr.B feels a sum of force direction to down in this figure.
                          We set up as spin direction of gyro in plus to express equation simply.
                          In this case, downward the direction of thrust.
                          3. Composition rotating coordinate system
                          Each term of this metic includes "T" .
                          This shows that the space-time on gyro is vibrating .
                          Stare at this metric !
                          The space-time on gyro looks like gravitational wabe aren't you?
                          Now we guess a activity matter of inertial force deviation propulsion system as gravitational wave !
                          Al
                          • #44
                            Hi Al!
                            This was also my line of thought too, at one point I decided to build a unit exactly like the pictures you have posted, but I thought that it might not work and I went onto other projects.
                            I couldn't understand the difference between "rotational movement" & "transitional movement, actually.
                            Can someone explain the difference between the two?
                            Is a force exerted by a spinning gyro rotational or transitional? that is if the force exerted by the gyro is rotational, rotating it will not lift the unit posted above up, but it will make it rotate, and balanced gyros shown in the figure will cancel each other out, and no movement will be seen.
                            But if there is a transitional component to the force exerted by a gyro, then yes that would fly.
                            Elias
                            • #45
                              To confuse the issues here are some interesting facts:
                              How Fast Are You Moving When You Are Sitting Still?
                              Daily Motion {0.3mi/sec}
                              To make one complete rotation in 24 hours, a point near the equator of the Earth must move at close to 1000 miles per hour (1600 km/hr). The speed gets less as you move north, but it's still a good clip throughout the United States.
                              Yearly Motion {18mi/sec}
                              The full path of the Earth's orbit is close to 600 million miles (970 million km). To go around this immense circle in one year takes a speed of 66,000 miles per hour (107,000 km/hr)3. At this speed, you could get from San Francisco to Washington DC in 3 minutes.
                              The Sun's Motion {12mi/sec}
                              Relative to the local standard of rest, our Sun and the Earth are moving at about 43,000 miles per hour (70,000 km/hr) roughly in the direction of the bright star Vega in the constellation of Lyra. This speed is not unusual for the stars around us and is our "milling around" speed in our suburban part of the Galaxy.
                              Orbiting the Galaxy {134mi/sec}
                              It takes our Sun approximately 225 million years to make the trip around our Galaxy. This is sometimes called our "galactic year".
                              How fast do we have to move to make it around the Milky Way in one galactic year? It's a huge circle, and the speed with which the Sun has to move is an astounding 483,000 miles per hour (792,000 km/hr)!
                              Moving through the Universe {361mi/sec}
                              And how fast is the Milky Way Galaxy moving? The speed turns out to be an astounding 1.3 million miles per hour (2.1 million km/hr)! We are moving roughly in the direction on the sky that is defined by the constellations of Leo and Virgo.
                              ASP: How Fast Are You Moving When You Are Sitting Still?
                              Al
