Originally posted by ren
The way I look at it is that when a permanent magnet is passed over iron repeatedley, the iron gets magnetized more. The more you pass a magnet over it, the more it gets magnetized.
Now, if we have a coil of wire wrapped around the iron, everytime we pass a magnet over the iron a voltage is induced in the coil. So every time we pass a magnet over our iron-cored coil the induced voltage increases. It's like the coil is a capacitor.
With a capacitor, when we short it out, the more the capacitor is charged, the more of a "crack" we get.
So my theory is that you should abrubtly discharge the generator coil once per revolution to get the best effect. Since it's also a bad idea to charge and discharge a capacitor (or battery) at the same time, you have to discharge the generator coil in between magnets - otherwise it creates drag.
Remember too that JB's FEG had 6 generator coils hooked in series. He did only discharge once per revolution, but for just less than half of the revolution. Here's where the flywheel comes in I suppose.
You only need enough potential on the back-pop to get the ions in the battery to move themselves, aka "in re-charge mode". Once/rev should be enough of a kick in the pants to keep the battery in re-charge mode always.
But here's the kicker, if you impedance match your primary battery to the load then it doesn't even think there is a load on it, therefore the primary is always in re-charge mode...
John K.
