  • Originally posted by xee2 View Post
    My understanding was also that FETs did not need much gate current to work. However when woopy is buning up gate resistors that would not seem to be true. And, in my circuits there is a definite increase in drain current when the gate resistor value is lowered. These FERs seem to act more like transistors than a classical FET.
    The IRF 530,630,730.830 work while the IRF 640,740,840 do not work. I have looked at the data sheets and I do not see what it is that is different between the 30s and 40s except the power. But it might be a gain difference. Please let us know if you figure it out.
    The "Gate Current" is the momentary charge and
    discharge current associated with the Gate Capacitance.
    To turn the MosFet "ON" the Gate Capacitance must be
    charged to a voltage higher than its Threshold rating and
    to turn it "Fully ON" will generally need to be charged to
    10 Volts. There are exceptions in that some are "L"
    or Logic devices which will turn nearly fully on with 5 Volts
    of Gate charge.
    To turn the MosFet "OFF" the Gate Capacitance must be
    discharged to 0 Volts.
    Internal to the MosFet is a protective diode between the
    Gate and Source leads to prevent the Gate Voltage from
    going too high (about 18~20 Volts) or from reversing polarity.
    It is very difficult to drive a MosFet with any appreciable
    series resistance in the Gate connection which would
    excessively prolong the Gate Capacitance charge/discharge
    time constant. A Gate resistance of about 50 Ohms is often
    used at high frequencies to limit Gate current magnitude and
    to dissipate power that would otherwise have to be dissipated
    within the Gate Driver chip.
    For best performance a MosFet should be transformer driven,
    with adequate protection against polarity reversal, or driven
    by a Gate Driver Chip. It is also possible to use discrete
    transistors configured as a Totem-Pole for the needed
    Pull-up and Pull-down of the Gate input.
    Once you learn the "tricks" of getting the MosFet to
    respond to its input signal you'll be able to make it do
    everything that you want.
    The higher the Drain Current rating of the MosFet the
    higher the Gate Capacitance. High Gate Capacitance
    demands more charge/discharge current to turn the
    MosFet ON and OFF.
      My 1" diameter coil is 1.5 MHz and my 3" diameter coil is about 0.5 MHz.
      @xee2
      thanks
      • Hi xee2 and all
        My last test shows that i can get very good lighting of CFL with the BUZ 11 under 12 volts.
        But i have to mount 6 x 0.25 watt 2200 ohm resistors in parallel. That is to say the equivalent of one 367 ohm and 1.5 watt resistor. And those resistors get hot anyway , so more would be better
        So far i know the FET are piloted by voltage and not by current , so why do i need to to have so high wattage in the gate?
        Thanks for answering
        good luck at all
        Laurent
        • Originally posted by woopy View Post
          Hi xee2 and all
          good luck at all
          Laurent
          @ Woopy
          I have put over 1 amp through the IRF530 FET using a 1/4 watt 51 ohm resistor. The resistor did not get hot but the FET would get hot if I did not use a heat sink (was OK with a small heat sink). FETs are strange. I ordered some BUZ11 FETs to see what happens when I swap the IRF530 for a BUZ11. I will post results.
          • So far i know the FET are piloted by voltage and not by current , so why do i need to to have so high wattage in the gate?
            The only way to truly know what is happening with
            a MosFet is to "scope" the Gate signal.
            Without an oscilloscope it is very difficult to diagnose
            the source of "strange" performance.
              @ Woopy
              I have had similar results Xee
              My IRF 730 over heated a few days back on my 6V battery at 0.2A . Im using a quarter watt resistors and sometimes half watt resistors, and they never get hot. My FETs get hot on any batteries above 1.5V!!!! But they can light CFLs easily and on low watts.
              • Originally posted by seth View Post
                I assume you mean 1.5 volts in a cell phone charger. I have never been able to get my FET circuit to work with just a single AA battery unless it was in the cell phone charger.
                • Hi SeaMonkey
                  Thanks for your advice, I have a scope. What are your recomendations for the probes place.?
                  @ Xee2
                  Good idea to test the BUZ 11. We will see if the results is depending of the fet or the complete config or probably both.
                  good luck at all
                  Laurent
                    Yes - i also havent been able to use a FET without the mobile charger. TIP 31 works on just 1AA, but FETs needs 1AA and charger.
                    But i'll keep trying.....
                    • hi all
                      going on working and studiing the MOSFET
                      and good results
                      so confirming that, with my set up, only the BUZ 11 works (i have not yet IRF 530)
                      i have also tried a big IRF P 450 and no chance.
                      I have begin to study all data sheet, so i become slowly more and more intelligent, but not enough yet to get all the subtility of those info.
                      So no other way to go on the terrrrrifffffic but fantastic way of trial and error
                      But i like, because it is so surprising and motivating.
                      OK so it seems to work with the Xee2 circuit and different capacitors and BUZ 11 and different resistors with very different results.
                      1- if you put no capacitor it works too. But in this case, if you approach the cfl very near from the L1 coil the lighting goes down , and if i touch the L1 with the cfl , the lighting stops and the current jumps as if it is a short cut in the L2.
                      2-Higher the resistor value = smoother the reaction.
                      E.G with arround 500 ohms i can get good lihting up to 12 volt and low A draw, but no or very low plasmajet at the end of the free L1 wire.
                      and at 100 ohms resistor the power is huge (see pix 1 and 2) where i put a 100 ohm and (probably 5 watt ) resistor., the lighting is very good and the plasmajet is at max for what i have got until now.
                      so for 14 volts, and 1.2 A (that is to say 16.8 watts), i can get the lighting of the pix ,
                      plus the heating of the fet and resistor and in bonus a strong and noisy 2 cm strong plasmajet.
                      So far very happy
                      and good luck at all
                      Laurent
                      • I received the BUZ11 I ordered and it does not work for me. I have tried many different L2 coil designs and several resistor values. The FET turns on and draws current but there is no oscillation.
                        • Wrapping your head around "theory"...
                          I certainly understand that, Woopy...
                          The spec sheet idea came up when I was studying a basic book of electronics... I'd read parts of it over an over again but never could grasp it until I started working with SECs. Working with the SECs introduced me to an area of electronics I had no concept of. So when I was reading my book I began to understand better what was being done because I'd already had some practical experience in the area -- just no professional terminology or theory to relate it to. It related the concept that FETs were better than transistors because of their high-voltage rating and low-current rating. I was thinking, "I wonder what FREQUENCY they operate at?" so I was looking for frequency in the datasheets. There isn't a lot of data about frequency but the switching times really indicated to me.
                          Studying this stuff is definitely hacking knowledge. You just have to keep doing it over and over again until it finally "clicks" and you really get it.
                          My current "beasts" are inductance and resonance... I think those could be the key to OU...
                          Take Care,
                          Mussle
                          • On my set up another curious result is that TIP 31 works with or without the toroid, when the CFL/neon is either near L1, or touching L1.
                            With FETs I get NOTHING without the toroid, even if i connect the CFL/neon to L1. They only work with the toroid, and they work even better if i increase capacitance with a metal sieve under the toroid.
                            Anyone else see anything similar?
                            Ive just bought 20 FETs (530, 630, 730, 830) and 10 new TIP 31s, and 20 IN4148 diodes - this weekend ill be joining you woopy on trial and error
                              I gerally get better performance with a top load. But most of the circuits I have made will work without a top load. I think it is a function of the L2 coil design.
                              • No problems just needed sleep
                                Originally posted by Jiffycoil View Post
                                On this recent change of setup I had to adjust the primary up and down in slight increments until the coil started to work. Once that was done its been running. I think this current setup is having a few physiological effects on me. After running it my eyes burn and I have a slight headache. I don't normally get head aches and there is no noticeable ozone to cause my eyes to burn.
                                I need to post this because it's relevant to our experiments. I have not had a headache nor burning eyes since that night. I must blame it on the three nights in a row in which I only had 3 hours sleep each night. After reviewing my journal that is more than likely the reason.
