I have one of the cell phone chargers coming and I want to see how efficient at transferring energy I can make my setup using low voltage. From what Ive seen from the others guys they get great results.
I hear you mate!Originally posted by Jiffycoil View PostI have one of the cell phone chargers coming and I want to see how efficient at transferring energy I can make my setup using low voltage. From what Ive seen from the others guys they get great results.
Looked at 2 mobile phone shops today and neither of them had the 1AA chargers...only car chargers. I figure if 1AA can light a 14W CFL wirelessly without the charger, perhaps with the charger we get OU - but im an optimist
always have been.
@all
have you folks check this place.. is this a good deal or bad..
Emergency 8 in 1 Cell Phone/MP3 Charger-The Electronic Goldmine
hope it helps
robbie
Heres my exciter working on 1AA with an emergency charger. Only seems to work a bit better than without the charger.
YouTube - 1AA exciter with charger
Still, all improvements are always welcome!
Armatures and pulse Motors
New updates
PULSE MOTOR, FREE ENERGY & OVER UNITY
Pics Of Places & Things
Hi folks...
I just finished my Joule Thief CFL circuit with good results and posted the info on the "Big Joule Theif" thread. Now I'm on to SEC land and I was so surprised with what I saw I had to throw a circuit together.
I made a video and posted it:
YouTube - anonymussle's Channel: Anonymussle's CFL Tree
Thanks much you guys for all your hard work. It's really amazing the stuff you can do!
Anonymussle
You're right... I took them out and nothing happened... CFLs go on CFLing...Originally posted by xee2 View Post
Nice video. Will removing the 1M resistor and capacitor makes any difference? I do not see how they can be doing anything.
Using two AAs, 1watt and 9watt hanging by my desk at the moment...
Hi all,
I have spent quite some time analysing Gray, Puharich and Meyer's systems. Turns out they all use the same principle. See my article over at Peswiki:
Article:Free Electric Energy in Theory and Practice - PESWiki
Since you guys are working on SEC exciters and variants, you may want to take a look at my post over here and see wether or not my theory can be experimentally verified:
You can find the attached pdf with my proposed schematic here:There are multiple versions [of the SEC exciter], this one needs an adjustable coil. IIRC, there is also one which does not need that and is tuned with a variable cap. So, based on this one, you find the schematic attached which I had in mind. I didn't draw all the decoupling caps, etc. but you get the idea. Just switch it on and off using a 555 timer or something like that. If this SEC circuit starts fast enough, I think this should work.
I also drew a comparison with what Gray was more or less doing, so you can see the similarities. If I finally understand this right, with Gray's stuff, you would need a bifilar wound coil or two identical coils in series (as you see with Meyer and Puharich, but for different reasons), because he drives both terminals in phase. With an AV plug, you should not need a bifilar wound primary, so this should work.
Gray used a spark gap oscillator and this is also an oscillator, but one that is much easier to build, tune and control. And because of the ultra wide bandwidth of Doc's circuit, this is about as close as you can get to a real spark gap oscillator with modern electronics.
I have drawn the couple cap before the AV plug, but it may be that you need two couple caps and place them after the AV plug, more or less as I have shown with the Gray equivalent.
So, it will be interesting to experiment with this circuit and make your own variations. It is very similar to what Gray did and with this we will at least get some answers to some of the questions that remain. And with a bit of luck, we hit the jackpot straight away.
So, have fun and happy hunting to all of you!
-- Arend --Last edited by lamare; 09-07-2010, 07:12 PM.
