Gravity - just pure plain GRAVITY
  • Aether Fluid versus Ocean Fluid + How-to Make Dial-up Gravity Boot Material:
    Aether presses down on matter, holding
    • The 4th Dimension? Not by chemical alchemy but physical alchemy.
      obtain the desired mass~density change zzzzzzzzzzzzzz
      • Aether = Creation Ramming Speed forming times of solar systems would need readjusting
        being that these
        • Why are most "stable" things in the universe either a sphere or a ring?
          What "force" separates elements of varying density in a centrifuge?
          Why do planets spin faster at greater orbital distances?
          What determines the orbital spacing of planets(and does anyone feel a twinge of ridiculousness when they show CG planets "colliding" in mainstream science periodicals?)
          By what principle are living organisms growing upward and overcoming horizontal equilibrium?
          Why do clouds "float"?
          • harness the power of aether we could repel all incoming meteors and asteroids
            • Great questions!
              We don't know anything, we can only observe what happened in our environment and try to model or theorize them.
              What has been a curiosity for me is the action of "rotation" or "spinning", what is it? I have looked at it as the dancing of existence. Rotation is still a mystery I think. And most of the questions you asked is related to this phenomena. Rotation has something associated with it which is called the Centrifugal Force (What is centrifugal force?)
              I suppose that because the basis of existence is rotation and a mysterious force named the centrifugal force is associated with it, makes stability in "round" (rotated) objects. Maybe rotation is a key component in oneness.
              This is a mystery, and I feel sorry when I see that it is called a Fictitious Force (http://en.wikipedia.org/wiki/Fictitious_force).
              I think that rotation causes the aether to push elements outward.
              The centrifugal force causes the most dense to be pushed more outward, so one should ask if Earth is rotating, then why is it thought that the most dense is at the core?! This may confirm the hollow Earth theory.
              I ask you a question: Why do planets spin?? And orbit?? I don't know.
              Stan Deyo has an interesting video explaining this phenomenon. You can find it at peswiki.com. What this is is the same thing causing the planets to orbit.
              Victor Schauberger has talked about the levity force, which causes this to happen. Living organisms have the capability to utilize this force. This may be the upward push of the Aether. (Dan Winter has interesting theories about this)
              I had never thought about this, I am glad you brought this to attention.
              Maybe there exists a some kind of Aetheric force which does this. This reminds me of Wilhelm Reich's work, which describes clouds as concentrations of Orgone (Aether) Energy. (The Cloud Buster)
              Some interesting thing about rotation, is that it is not relativistic. In other words, it has a point of reference (May be the Aether), otherwise a spinning object would not have the Centrifugal Force acting in it. So there is an "absolute" velocity when we spin an object, and it is not like the velocity it travels space at all, which is not absolute and it is always relative! So rotation is something that has not been understood clearly.
              Elias
              http://blog.hexaheart.org
              • Girls like them <> maybe girls make clouds.
                Clouds floating is probably more than
                • adds to all the other
                  • Anti-Asteroid Aether Weapon <> also would repel incoming meteors (ICBM missiles?)
                    zzzzzzzzzzzzzzzzzzzz
                    • See upper two sets of 9 See lower two sets of nine:
                      • I thought Tesla was refering to frequency and harmonics with this statement. As in chords and tripplets etc, like what Keeley was doing, not so much about the bible and creation.
                        Cheers,
                        Steve
                        You can view my vids here
                        http://www.youtube.com/SJohnM81
                        • Everything in the universe is in perfect harmony. To get OU or FE from our machines, we must break this harmonius cycle. When something is out of harmony in frequency, or resonance, it causes the forces of aether to intervene to bring back these into a harmonius cycle. So the aether is the real energy we are trying to capture to use as our workforce. Only through out of balance inharmonius machines do we have a chance of capturing some of the aether to turn our wheels. Good Luck. Stealth
                          • Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
                            • the future would have to
                              • The hexagon is basically the middle section of two intersecting triangles. Now hexagon is not a solid structure, an equilateral triangle is. Good example is kid toys with metallic ball joints and magnet rods between them. Any other structure will flex but not the triangle. Also the the tetrahedron does not flex but a pyramid does, until you make it to a octahedron, again surrounded by triangles.
                                I think nassim haramein is not far off with his stuff. About the numbers I'm not sure yet, but I think there is lot to be learned from the 10 numbers we use. It's just a matter of perspective. I think aromaz is on the right track and three is the beginning, but it seems to me 9 sits in the middle of these two separating chains as well as zero sits in between of all, 6 is the reverse.. Oh well, I guess it's easy to mess your head with this stuff
                                I like to think of it the following way:
                                6
                                9
                                7 4 1 3 2 5 8
                                0
                                [edit]:
                                or maybe more like this: can you see the 3 triangles forming?
                                6
                                9
                                3
                                7 4 1 0 2 5 8
                                Tetrahedron is formed by 3 triangles, fourth side is the byproduct. Just one idea I've been playing with, not trying to claim anything as I don't have the sufficient data or knowledge.
                                PS. interestingly after mentioning octahedron, one is formed between two intersecting tetrahedrons in a star tetrahedron. Consisting of 6 vertex points and 12 edge vectors. These are the repeating patterns that can be found in fibonacci sequence and its mutations for example.
                                Anyway, if it's helpful feel free to use it, if not, just drop it and move on
