  • Originally posted by dunfasto View Post
    fabrice andre used caduceus coil.
    dont get confused with cw ccw coils.
    cw coil has NS poles
    cw ccw coils have either NSSN poles or SNNS
    similar poles facing each other acts as caduceus cross over or nodes.
    for overunity one coil must be cw+ccw or caduceus(the better) which create electron avalanche. other coil is cw which is output coil.
    electron avalanche can be produced by either 50 hz or high frequency +high voltage AC or pulsed dc but the coil must be cw+ccw or caduceus.
    suppose we want 50 hz as output then fab andre long litz coil must be caduceus and modulator coil must be cw coil and so is output coil(cw).
    and suppose we have high frequency hv ac in long litz wire coil then modulator coil must caduceus and output coil must be cw.
    one coil must be caduceus then modulator cw and vice versa.
    one coil must produce electron avalanche.
    when using cw+ccw coil then there must be a gap where the joint is so ferrite core are arranged as 00000 gap 0000
    when using caduceus coil as primary hv ac or pulsed dc( cap charged spark gap like chubinidze) the ferrites must be arranged as continuous tube like this 000000000000 over which caduceus coil is wound as primary. and over caduceus coil wound modulator coil and output coil.
    case dally: the RG58 coaxial cable is cw+ccw(magnetic cancellation coil) which produces electron avalanche
    case akula: 50 hz coil wound as cw ccw in two layers produce electron avalanche.
    case sr 193: he used jointed cw+ccw
    case chubinidze : he used caduceus coil(resonator)
    NOTE:
    1. WHEN USING PULSED HV DC TO FEED PRIMARY CADUCEUS there is no need to modulate it with 50 hz in oscillator of high frequency.
    2. when using high voltage high frequency Ac feed to caduceus then the modulatore coil(50 hz) must also modulate the high frequency oscillator by winding few turns say ten turns on ferrite core of flyback along with the oscillator coil fed by transsistor. 50 hz live wire from generator of 50 hz(amplified) wire-----------ten turns hv ferrite------modulator coil(cw wound over caduceus)-------to neutral or cold of 50 hz.
    dunfasto
    Hi Dunfasto.
    I admire your tenacity, but Now I KNOW you do understand what you are writing about in this thread.
    This not only regarding your proven lack of comprehension regarding circuitry, but now also your understanding of fundamentals regarding induced magnetism, and especially the caduceous coil which is so not the same as CW+CCW arrangements.
    Hendershot used CW+CCW windings on his tin can (ferrous) sleeve.
    The true purpose of CW+CCW, or for using a caduceous coils is to induce a magnetic vortex, and in this regard Hendershot used an extra centre winding energised via a series connected phase shifting capacitor to induce field rotation.
    It is the magnetic field vortex which leads to electricity generation, and not as you imply !
    Also CW+CCW is not a magnetic cancellation >
    *** it is more like a magnetic spring ***.
    After creating the magnetic vortex, this arrangement can return unused electromagnetic energy back into inductive drive/load circuitry.
    Within a caduceous coil the fields at the 90 degree crossover points still add axially, as both are in the same winding sense; ie. both are at 45 degrees with respect to the longitudinal axis.
    Where the caduceous is different is that it is more like a 'magnetic end fire' device when it comes to impulse energisation, or to field alternations tuned with respect to the length of wire used; which is why its may be manually adjusted (essential) inside another winding to induce a central magnetic field vortex region.
    Fabrice Andre clearly understands what he is doing with his caduceous coil, but caduceous coil energisation is not essential.
    And 50Hz produces an electron avalanche ?............... ???
    Cheers ........... Graham.
    • Originally posted by SERG V.
      For transformator T1 on big ferrite ring. Use here ferrite yoke from TV or MONIT.
      Coil 1 and 2 24 Windings 0,4 mm wire in silk isolation. Both wounded in same time
      Coil 3 60 windings over coil 1 and 2 with same wire.
      Coil4 600 windings 1mm diameter aluminium wire over coil 3
      T3 used was rewounded to input 400V ac(rms), output 230V (fisrt secondary) and 18V (for self-powering) second secondary.
      T2 ТДКС - Flyback from TV Юность (TV youth). Has inner voltage multiplier so output about 20-25kV. Need for Static Field.
      Сhoke or inductor (most upper transformer on sch.).... have 2 capacitive coils. Wind it with 2 wire in same time with 20 windings (diamеter higher than 1mm in good isolation). It's kind of capacitor coil. Experiment with number of windings to get godd output on your Ferrite yoke coz you can't find Original ferrite ОС-90.29ПЦ32.1.5.
      Both coils were placed over TV yoke ОС-90.29ПЦ32.1.5. Try ferrites from old CRT monitors or TV sets.
      Both Transistors Sanyo 2SС2625
      That is a much better circuit diagram than one shown earlier Serg.
      Apart from the circuit and the capacity hat, operation here depends upon the *length* and *coiling* of the *earth* wire.
      This is a resonant device relying upon the different time periods of equalisation effects for relative positive/ negative charge carriers in the atmosphere.
      Also, these 'capacity hat' devices are ILLEGAL because they are *via that length of earth wire* electromagnetic radio transmitters being operated without a government issued licence.
      Thus ALL of the electronic equipment of such a constructor, as well as his generator, becomes radio-direction finder locatable and confiscatable by the government, with the constructor subject to arrest, with future Court appearance and fine/ jail !!!
      Imagine what it would be like if every house had one of these,
      the government propagandas would simply not get through the noise to TVs and radios !
      We need here to concentrate on the non-EMF radiating equipments, as per the Hendershot generator which could operate a radio.
      Cheers ................... Graham.
      PS.
      ***Show these generators running an AM Broadcast Band radio to prove they are not illegal transmitters***.
      • Well, you should use shielding and recall what Tesla said ! Only 5% lost on radiation, easily shielded. Look at Kapanadze, special plastic needed (well not special but correct one, not very cheap one)
          Shield enclose the Dunfasto/ Serg circuit ?
          or any Tesla capacity hat device resonating against Earth ?
          won't they stop functioning with respect to ambient because they will couple with the shield ground ?
          Besides, spark initiated longitudinal emissions go through shields anyway ! (Old Scientist YT videos.)
          Don Smith did not do this, and so many contributions in this thread have been total distraction from his design.
          If Don's missing part was an inner ferrous sleeve core, whether ferrite or iron pipe or sheet steel etc., then his device released energy in the same way as Hendershot's, where I hypothesise that a caduceous or CW+CCW induced magnetic spin vortex induces a so called 'electron capture' within iron atoms, where the truth about 'electron capture' has never been properly explained/ taught.
          This untaught aspect relates to the additional emission of an *Auger electron* along with the beta particle.
          Now Serg correctly warns us that beta particles represent a radiation hazzard for living beings.
          That is a fact, but how do we tell whether any radiation is either beta or gamma when using a geiger counter ?
          Do we not insert a thin section of aluminium between the source and our geiger tube ?
          The aluminium will block the beta, but not the gamma.
          Is this not safe ?
          And yet the aluminium is NOT blocking the passage of the beta particle - *** it is transducing it ***.
          Just as the aluminium foil around the Hendershot core ...........
          Just as does the outer copper windings of the Don Smith device,
          and Kapanadze, and others.
          Tesla electrostatic capacity hat technology is a distraction !!!!!
          Did Tesla use that to empower his electric car ?
          • Tesla is the True Master of Electricity
            There are two ways Tesla do on his system.First, the freely oscillating circuit( Induction Heater) the very well known Auto Resonance LC tank circuit . Second, The Controlled Amplification Resonance which is always cited on all Tesla patent when it comes to High Frequency.
            What Serg V. and Boguslaw have told you guys are correct but the circuit they are posting are the early stage of the Tesla Experiment. What actually we need is High Frequency Vibration means extra energy compared to the slow vibration 60hz.
            What your discussing and arguing on this forum are all related, except for the electron flow idea which is not the correct concept to understand Tesla(Vibration/Domino Effect).
            To clear all your minds, the green box of Kapanadze is the what we call the early prototype of Tesla Magnifying Transmitter, The way of transmission is by sending current to the ground which is switch by the HV spark gap. The circuit is completed when the spark gap connect the open points of the two transformer which also the same time vibrate the ground by sending the currents on it. What you see on the outside coil of kapanadze is the converting transformer, he has hidden the primary and secondary Hi Frequency Generator. It is a matter of ON and OFF adjusting the circuit controller Tesla always cited on all his patent which you substitute with the auto switch SPARK GAP- which is very wrong.The twin tower of transformer of kapanadze is the real deal- The Vertical Two Blue Transformer of Kapanadeze is the correct Tesla Coil with the correct necessary instrument needed.
            We actually needed two transformer, First is to step up the voltage= primary L1 and secondary L2-produces hv hi freq current that will jump to the primary L3 of the second transformer. Second is to step down(secondary L4)= in this process we step down the voltage to the usable amount we needed at the same time by using large inductor we are converting the HV to Hi amperage low voltage. The two transformer have its on grounding rod, they are only connected when the spark gap complete the circuit.
            The key here is the amplifying charging of the condenser on the Primary L1.The other key to success is to read and only read Tesla's Patents and Articles which was actually intended for the future(us). Everything is in the patent but you need to read and understand everything what was Tesla have left for the humanity. Consider all this as a gift given by Tesla to the humanity.
            • Originally posted by GSM View Post
              PS.
              the circuit posted by serg v. is 99% correct but critical component 1% is missing near the inverter. thats needed to run circuit.
              dunfasto
              • I guess: a diode, because this device is a electron multiplier and they work with DC. Please complete the schematic.
                What is the function of the relay?
                • Missing Information
                  Hi,
                  One problem I notice with these schematics, is that they often leave out various details like coil form diameter, type of coil form, number of turns in each and every coil of wire, wire diameter or wire gauge required for each and every wire. Also, if a capacitor is used, the type of capacitor, and the voltage rating of the capacitor.
                  I'm grateful for what you guys have provided already. It is just that providing even more details would be helpful to me.
                  • The purpose of the relay.
                    EMCSQ, the purpose of the relay appears to be to send some of the output power back into the input. My understanding of this circuit is that once the circuit is running and producing free energy, the relay is switched on by way of the step-down transformer. Then the circuit is self powered, as current can flow from the output to the input through the relay. Another method of doing this would be to just use a simple SPST switch.
                    • And not providing for ALL of the component and coil winding details, makes the job practically impossible for the everyday electronics hobby tinkerer, like, well... Us. Notice how I said "practically impossible"...
                      Or, Is that the idea?... To keep them guessing? For as long as possible...
                      I would like to see some working devices first, not more diagrams and schematics of the unproven theory. And, if not, then people can at least say something like, this is another diagram to you to test, but without all the needed information.
                      Information like FIRST showing an operational working device, with meter and scope readings, at least. And also showing how it was built, and tuned, if needed. That is what we need.
                      As showing a video of a device, but not its schematic, or a diagram but not video or pictures, is only half of it.
                      • Originally posted by Nick_Z View Post
                        Well, that information even Tesla never released. Why ? I think because he has to earn money for his work and releasing info would void his patent attempts. Anyway, I think the schematic is very close just we need to find the purpose of two diodes.
                          dunfasto
                          So what is the missing component and exactly where in the schematic does it go?
                          Don
                          • complete sr 193 schematic with details
                            complete sr193 schematic with details
                            the circuit contains ic cd4011b and specially designed emitter follower transistor circuit bd139 and bd140
                            the ic pins used are 1,2,3, and pin 14 and pin 7
                            hv coil is litz wire coil
                            click zoom to view details
                            dunfasto
                            • "Very close" only counts for tossing horseshoes...
                              Let see some proven working devices, first. Not more theory on paper.
                              • [QUOTE=dllabarre;240989]So what is the missing component and exactly where in the schematic does it go?[/QUOTE]
                                the circuit does not show the inverter battery feed thats is 12 volt 7 ah so to self run this inverter circuit we need 12 volts from the output to feed the 12 volt input of inverter. we need step down from 220 v to 12 volt rectified"
                                where bulbs are shown lighted up from there a stepdown transformer from 220v to 12 volt followed by rectifier fwbr to feed the 12 volt supply to the inverter so battery can be removed and the circuit self runs
                                dunfasto
