When i look at Don's original circuit drawing I honestly don't see how it could
work like that, the center tap is not grounded the two ends are and the two ends are joined together.
Uploaded with ImageShack.us
This is how I see some work could maybe be got from the ground disturbance.
Please don't quote me on this it's just a thought, something to think about.
The small drawing at the bottom will work for charging the cap and I've seen
a lot of people not using the both ends together.
Maybe if both sides were rectified separately then added as DC like the next
sketch down might work.
I will try it the way Don's drawing is shown, but I am going to use all CCW
wound coils just like Don explained, if he left something out then fair enough,
but if he deliberately gave a detailed explanation of false information then I
would think he was a hoaxer, as yet I am undecided. If both coils are wound
CCW and the ends joined they should cancel each other out as far as I can tell.
I'll also try this setup with two bridge rectifiers in parallel. As well as other things.
Personally I think I would be most inclined to ground the center tap and make
two out of phase 1/4 wave resonant coils from the two sides.
attached. Don said that original schematic was deliberately spoiled. In fact that simpler circuit is showing that it' just electrical method of electrostatic induction usage. I have no doubt that it works ! It could be that I'm wrong and original circuit also works but we don't find it easily because it contain special coils while simpler one only require fast diodes and big electrolytic capacitor and proper resistive divider.
