  • Hi guys,
    Returning to a comment I made in a previous post, it might be that Tesla's Antenna system of harvesting atmospheric energy might just be the use of amorphous selenium on a receiver plate. Not such a difficult process to work with for use of experimentation. Could be cheaper than PV cells and operates 24/7!! Check health hazards!!
    Dwane
    • Originally posted by Dwane View Post
      Hi guys,
      Dwane
      The older copy machines had a aluminum drum covered with selenium.
      • Originally posted by ilandtan View Post
        Hi ilandtan,
        As you have noted your experience with these types of photocopiers, I am going to tread carefully! I think I am correct in stating than the drums used in photocopiers were coated while rotating and also charged with a drum covered in fine needles - But that charging technique might have been a Xerox propriety feature. At the point of light the charged particles become electrified and the dark ares become none active. On some machines the drum or plate is recoated, on some others cooked plated were just recharged.. I think the point I am getting to is Se when fixed "cooked" to a plate, during daylight, the Se is active. At nighttime, it is my understanding that the Se is UV sensitive only, thereby, providing an energy source 24/7 as a collector material. I would suppose, and have not found the reverse opportunity of using an alternative method other than light or UV to get the Se to operate in its own electric zone. Would an electric charge be enough to activate the Se as an alternative to light? I have ordered some Se for experimentation in the new year!! I would think Don would have passed through this information at some time? I shall Suck it and see.
        Dwane
          Hi ilandtan,
          Dwane
          You don't have to tread that lightly, I only fixed them, and did not design them.
          I could however offer that the Bias voltage was a key adjustment, as the corona would could only charge the SE surface to a certain point, because the halogen lamps only had a certain level of light for neutralization; allowing the toner (powdered plastic) to statically adhere to the drum. Which had to be pulled off the drum on to the paper by the transfer corona.
          That being said, I don't know the foundation of your experiment. I am trying to understand the magnitude.
          It might be that UV is present 24/7, but how much energy is that?
            Hi ilandtan,
            It might be only a distraction. I am constantly waiting for components or materials, or trying to source something or working out what to do! I am waiting for components to arrive to tie up the Slayer tests, some machined parts for my Figuera device are ready and I am trying to work out how a resonant DC HV corona charge device works. I have some Carnauba wax on its way. The Selenium has slipped into the equation. However, there is a lot of interest in its usefulness. I do not have the conditions necessary to produce a satisfactory selenium cell. I still remain on course with the Don Smith outcome. The Selenium will be sometime next year!
            Thanks for your advice on this.
            Dwane
            • Don Videos'
              Hi ilandtan,
              Have just finished Don's videos' you posted. I liked part 2, third trimester! best. More or less gives it all away. Consolidates information. I think this is the only video that I have seen where he becomes quite specific.
              Not to be seen as biased, I am trying to watch Rick's video at speed increase 3:1. Will stop if something looks interesting!
              Dwane
              • Crazy Thoughts Of Don Smith Device
                I know if you study Don Smith's devices, and you come to the realization that devices, in his explanations don't behave the way he describes. The "Don Smith Effect" is something that he says is how all his devices work, but yet it is nonsense.
                How do you charge a plate of a capacitor, and only use the negative side to ground to power a load.
                My answer is to make the first plate a radiator, and then use charge separation to collect the radiated energy between the negative plate and Earth ground.
                I can prove this works.
                Now imagine a very large capacitor fully charged to maximum capacity, imagine the negative plate attached to a load and then to Earth ground. Disconnect Positive plate and insulate to minimize leakage.
                You get no current flow to the load to earth ground why?
                Because the capacity isn't measured from the positive plate of the capacitor, the capacity is between the negative plate and ground, which is tiny no matter how big the capacitor is. Hence Don is Nuts... well but what if we visualize the same scenario but we start thinking the negative plate is not stationary, but a rotating disk.
                Through charge separation, the positive plate is positive because we have emptied the electrons, and then gathered on the negative plate. If we disconnect the positive plate, the negative plate will remain electrostatically charged thus saturating the plate with electrons. If we spin the electrons off, we are creating a negative pressure zone, by pumping the electrons out of Earth ground.
                It's like taking hose in a pool and spinning it around, the rotation creates suction going against gravity. Because you created the pump effect.
                The flow of electrons creates current, the electrostatic induction assures a hefty gain as the electrons spin into the ambient again to be reused.
                • some thoughts based on experiments.
                  The capacitance is AS IS, it varies by the materials and how its constructed, the value can be measured by its physical properties.
                  whether the load is on the positive plate or the negative, as long as there is electric potential there will be an electric current and the load will be powered.
                  electricity isn't just about electrons.
                  plates aren't "CHARGED" with anything.
                  there are some videos where capacitors are charged and disassembled and sorts of things to see where this "Charges" are "Stored".
                  "Positively charged Plates" are like "Hot Plates"
                  "Negatively charged Plates are like "Cold Plates"
                  (or the other way around).
                  when two are joined by a conductor you would have a "current" or "conduction"
                  BUT..
                  there is still a "Current" through the insulator and the ambient air, known as "leakage current".
                  No batteries/capacitors remains "Charged" is a proof of that.
                  you can never stop the current flow, only slow it down.
                  "Heat" and "Electricity" are both recognized as forms of "Energy"..
                  being both "Energy" they should show similar behaviors don't you think?..
                  • Hello!!
                    i am trying to charge my 12v 70AH dead battery! using capacitor charger
                    with 1.28A
                    the battery voltage gos up to 15.4 v on the meter and i stop it
                    we can see the voltage run down to 13.6 v or something?? i dont know why
                    where we should stop the charging process?
                    best regards
                    luc2010
                    • Originally posted by luc2010 View Post
                      Hello!!
                      with 1.28A
                      best regards
                      luc2010
                      That seems like a curveball right away. What do you mean dead; Does that mean acceptably discharged, or discharged beyond recommended recovery levels? I'm not an expert on battery charging, but I can give my useless advice.
                      A battery is a chemical device, so when you say it's dead, your telling me something is failing in the battery's ability to retain charge. Depending on the makeup of the plates, it's sulfation, the specific gravity of the electrolytes all contribute to the battery capacity, which is usually reflected by the voltage if all the baseline levels of the reaction are possible. However, you can't use voltage alone as the indicator of how many amps it can produce over a specified time.
                      If you take a brand new AGM battery, I think it will be above 14V, but a used one will charge to somewhere around 13.5V. There are sites that have all this information, but the fact is that it's better to have a "smart" charger, because it varies the charge rate by where the battery in its charge leve.. i.e., bulk, absorption, and float. If you are leaving it on 1.28A charge rate, that is a low rate, but you can't leave it indefinitely because it will cook the battery.
                      I have heard that radiant charges destroy batteries and make them more like capacitors, which we know doesn't work the same way as a battery. If you are using capacitors to charge a battery you can deliver high bursts of currents, but if you deliver too much it can damage the components. Heat is bad for AGMs, I've read. I recently bought a 5aHr battery and solar charged it with a 15W panel, in a month the battery slowly lost capacity because I had it out in the sun charging. I measured the voltage and everything worked as described, but the battery sides started to warp, and my charge controller started pulsing the load after an hour.
                      If the battery is "bad" it could mean different things so. I have probably given as much useless information as anyone can tolerate. You might ask Turion, he breaths batteries because his 3B device revolves upon the charging of batteries.
                        Hello ilandtan,
                        Thank you for taking the time to post, i am just trying to understand the battery charging process
                        as we know, we have
                        1-Constant voltage charger ''the standard method''
                        2-Constant current charger
                        3-Multistage constant current / voltage charger
                        its advantages and its disavantages thats need to be compared?
                        my guess,
                        for the last stage we must stop the voltage to 15vor even higher?
                        from 14v to 16v?
                        i need a sign to finish the process?
                        always, open to hear and try new ideas!!
                        back to work!
                        Thanks again for sharing
                        luc2010
                          Hello ilandtan,
                          as we know, we have
                          my guess,
                          from 14v to 16v?
                          back to work!
                          luc2010
                          Idea 1: I would use a conventional charger and that has a meter on it, which tell you when the battery is full, stop charging and take a voltage reading of the battery, then place a discharge load for five minutes and see where you're voltage is at; use that as your max voltage setting. Then you can buy an overchager module for 15 bucks and then set it to that voltage. Reasoning: There would be no need to supply more than that voltage so the cutoff would determine your answer.
                          Idea 2: Buy a solar charger module and feed it with your capacitive source voltage. Let the module manage the three stages. Reasoning: The circuit is designed to do the thinking, no brainer.
                          • How do I upload a file to private massages?
                            Dwane
                            • Use outside links
                              Dwane
                              The paperclip button is not present in the private messages to use the attachment capability such as found in a reply of the forum.
                              I usually use my amazon or google drive to give people access, to content via a URL. This way I control the accessibility and can easily withdraw the share after the user views or downloads the file.
                                saved for later use!
                                Sir,
                                you ever come up with a simple solution?
                                best regards
                                luc2010
