    My personal opinion.
    He said
    The primary has to be located within the Bloch wall area, dead
    center, and, at a 45 degree angle to the secondary to function.
    Hello BRO!
    thanks for the valuable contribution, can you please explain the 45 degree ? in my opinion the max electromagnetic flux can be obtained when both primary and secondary are parallel to each other, this mean the angle have to be 0 ! ?
      Hello BRO!
      Not Sure Med, maybe he means this.
        Now Sure Med, maybe he means this.
        Thanks Bro,
        it seem to be a cleaver method, this give an unbalance in each direction so there's a kind of separation between magnetism and electricity, it worth to be tested, thanks once again
          Thanks Bro,
          Yes I agree, it reminds me of the DYNAFLUX rotor wobble.
          In the DYNAFLUX the rotor is on an angle like these coil winds the
          difference being one field is rotating on an angle the other field does
          not move.
          The interaction on both are similar looking. Just a guess.
          • Thanks Marc
            Here is the first step of a Don Smith Device.
            Published on Jan 19, 2016
            Showing ambient energy or cold electricity draw from ionic source.
            Source uses 9.6 watts to fire the ZVS and light a 20 watt led
            without being able to measure voltage with a low frequency energy
            source.
            [VIDEO]https://www.youtube.com/watch?v=0tM2WP3E_KM[/VIDEO]
            Marc Belanger 2 days ago
            the frequency is too low to.be rf, however, my circuit isn't in
            resonance so I only get close with the right spark gap,
            unfortunately, the one that works to create resonance burns
            out too quickly and it's rated for 5000 amp max discharge and
            2700 volts , but, I.don't exceed 1280 volts input. the coil is built
            to resonate at 30077 hertz but the output of the zvs and fly back
            is much lower. this varies with the spark gap, how quick the
            pulses are, etc.
            the reason the ambient energy is induced is due to the coils
            being close to resonance. the electrons in the primary coil
            are dancing around by the pulses, and, the key to.getting
            this to work is to have both in dipolar resonance so they both
            have the electron movement. once they get the movement,
            the secondary will operate and energize a load.. the closer
            to.resonance, the more electricity comes out, however, science
            declared a long time ago that there's only two.types of electricity,
            amperage driven, which this is not, and static, again, which
            this is not. this is cold electricity drawn from the ambient within
            the secondary pulse because I'm driving the coil close to it's
            natural resonant frequency. If I tune the secondary and connect
            the correct capacitor, we can get exactly the input energy for free,
            or many "mirrors" or copies of this energy amplified by what's
            called phase conjugation.
            this is not drawn from radio waves, there isn't 20 watts of power
            to pull in down in my basement from radio.towers.. after finished,
            I connected 12 of these leds, and they were all the same
            level of brightness. I then connected a 50 watt led, turned it up and
            smoked it. then, my arc gap came loose, I.connected it live and
            it blew the ,20 watt led like a bomb. the amperage is devastating,
            so, no, it's converted here within the circuit and outputs more
            than in.by Earths flux, or something like plasma tubes.
            Kangsteri 1 day ago
            +Marc Belanger Well this is hard to explain easy, but here is
            some of my current speculations with bad english... It could
            be that the spark gap makes the circuit act like "solid state
            stirling engine". So it doesnt use the traditional electrical
            energy from the source, but it rings / moves the natural
            energy in the circuit and its mass. So it doesnt create a
            nything, it just boosts the natural movement of electric atoms
            in the mass. Or it could be creating negative / positive state
            to the circuit and the natural charge in the atoms of the mass
            try to fix the balance. This could explain why it usually gets
            cold too, if it sucks the needed current from the air atoms.
            Tesla mentioned that it has similar state of matter than gas and
            it might make similar hissing noise... On many "free energy"
            devices the key element is some kind of tank circuit or the mass
            of it all and tuning it. This means the size and relation of the main
            circuit to rectifying circuit, coils, inductors and capasitors, and
            the size of them. Coils and specially inductors seem to be often
            very underrated thing in the circuit, they also store and give very
            much power. I have made some tests on different style joule
            thiefs and joule ringers too. To me they seem to act like
            "ram pump", that can store, boost and limit the current. And
            there would be very much improvements to be made in different
            shapes and materials of the cores and wounding methods.
            The Lasersabers "super joule ringer" is very special in this case.
            It seems to work with small neodymium magnet core too. But i
            need to make tunable capasitor and more tests with that, and
            the polarity of it. I hope this makes any sense.
            Marc Belanger 1 day ago
            Yes, it makes sense to me, especially after I read Tesla's entire
            high frequency section and tuning for resonance very recently
            again and again, over and over, purely some deep form of
            fascination I have had for electricity of a unique nature... I
            even read about Tesla's fascination with electrical and lightning
            as a child and it reminds me of myself. Since my father was a
            lineman and became a master high voltage cableman , starting
            his own business in the early 70's, I wanted to always do what
            he did. At early ages, both myself and my brother had no fears
            with the electric system and played with it often, electrocuting
            ourselves and still not ever being afraid of the sources, not even
            that of high voltage systems as we grew up. We both joined
            the IBEW and the CT apprenticeship to learn a trade working
            with high voltage cables, within transmission and distribution
            systems. We have taken over the business and now run all of
            the operations now for years, however, I have been experimenting
            with power systems now for nearly 18 years, all types of
            alternative energies, which I have found many ways to do
            with hv and low voltage electricity was was thought to be
            impossible now for the last 5 to 7 years. It seems that everytime
            I lay down and try to sleep, I think about this and other options
            for my experimentation that would me to rearrange the non
            working experiments I am working with, just to get a special
            feature or unique outcome, and, there are so many possibilities,
            to me, the challenges are endless. I never give up with a
            project I am working on until I am satisfied with the outcome.
            I leave the projects together even if they don't work, then,
            I go back to them once I see a vision of a new idea that works
            to make something happen so it functions, then, I try it.
            The visions usually portray a way to make the system work,
            but, they never function the first time, I always have to wait
            and go back to them time and time again!! I saw a vision in
            my dreams last night,
            and I feel I have actually found the correct arrangement
            to use for the circuit I am working on, however,
            this circuit is not Don's because it is my own arrangement.
            I was told in the dream how to make it function, but, I will
            have to use now a very high voltage and high current IGBT
            or Mosfet for switching so the current can be connected and
            disconnected from an isolated circuit to cause this high
            amperage discharge in the secondary, enough to charge the
            caps and battery to use for a massive gain in energy for
            self looping and to do heavy work.. If you remember what I
            stated about the arc gap, When I connected the arc gap
            after it fell loose, I used a pair of insulated pliers and tapped
            it to the source where it was fed, allowing a burst of HV to
            get rectified and shoot through the coils, getting to the other
            side in a very strong burst, but, nothing more than this other
            than the exploding led chip. It caused a high powered blast in
            the secondary that was startling, I mean it sounded stronger
            than a shotgun blast and I literally jumped! . This blast was the
            led exploding as loud as a 208 volt phase to phase explosion,
            however, when the spark gap is connected normally, there isn't
            enough of discharge from the secondary to do anything but light
            the leds, however, I could light as many leds as I wish, with no
            ill effect , or any use of energy from the source, in fact, the
            energy used was reduced! I tried this again, and, the next time
            I tested the output voltage and it was tested ok with the analog
            meter which jumped up to 240 volts. I could tap the connection
            together 5 times instantly and all 5 taps gave me 240 vac. I then
            rectified this and it made 320 vdc, but, I decided I am going to
            use an igbt or a mosfet to connect it after I isolate the control
            for the igbt or mosfet and power the switching circuit from a
            battery source that is unrelated, using a 555 to pulse it on and
            off, creating this energy burst 60 times per second, then, transform
            it to a lower voltage to see if it will charge batteries. I know it
            will work, I saw it in my visions working, and, that is when they
            all work perfectly. Oh, BTW yes , you are 100% correct, this
            energy that powers the leds seems to be smart, like it has a
            mind of it's own, knowing what it will blow up or what it will not..
            I actually am able to feed my cheap and old laptop with it
            and it turns on, however, it will not charge the battery. I am
            trying to figure out something and would like to see if it needs
            rectification to feed the battery first, and, if it does, we won't
            need to go any further. This means we can charge batteries,
            then, use the battery to feed large ultracapacitors for load
            handling, and, fire up powerful inverters. The energy, touched
            by a human has absolutely no effect.. add a light bulb..
            no effect... add a neon no effect... add the led , or as many
            as we wish and it or they lights up, but, these aren't low power
            leds, these are chip style flat leds that won't light without
            50-100 volts and 50 watts, or, 12-24 volts and 10-20 watts
            consumption. But, the circuit will power up as many as I can
            connect to the circuit. it will energize the same brightness on
            all of them as well. I connected all of them tonight in one shot,
            then, I connected 20 of the 1 watt leds in series and parallel
            without popping them. I connected a 4' flourescent bulb to full
            brightness and the load drops to zero when it does this. There
            is no hv according to the oscope too. It is very strange! Thank
            you for your interest. If you wish, ask me to connect items and
            I will video them for you before I change the circuit I'd like to
            keep it for testing. I am going to bring this out to Yale University
            for testing soon, I would like to make an appointment for a visit
            and possibly have their students do a study on it if they wish.
            I do a lot of work at Yale currently and have a friend that told me
            he would be able to get me in the door for a physics study as he
            did once before for another project..
            • Marc Belanger Continued
              The circuit is an experimental reversal of Don's original system.
              He has given the wrong diagram, but, the info is out there to
              make the system work, along with my interests in making the
              correction, posibly even showing a complete diy if I don't receive
              what Ive been after.. . anyway, don't keep shouting doubt..
              your doubt won't stop me from succeeding in doing what I am
              trying to do. I have several of these boards made up and two
              of them have pretty promising results, the battery even
              overcharges, the whole nine, I am just waiting for parts to
              even out or reduce the battery's overcharging.. when they
              arrive, the questions I had will be answered, especially the
              Metglass core and the asymmetric transformer wound with
              Litz.. It works like a charm.. There's a few other devices that
              are already functional in my lab, so please, don't try to add
              the suppression to my channel.. I've already passed your
              level of negativity and have made it very positive for my
              viewers. The big problem is that there's too many flies out
              there seeking **** and, I've found that I get a lot further
              helping others privately than posting any of the answers
              to the public. You know as well as I do that I can't post
              the reason why it all does what it does publicly ,and,
              that Public posting has taken a lot of true innovators that
              have figured out the reality of these devices offline and
              made them go away for good. . I'm not one of them. I've
              taken the impossible and already made it possible. What
              makes you suggest that I can't do it again? That is my only
              wish here.. is to show folks something is possible so they
              don't give up. If I weren't in business with the power
              industry, I would have already pushed these devices to
              the private market, on the underground because there
              aren't many able to take apart what I have built to be able
              to replicate it and then tell you how it functions correctly.
              That is the entire key to this all. if they could say the answer
              with certainty, then they can build it, but, until that time
              comes, everybody thinks this is a step up system that
              magically collects ions, slices the energy and outputs magic
              from the high frequency area.. which it can't and won't do..
              it is what I am showing here, minus the special compound,
              however, this can't be in resonance because it doesn't have
              the metallic rod needed to make it all happen... I have, and
              have had a similar metal compound available to me for years
              that absolutely makes it function.. should I REVEAL?? remember
              my key is similar in structure, but isn't the same, however,
              it does and will continue to self operate no matter what you
              or anybody else says. I just haven't posted mine because the
              frequency isn't stable or in the correct range yet. It will be
              very soon though, unless i receive what I've been asking for.
              Unfortunately, cold electricity is immeasurable without the use
              of a scope. In fact, I think I've proven this in my video to
              show it only shows up as negative energy from a scope,
              which doesn't happen in dc electronics. But, i will happen
              to make it easier for all by offering a negative energy to
              dc output by trying to rectify when I get back to the lab
              this evening, seeing if it will successfully rectify and output
              to charge batteries or a cap since the energy will not
              charge ultracaps directly, but, it may only be because
              the ultracap works more like a polarized electrolytic cap
              and will filter out high frequencies, eliminating flow of
              energy completely. I just think it is also too weak to do
              so, however, when I remove the arc gap and reconnect
              with a tap using a set of pliers, the led blows up like a
              bomb, and, it makes no sense since it isn't a solid
              connection, it is an open connection that gives the
              oscillation of the tank circuit time to charge too high
              and amperage build so high that the output ends up
              exploding with mass amperage for a split second.
              Anyway, this shows the true potential of the system
              because it shows me one of two things.. I am using the
              arc gap in parallel to the rectified input, then, charging
              a cap in series to create a charge pump, however, I
              need to do just the opposite and create a steady dance
              of electrons as an input while the cap is already charged
              in parallel to evenly release the strike of the arc in a
              steady but silent motion to output as a massively an
              increased output. This is easily done with a special
              metallic compound, however, I can't give this up, I
              am trying to find the way without it.
              +dusanln Don's system is a protected system since it was
              bought out for it's use, and, the majority of the technologies
              were bought to be shelved. The information being listed online
              will attract the wrong kind of attention, but. I certainly will
              assist you, however, what folks think are the parts, aren't
              really the same parts needed for every system. Every coil,
              whether they are B&W's coils or not, air dux, or other brands,
              even the same brand and model numbers will have a bit
              different resonant component. We have to tune accordingly,
              and, even the formulas used all over for Rf are not really the
              true formulas, the formulas are literally specific for this device
              and must be specifically comprised of two different mathmtical
              equatins si. I am going to share one secret right now with you
              all... The primary has to be the larger coil, and, the secondary
              is a split coil, it doesn't have to be opposing coils, but, they
              do have to be multiplied x each other's turns to get what you
              need for primary turns. Also, the insulation of the primary
              between each turn needs to be calculated "the space" needed
              to calculate the resonant uf. at the same ratio as the turns
              ratio from primary to secondary. Spacing equality is vital, and,
              you need to have at least 4 times the primary spacing between
              leads to catch a break with resonance with the mutual
              inductance as it is vitally important to receive this for an
              amplification factor. To make the tie physically will give an
              amplification by way of "forced resonance: of the overall
              inductance and turns, as Kapanadze does, however, the
              coils of his feed into each other and aren't mutually
              inducing from one to another by way of matching frequency
              due to the same wavelength's oscillating without touching
              each other, allowing the dispersement of electrons marching
              in one coil, in the same direction as the other coil. This is
              the whole magic trick with the Don coil system and it was
              discovered by Tesla.
              • The bent coat hanger is fashioned to represents it's fractal role.
                Which is that part of a network to filter direct and converge the unobserved energy.
                • Here are some shots of Marc B. device replication of Don S.
                  You will notice the primary coil of 140 turns? I think that was the
                  number of turns, is on a 45 degree angle inside of the secondary.
                  Marc talks more about the Antenna. The pictures shows the angle.
                  Marc Belanger 10 hours ago
                  +Bro Mikey Thanks BroMikey. I have finally figure out
                  how the system induces the energy, and if we look at the
                  Don images of his benchtop generator, we see a tube
                  internal to the generator that gives us exciting news
                  showing me and the world that the North side of the coil
                  has a core, or, an antenna core, which would be similar to
                  Kapanadze's but, used for a different purpose. Don spoke
                  of the use of different core materials used in his Dipole
                  generator, one of them being a milspec metallic compound
                  that acts as an antenna, not as a magnetic core since the
                  material is not ferrous whatsoever. We would connect this
                  core to the arc gap side of the ground, at the NST,
                  introducing a pulse of ground to the core's antenna rod.
                  I find that aluminum acts as the best energy antenna, so,
                  if we pulse ground spikes through to this, there is an
                  energetic comp[onent to it, creating an attraction from
                  the aether , back to this antenna. Since the coils are wound
                  around this, for the magnetic energy to get back to the
                  antenna, it has to go through the coils first. We show in
                  my video that the aether's cold electricity is excited in the
                  secondary coil, ready to go, awaiting for the magnetic
                  energy component to hit it as it is in partial resonance.
                  The harmonic that is already there in the secondary is
                  ready to induce anything that would flow near or through
                  it as an electrical energy derived by the magnetic
                  component as the coil is charged, but, it isn't yet
                  energized. Since the antenna is attracting the Earth's
                  plasma tubes to the system, when we ground the other
                  side of the load, the charge pump has been pumping this
                  pulse of enrgy into the ground, and upon it's realignment
                  to the antenna core, this energy will start to flow as the
                  pulses start to migrate from the ground, back to the
                  secondary coil, completing an operating circuit. I really
                  feel this is the answer and I will be providing my work on
                  this to see if I could get the energy to flow this weekend,
                  provided I could provide a new and better ground to the
                  charge pump, and, the higher impedance ground will have
                  to be the load's return ( i think, I may have it backwards,
                  but, if it is, it will only require changing two wires to see
                  if the current starts to flow.) i will keep you all posted.
                  It won't take much to get it going as I built 2 new coils
                  with fine stranded copper clad aluminum 1/0 wire as the
                  antenna core last night and will be testing them later
                  today!
                  • Doc E says it works also.
                    The tube video guys are a mess when it comes time to
                    explain what they are doing. I remember way back watching
                    some make statements that the voltage is stepped up but
                    "SO WHAT" and I would go to the next video.
                    They always fumble the ball when it comes time to tell
                    someone else what is going on. Doc E did a bunch better
                    than what I have witnessed. Answers like more voltage
                    comes out just doesn't say it.
                    [VIDEO]https://www.youtube.com/watch?v=tyW5TYyx-k4[/VIDEO]
                    • Hi, All,
                      For my very first post on this forum:
                      I have been looking at the picture of Tesla's apparatus, as well as a few years research into the whole 'free energy' stuff. Interesting. Sometimes I recall Johnny Cash, because 'I've been everywhere, man' on the 'net researching and reading about a whole lot of what I believe to be working technologies that have been suppressed by the so-called 'elite'.
                      I have not experimented with any devices yet (only for fear of burning down the house, or being shocked to death that I got something working :-D).
                      Right now, I am into research and ideas, including Eric Dollard and his postings here.
                      For my very first reply on this forum:
                      @ Jeff Pearson,
                      In studying the photo, and my knowledge of drawing, I believe the little squiggly you see in the circled section of Pat 568,178 is a 'hidden line' depicting a rod through a hole to hold the rod attached to a plate, and the thick portion is a sliding collar to allow the movement of the plates to vary the space between them.
                      I had to look at this a few times, because with Tesla, sometimes it's hard to see what he was doing.
                      I wonder what ever happened with the guys that were trying to replicate the Lockridge Device? I've had some thoughts and ideas on that as well.
                      The posts about Syairchairun's device is interesting, and there's a few that are working on that one, too.
                      Anyway, a VERY BIG THANK YOU TO EVERYONE who is willing to share their ideas, findings and concerns.
                      TheForces2B
                      • Greetings Force2B and Everyone to whom this may concern.
                        Here is a recent entry I feel it very important for serious
                        experimenters. Thanks Marc for sharing your work that has
                        required long investigations through the years.
                        Not only does Marc understand how to do this for himself
                        he is also well able to explain to others what is needed.
                        This is an important addition for replicators.
                        Marc Belanger 6 hours ago
                        +Bro Mikey I have had luck with one of my first replications of the
                        schematic Don supposedly released. There are like 7 diagrams
                        from Transworld Energy, Don's company before he passed away.
                        He must have made a bunch of the circuits work, however, he
                        would show the schematic without any values other than voltage
                        and locations of the parts, labeled with what they are but not even
                        the sizes of the parts. The funny part of the circuit is that the coils
                        are even more unique than a finger print, so, when folks ask "How
                        many turns are in my design, it really doesn't matter. The turns are
                        only responsible for the voltage per turn on the primary and the
                        secondary. What other builders don't realize is the fact that the
                        length of the coil, the spacing between the turns, and the diameter
                        are all part of the outcome that gives us the inductance of the coil.
                        The inductance is an important factor that gives us resonance at a
                        specific frequency when a capacitor is added to the coil in series or
                        parallel. A capacitor and an inductor creates a tank circuit . The tank
                        circuit will resonate at whatever frequency it is built for, however,
                        the capacitance and inductance of the tank circuit are the prime
                        reason why the tank circuit oscillates at the frequency it's
                        designed for.Factors in other components of the circuit, such as
                        coil capacitances and other inductances will change the desired
                        results, so, all parts of the circuit that connect together must be
                        tested for their total inductance before and after they are
                        connected together, then, capacitances of each part of the system
                        before and after their connections are made to see whether or not
                        they rise or drop, then, additional components will need to be added
                        to tune them back where they need to be to find and maintain
                        resonance.
                        When people ask what size wire and how many turns are use in say
                        the "L1" coil, there isn't enough data to build the circuit with this.
                        The best question to ask would be "how much inductance is in L1,
                        and, if any, how much capacitance does it have?
                        The things I did to have a successful resonation is the following:
                        Find the printed NST frequency. Then, add a gas discharge tube to
                        the outputs, connecting one of the NST's hot legs to one side of the
                        arc gap and the other hot leg to the other end of the arc gap. Turn it
                        on and test the frequency with an oscilloscope and a hv scope probe
                        that will handle the level of voltage from the NST. This will give the
                        correct feed frequency. Next, we have to test the NST's
                        output for capacitance with an LCR meter, and, the inductance.
                        Then, we need to wind our L1 coil, documenting the L1 coil's
                        length (precisely) and keep them separated, measuring the
                        inductance of the L1. Once we have this completed,
                        we need to connect it to the output of the NST
                        and test the inductance while connected. Once we obtain this measurement,
                        we need to take this and go to an online resonance
                        calculator to see what the capacitor size is that is needed to resonate
                        at the circuit's drive frequency. We need to add our capacitor to the
                        circuit and test the capacitance when connected with the cap inline
                        or in parallel so we could see if the capacitance remains where it
                        should be. If not, we need to tune it by adding the capacitance
                        necessary to land at the correct capacitance calculated by the
                        online calculator. Once this has been done, we need to energize
                        the circuit and scope it to see if it resonates and the frequency
                        is exactly where it is tuned.. the desired frequency. If it is off,
                        capacitance must be added or subtracted to get it correct. Once
                        done, we need to wind the next coil either 4 times longer or 4
                        times shorter, so we have a mutual coupling at a quarter
                        wavelength. This needs to be done from each node, which
                        will be a termination, a soldered connection, where wire goes
                        from stranded to solid, and, where the wires end up, such as
                        a termination on a battery. If the total length from the coil to
                        it's destination isn't calculated, the self resonance or mutual
                        coupling of the primary to secondary will NOT happen and the
                        circuit will fail.''
                        The secondary side is a little bit tough to do because we need
                        to calculate the length so we could land at an appropriate turns
                        ratio. This nearly never happens, however , I had instant resonance
                        the first try when I weighed out exactly the same wire weight for
                        the coils, as Tesla states he did. If you do this, the scale needs
                        to be precise. If we use the same sized wire, the lengths need
                        to be any even multiple of the other side. It's difficult to do
                        regardless because the precision has to be within 1/32". That is
                        difficult to do with wire cutters, so, weight is easier. The primary
                        could use fine strands such as #34 wire at 1/4 the length of the
                        secondary, and, the turns ratio is best to have a long enough
                        length so it has a high resistance, meaning it should have 100 to
                        500 ohms. This requires a very fine wire and a lot of wire. It also
                        allows the cold electricity to pass as the hairpin circuit does
                        with high impedance light bulbs do, while low impedance allows
                        nothing to pass, especially when in parallel. Resistance is part
                        of the resonant frequency, so, if Don took the 8 awg wire and
                        he added a 500 ohm resistor inline with the l1 coil, inside of the
                        tube, we would never know unless we tested it.
                        The Hairpin Circuit, researched by Karl Palsness has proven that
                        high impedances allow more power to pass within the circuit,
                        and low impedances virtually eliminate the energy transformation
                        /production. This is KEY with Don's system, and, we could add
                        the resistance to the resonance calculator to come up with an
                        LCR circuit that performs even better and is easier to tune than
                        the LC circuit since the capacitor values will be easier to acquire
                        if we add resistances. We will also be able to manage frequencies
                        within our full wave or half wave recitifiers by adding caps and
                        variable resistors within the bridge. This is key for controlling
                        frequency along with the use of inline chokes and capacitors
                        across coils with the use of a resistor.
                        There are hundreds of variables we need to cover in the Don
                        circuit, so, if we leave this alone, we will find we will never get
                        the outcome desired.
                        The most critical point in the system will be shunt points. To
                        add a short will need the use of another coil. Look at Don's
                        schematics. You'll see that 4 of 5 circuits use a short or they
                        are shunted with capacitors and arc gaps to bring in that
                        additional energy from the ambient. These systems are very
                        real.. We need shorts to make it work just like Ishmael Aviso
                        does. Short them it works!!!
                        • Continuing entry on practical design for Don Smith Device.
                          Marc Belanger 3 hours ago
                          +Bro Mikey yeah, there are short circuits at the l2 coil, as a few of
                          the original diagrams have one completely shorted coil as well, it has
                          a 4th coil to transform the energy. there are shunts using caps as
                          well because some of the coils don't have resonant caps. the .047uf
                          cap is a shunting cap, but, we need to look.at the correct diagram.
                          I.figured this out because of the oscillation caused with the closed
                          tank l3 which.is in series with l3 and a bridge rectifier.
                          I've been slowly but surely collecting all parts of the system Don
                          built... I mean all of them except for the last yellow coil and the
                          Cornell Dublier caps
                          (.1uf 4kV wvdc yellow intro caps he had made)
                          anyway, I found the radio shack inverter, the neon dimmer, and
                          the barker and Williamson coil. next I'll eventually find the
                          Bertonee NST, I just put out want ads and wait.. they eventually
                          pop.up!
                          this way, when I eventually have it all, nobody can shoot me down
                          and say I did it wrong. it either works, or it doesn't. there's just
                          no in between. I've studied this forever and know everything
                          written about it, plus I have mass experience at failing, so, there's
                          not many bad ways to.try left.. lol. can't stop.laughing... I burnt
                          and blew up many things, blasted off screwdriver ends, discharged
                          caps up to 500 amps, and now since I know exactly what to do,
                          my ight output design will have to drive enough amperage out
                          provided the massive 88uF 1200v caps hold up during charge time.
                          I think they'll withstand microseconds worth of ups, downs and
                          overplayed, however, I'll have to ensure the load is enough. I
                          could shunt the circuitry with heaters until I figure out the correct
                          sized cap for the right voltages and amperage. my calculation was
                          1200 volts to give me 120 volts continuous. 10 times the over
                          voltage with minimal amperage to mix with 10 times lower voltage
                          and 10 times the amperage for a very substantial output.
                          supposedly, the frequency and oscillation between the output
                          coils and the short produces the Casimir effect according
                          to Don.
                          • scope trace at resonance
                            How should look the scope trace when primary are in resonance
                            with secondary?
                            Can somebody post some pictures?
                            • Originally posted by sinergicus View Post
                              with secondary?
                              Hello Sinergicus
                              Not sure if the Don Smith device always shows proper volts
                              or amps and that would also effect a scope shot. I believe
                              that this anomaly is stated often with the Don S. but maybe
                              someone else will correct me.
                                Hello Sinergicus
                                i agree with you Bro, in my opinion this look like digital versus analogy systems, in the latest test using an extended bifilar arrangement the voltage is radiant but accompanied with ordinary electric current so the final power is real active, it's no cold anymore after using it from the capacitor banks, the system work in more dimensions , so it's no easy to catch it !
