  • Originally posted by woopy View Post
    Hi jeofr
    great work , i am impressed by your great inspiring work
    Hi Mr clean
    hi Kurt very near the aim bravo
    at all
    some idea for the vacancy in music
    good luck at all
    Laurent
    Charging by induction music - YouTube
    hi mr.woopy,
    very entertaining and impressive work.
    yes music is life force it affects our mind and hearts.
    admire and appreciate your openess to share and experiment.
    admirable work.
    thanks and regards
    dunfasto
    • Originally posted by GSM View Post
      Is L3 not at live end of L2, thus any ground at L3 would kill transfer ?
      Also earth for L3 diode rectifications is via toroidal transformer interwinding coupling ?
      Hi gsm,
      it will compensate and enhance if resonance is not matched as the placing position of this L 3 coil on the kacher long coil affects the output fed to caps and to find the best position of this L3 coil connect a bulb across two ends of L3 coil and move it along the length of kacher long coil when the bulb light its brightest fix coil at that position and connect earth and the bulb will light up more brighter.
      the frequency is still HF when rectified will give more brighter lights at output of inverter after transformer.
      thanks and regards
      dunfasto
      • Originally posted by joefr View Post
        Hi All again
        This is my new setup with Kacher Tesla Coil and StepDown 300VA 230V - 12V Toroid transformer. The load in this setup does not affect the input. OK, it affect it a little as the input goes down a little when I connect 12V 60W Car bulb to StepDown transformer output.
        JoeFR
        Hi joefr,
        to reduce input use the following figure arrangement and see the difference. dont use L3 coil. and keep the L1 coil close to the cold end of longer kacher coil.the load wont affect input in any way and output performance will not be affected. your present consumption will get reduced to 300-500 ma at 24 volt.
        energy of your caps
        the energy of your cap bank is 4.297 joules that is 4.3 watts approx. i dont know your frequency if your cap charges in one second then you are pulsing with 4.3 watts/second approx to toroid.
        spark frequency also decides the power fetched and pulsed to transformer. the rate at which it is pulsed to toroid transformer.
        cap charging and the storage energy the cap hold decides your power at the input of your toroid transformer. since it is still high frequency the real amperage is not known. if you are to take measurements of input and output you must convert output to pure dc then do measurements.
        thanks and regards
        dunfasto
        • Originally posted by dunfasto View Post
          Hi mr. clean,
          you have done so much work on don smith device. i admire your work and the zeal and enthusiasm you put in and the videos have been inspirational for others to follow your track.
          wish you good luck and all the best for the final run.
          thanks and regards
          dunfasto
          Youre too kind, thank you im glad to have others to share it with!
          -Shunryu Suzuki
          • Comment
            • Hi joefr,
              use gdt and use in series if u want to increase gap. or use stainless steel needles with pointed ends encased in glass tube with enough diameter to slide in needle for adjustments
              and if you want to go for ready made then best choice is RED- thoriated tungsten as you are pulsing DC to coil.thanks and regards
              dunfasto
              • Hi Dunfasto
                I tried different types of GDT-s but they are not working as good as open spark gap.
                So I like to try open spark gap with tungsten electrodes.
                JoeFR
                  Hi Dunfasto
                  JoeFR
                  use Red- thoriated tungsten. as you are pulsing DC to coil. try to make spark silent by adding resistor in series with coil.
                  T and R
                  dunfasto
                  • Safety hazard "alternatives to thoriated tungsten are available"
                    T and R
                    dunfasto
                    @joefr @ dunfasto @Mr. Clean @ woopy and all
                    A step forward in the mile stone progress Thank you for sharing your achievements.
                    Due to safety hazard alternatives to thoriated tungsten are available
                    1.5% Lanthanated tungsten electrodes (AWS classification EWLa-1.5) Lanthanated tungstens are acceptable alternatives to thoriated tungstens even in performance. The Danish Welding Institute has recommended that thoriated tungsten be phased out in Denmark since non-radioactive alternatives are available.
                    Hope it helps
                    JJ
                    • @ JoeFR
                      Dynatron is using pure tungsten.
                      I read somewhere that you can shape one to make an anode and cathode.
                      Encase them in a pyrex tube under vacuum for smoother, quieter operation
                      You will have to experiment with the pressure.
                      • Tesla used magnets near the spark gap to quench and quiet them. He also tried air blowing on it I believe (not especially efficient though when you are trying to achieve OU).
                          scalar amplification
                          ScalarWaves - Vidéo Dailymotion
                          thanks and regards
                          dunfasto
                          Looks Fake, If there is not a battery in the little thingy with the LED in it and a
                          magnetic switch operated by a magnet under the bench, then I think there
                          must be a HF coil under the bench and the ones on top of the bench are
                          receiving charge by transformer action or other action. Easily done I think. I think
                          there is an input. Only one person can prove it is not a fake and that is the
                          maker of the video. It doesn't make any sense to think it is real free energy
                          with no user input without better proof than that. I think anyone with a basic
                          knowledge of coils/transformers could pull that trick.
                          Is this your video dunfasto ? I think it is important to know if it is your video.
                          If it is your video can you show the experiment on a concrete floor ?
                          That trick doesn't look much different to the trick I did in this video below.
                          Free Energy Coils In Action.wmv - YouTube
                          Except I didn't put a funny lookin coil on the bench.
                          The transmitter coil I used to do that trick was a solid state Tesla transformer
                          powered by a 12 volt battery with roughly 7 to 8 watts of input power and
                          the transmitter coil was situated about 3 meters away out of shot with no
                          connection at all to the receiver shown. The receiver coil has no connection
                          to anything and there was nothing under the wooden thing it sits on
                          (which is beside the point anyway) but I thought I would mention that as well.
                          Pretty much anything we can imagine as real can be faked, we need to get
                          used to that fact.
                          2nd P.S. I found when doing transmitter receiver experiments that more stable
                          and consistent results can be got with lower frequencies, in my opinion
                          because it is much easier to match resonance of transmitter and receiver
                          because a small change on a 50 kHz coil produces a much smaller change
                          than a small adjustment on a 5 mHz coil It's not easy to tune a coil
                          to say 5 449 200 Hz.
                          it's much easier to tune a coil to 449 200 Hz. Changes on approaching have a
                          lesser effect as well. In my opinion that is.
                            used to that fact.
                            Hi Farmhand!
                            the frequency is 16 hz only. scalar work best at multiples of 7.8 hz or 8 hz
                            scalars are everywhere you dont need battery to tap scalar energy. you only need to tune to multiples of 8 hz frequency only. you only need cap and coil to use power freely available by nature. making Tesla words true.
                            scalars and radio and joule thief
                            Joule Thief, Magnifying Transmitter, and ye olde tyme Crystal Radio. - YouTube
                            Full regards!
                            XILO
                            • Electrodes
                              Talking of electrodes, I took apart an old microwave the other day (my first microwave breaking session). I managed to get the magnetron apart, to get the magnets out, but I wanted to go further, so I smashed the ceramic isolators top & bottom to take a look inside (I hope it wasn't too radioactive ).
                              Anyway, in the top were 2 electrodes, going into the top ceramic isolator. I smashed the ceramic & got them out, they are incredibly hard, very hard to bend despite being only around 1-2mm in diameter (will measure them in the next few days).
                              Anyone know what they are made of???
                              It also looked like there was some seriously pure copper inside there, but only a very small amount, & not easy to get to, so I dumped the rest.
                              My current electrodes are just some mild steel M8 threaded stud. I filed one flat & the other pointed (conical) to simulate the anode & cathode of a diode. I believe this is a good way to do things???
                              Now I'm on the look out for more microwaves, as I need the capacitors badly!
                              I got my new L/C meter a few days ago, so now I know what capacitance will be needed to tune my coils to resonance. I'm thinking about 35KHz, but it will all depend on what HV caps I can eventually get.
                              Hoping to catch up with a few of you soon, you're all giving me much inspiration, keep up the good work!
                              • mot magnetron
                                Danger re magnetrons: Be very careful taking magnetrons apart. Some of them have extremely dangerous chemicals inside. I hope yours is the good type.
