  • Peculian,
    Thanks for the links, but my question was what did don use. You are saying he used 12 to 14 gauge?
    • Originally posted by drak View Post
      Peculian,
      I don`t know Drak.But I have already purchased a cable 10m long 14 gauge.
      I think from 12-18 gauge cable like the ones in photos I posted here should do the work.
      But experimenting with it needs to be done in order to see what fits at ones efficiency.
      @Farnhand.
      LOL. Take a gauss meter to see radiation from your billy goat.
      Take care or you can be severely electrocuted.
      • link problems
        If a video link is bad, please do not flag this post as problematic to the forum moderators.
        Instead, bring it to the attention of the person that posted the link - submit a post in the thread stating this.
        Thanks!
        • Hello Drak
          @Farnhand.
          Peculian may be right about the size wire. I don't recall DS ever saying for sure. Instead he said use one fourth, larger to smaller, to form the L1/L2 coils. I do remember someone saying that he used his favorite wire with this build and that was jumbo speaker wire, I think.
          I personally used solid copper wire (4 gauge) which is very heavy for L1 and solid copper wire (16 gauge) for L2. I designed my coils like the Kapanadze design for several reasons and followed the one fourth rule with 1 being L1 and 4 being the L2 length or one to four. Also important, L2 should be comprised of two smaller coils, each wrapped ccw to each other and each following the one fourth rule and then you must center tap between the two as DS explains in the pdf.
          Best I can do for this so if you don't understand what I have said, then please re-read what DS said about this.
          Hope this helps.
          • Stoker,
            Thanks but I have already tried a lot of experiments with this, check my history. I'm simply trying to determine, as had been mentioned before, whether Dons' L1/L2 was in resonance with his NST. Looking at Don's device, he used (2) .1 uF caps across L1. I used 8 gauge wrapped like it is in his photos and with the .2uF caps it only dropped the resonant frequency down to about 300khz. His NST is running at 35khz. Maybe you can see where I'm going with this...
            • In the end, electricity, along with all the known factors by which we measure the work that electricity can do, would all fail if it weren't for field theory. With it, all of the above can be true and is true. Don Smith knew this and built a machine without moving parts that can and does work with the ambient energy around us thanks to good old mother earth.
              I hope this helps.
              Stoker, indeed it does.
              Thanks for your informative posts.
              Bob
              • Hi Drak
                This explanation will be ruff, but think you will understand.
                Whether you are using 12v supply or wall supply you will need to adjust the voltages to fall into the right frequency range. For me, I use the wall, variac, NST with the appropriate capacitor (more on that later). Don used a 12v supply with inverter, variac, NST and the appropriate capacitor.
                You used 8 gauge wire for primary L1 while I used 4 gauge wire instead. I don't know what gauge wire don used, but I do know that L1/L2 did resonate with the supplied power and frequency. Please recall that Patrick Kelly provided a chart for the purpose of finding the appropriate capacitor for this problem. It was a simplified version of a much more complicated formula that Don recommended. If you can determine the LCR measurements of the coils and feeds to them, then you can determine the proper capacitor to use.
                Some of this is still above my head and I study with repetition to get past the hard parts.
                The difference in the wire sizes we chose to use will also determine or have a determining effect on the size capacitor for the job. That is something I've learned by studying the Kapanadze information.
                I think that 4 was easier than 8 for this purpose.
                I'm probably wrong to suggest this, but our builds are not the same and will never be the same based on the material differences, but the function will be the same when all things are in balance.
                Hope this helps.
                • Originally posted by Peculian View Post
                  Thank you for making this clear to the point !
                  The same route applies for me too.
                  quite welcome sir
                  • Drak, one more thing, please
                    My last post was quickly written and may not be clear after all.
                    The voltage and frequency supplied by the NST will create the starting point. By this I mean, the frequency of the NST will hopefully get you in the ball park and the adjustment needed for L1 is just a matter of finding the right capacitor for the frequency you want. Don always suggested 35 KHz, your right, but he never said that it should not exceed that. He has said that he felt that he got better results in that range. In some of his later designs, though, he talked about much higher frequencies. I bet you know that. A variac can be a big help with this problem too.
                    Anyway, enough said.
                    • Originally posted by stoker_x1 View Post
                      The output frequency of the NST will be the same as the input AC frequency (usually 60 Hz). To get to 35 KHz you will need to excite an additional resonator that is resonant at 35 KHz. Is that what you are doing? This may be the function of the spark gap. Or, am I missing something?
                      • Frequency
                        Stoker,
                        The frequency of the pulses passed on to the L1/L2 coil pair is determined by the rate at which the spark gap fires. That rate can be higher or lower than the frequency of the driving oscillator as it is determined by the number of oscillator pulses per second, plus the oscillator voltage, plus the gap which the spark has to jump, plus the size of the capacitor feeding the spark gap.
                        If the capacitor voltage builds up fast, then the spark gap can fire more than once for each cycle of the oscillator. If the capacitor is large, then it can take several oscillator cycles to get the capacitor voltage up high enough for the spark to occur. So, the capacitor size and spark gap width can be used to adjust the frequency of the pulses fed to the rest of the circuit.
                        However, if you strike a bell which vibrates at 400 Hz, you hear the sound. That does not mean that you have to strike the bell 400 times per second in order to hear it. The bell has it's own resonant frequency and will vibrate at that frequency even if it is struck just once. Just like the bell, the L1 coil has it's own resonant frequency and will vibrate at that frequency no matter what the rate of the incoming pulses happens to be, even if there is only just one spark. Because of that, it is vital to have the L1 and L2 coils in resonance with each other.
                        Because of the standing wave produced inside the wire at the resonant frequency by the sigal bouncing back off the end of the wire, if the coil wire is extended beyond the coil in order to connect with the next component in the circuit, then the wave will continue to that connection, and the connecting wire length forms part of the physical length of the "turns in the coil". If the wire forming the coil turns is terminated at the end of the turns and the connecting wire is a very different diameter, then the signal bounces back from that sudden change in diameter and the connecting wire length is not part of the vital 4:1 wire length ratio needed for inter-coil resonance.
                        Life is never quite as simple as it looks on the surface, but once you get the hang of it, it can be fun.
                        • When your are designing these blocking oscillators, consider using a resistor in the collector line of the transistor or they draw enormous currents.
                          An ordinary Joule-Thief circuit draws over 100mA and that is to much for self-running.
                          • Originally posted by Haan
                            All this talk about 35KHz ...
                            For you guys looking for simple instructions on how to build a DS device, I suggest you listen to DS himself on the videos Donald L Smith Device bonus part 1 and part 2.
                            Thanks for the video links. So he was not using a neon sign transformer, he was using a neon sign power supply (oscillator with high voltage output).
                            • How to use a SWR meter - CBradiomagazine.com - YouTubeThat is a full standing wave or in Tesla speak a longitudinal wave. Part 3 of 6: Eric Dollard Tesla Longitudinal Wave Energy SBARC Ham Radio with Chris Carson - YouTube
                              • Truth
                                Look at this page. Go about 2/3 way down and you will see a diametrically magnetized magnet. Go almost to the bottom and you will see another. Gee Whiz what a bunch of lazy people. You want everything handed to you. No wonder you never build anything that works.
                                Disc Magnets
                                Carroll
                                Ok Cifta interesting good to know that there are magnets with polarized face
                                I posted this 10 pages ago -it seems people really don't want to see the truth, they get caught up in the shinny parts and reality just fizzles away in a puff of smoke...
                                Ok Dragon maybe it was a simple motor but was very geniusly built to hide batts.
                                Regarding this Zilano schematic did anyone had success on this? Can one use a flyback instead of Tesla coil without coils?
