  • DJ,
    Thanks for sharing. Glad to have you here. Please help me if you have time. The pdf files I posted have a lot of information and one guy just can't sort through it all without the help of others. Zilano started helping us at one point and it looks like she continued to upgrade her circuit until she left us. So, it's a bit confusing unless you see that she was constantly making improvements to her device and then look at it that way. Looking forward to hearing from you and others. We have to sort all of this out fast.
    My e-mail is: [email protected]
    Best Regards,
    David Fine / Slovenia / Fiditti
    Originally posted by DilJalaay View Post
    Thank you very much. Its korean patent for "Electrical energy conversion devices using the resonant circuit"
    Some snap shots for study purpose guys. it very much resemble with zalino post.
    Would love if some on translate in good English.
    Regs to all.
    DJ
    P.S:Just join you guys, space please.
    • Att - soundiceuk
      Mr cleans coil details
      In the first instance L2 was a BW coil 2404 TL 3 inch Diameter .. if you recall he decided to reverse the direction of the winds in one half at a later stage.Miniductor and Airdux air wound coils catalog
      and as per Don Smith he's removed a couple of coils from the centre
      In the demonstration we are watching He's decided to use a 2410 TL (if I'm reading 14 Gauge right)
      Perhaps I can also throw a bit of light on the ignition coils. Mr clean has used bog standard off the shelf car ignition coils Just like this 12 VOLT IGNITION COIL CLASSIC CAR POINTS IGNITION | eBay cheap as chips and easy to get... there is no rewinding to be done, by anti phase he means the + of one coil is connected to the negative of the other so that on the HT side to put it in simple terms one coil is sucking whilst the other is blowing, so he's effectively getting twice as much bang for his buck.! In transistor terms it used to be called push pull (sort of) the circuits here RMCybernetics - DIY Homemade Ignition Coil Driver
      the sig gen looks nice build or buy is up to you .. to build its here RMCybernetics - DIY Homemade Signal Generator with Pulse Width Modulation
      The one you show is very nice but its a bit ouch on the wallet but as you say nicly made and I think Mr clean bought himself one . As an alternative drive it with a function generator. And when its finished and working build a simple 555 circuit to match the output... The big advantage is it works and we have all the details and the camera work!
      • Originally posted by Slovenia View Post
        DJ,
        Best Regards,
        Yup, this was my very first post on this forum :
        Originally posted by bbem View Post
        Very interesting video and theory about OU:
        Physics of Free Energy Device, Revised (ejeong1's Channel - YouTube)
        By Eue Jin Jeong
        His blog:
        Dipole (Anti)Gravity, Magnetic Gravity, true Gravitomagnetism
        His patent:
        (Korean translate with Google)
        Look at the circuits.
        • I saw Zilano's last post mention the lightning arrestor.
          Problem with radiation comes from the linearity of the spark in a gap.
          Some time ago I had also wondered about circular xenon flash tubes - two could easily be fashioned as an active primary - though I was left wondering how long they would function for. Lightning arrestors may be more rugged, but still straight ?
          Then again, Tesla used magnetic pole pieces to arc the current within his ionised spark gaps, which would have reduced concentration of scalar beaming.
          • Originally posted by GSM View Post
            Then again, Tesla used magnetic pole pieces to arc the ionising current within his sparks, which would have negated scalar beaming.
            is PJKs suggestion of perhaps using a string of neons totally diss?
            • anyway I'm running a russian arrester right now on test with a string of neons on 20KV DC and it looks anything but linear ... quite erratic in fact DSCF0161.AVI - YouTube
              • Zilano old posts
                If you don't think it should be made available, DON'T download it for yourself and complain!!
                Don Smith Rep Zilano Posts Updated Jan 11, 2012
                Thanks for the interest!!!
                Hello,
                U did a great job. i already downloaded your file. i am reading it now am on page50. as soon as i finished reading. i will make up my mind, how to sort it perfectly.
                Regs,
                DJ
                P.S: I very much appreciate your contribution to FE movement Zilano. We all wish to see you again.
                • Missing Zilano Posts
                  Thanks DJ, there's also another larger 232 page pdf file with all of Zilano lost posts. I posted that link back a few posts if you want it too. There's a lot of info in there and it will take a long time to sort it out without a lot of help.
                  Hello,
                  Regs,
                  DJ
                  • Avramenko's Free Electrons Pump v1.0 by Jean-Louis Naudinand saves HF oscillator and LF oscillator ?
                    Well folks, it would appear that Zilano is done sharing here. One of my friends who is helping me found the post below. There are a lot of incredible things going on in and around page 56 of this thread.
                    It would be nice if we could get back to replicating the device guys. All this other stuff is nice but it's not getting the machine replicated in my opinion. I like most of you a lot, so I'm not trying to slap anyone.
                      Slovenia .... I'm glad you arrived when you did and realised what was happening or else ... all gone , I had a few bits saved but not enough..
                      • thigiru
                        Hi, i have tried to work on the signal generator and i believe it is fine now at 31khz. I'm in a fix on how to harness the power back to day-day useful energy. i have seen many plans where a spark gap is indicated to be in parallel with a capacitor and an 80 turn isolation transformer coil. help me here since i think they should be as follows;
                        spark gap in parallel, capacitor in series with the isolation transformer coil or vice versa.
                        • Thank-You!!
                          Your very welcome!!!
                          • Could a Cyber Ciruits power pulse modulator be used to pulse a lightning arrestor/Xenon tube via a trigger transformer ?
                            As per Zilano's last. Could provide worthwhile options for tuning.
                            • Originally posted by thigiru View Post
                              • You serious? fwbr = full wave bridge rectifier ... did that just slip your memory banks
