Rant=on
Free yourselves of this nonsense that God(or insert your own master here) or anything in nature works off of 1/4 & 1/2 wave resonance.
It is this type of thinking, that is pushed by others, that destroys the imagination and pulls us further away. Lets understand this. There is no free energy in resonance of 1/4, 1/2, or whatever.
Look at it like this. If you wanted to figure out how the refrigeration effect works you would not build a copper/aluminum coil and worry about calculating the F.P.I(fins per inch), C.P.D.(coil pressure drop), or size of coil. NONE OF THAT STUFF will tell you anything about(or get you) the refrigeration effect. BUT the more of your time I burn speaking of components that DO NOT create the effect the more time I buy for someone else.
In refrigeration we deal with 'Latent' heat (aka Hidden heat) this form of heat CAN'T be measured by our meters, we can only measure sensible heat. This hidden heat is the basis of refrigeration without it you have nothing. Latent heat (removal or addition) is what creates a change of state (liquid -> vapor or liquid -> solid)
I can show you this effect by taking a cold glass of water out of the refrigerator and placing it on the table. Condensation will form, heat will be removed from the air on the surface of the glass. This is known as the refrigeration effect. At no time did I tell you that you needed (x) size coil and (x) type of voltage. We need to find and unlock the 'effect'.
My research now is telling me that the missing component in all these systems is nothing more then heat. Heat is a HUGE part of nature it is involved in the 'process' and in the 'exhaust' of the process.
Questions:
What benefit would I get if I were able to siphon off electrons from iron at a very low cost?
What can I do with these electrons?
Does the 'boiling' off of electrons resemble a natural refrigeration effect?
If these electrons, by the million/billions are accelerated and immediately stopped what happens to there energy?
-Core
Rant=off
Questions:
-Core
Rant=off
I guess that 1/4 wave thingy wasn't working for him in 1906
