Marko Rodin
  • #76
    Nassim / Rodin
    Hi DavidE,
    Thanks for posting the Nassim / Rodin stuff.
    Actually, there are a lot more videos... fun to watch:
    YouTube - theUMMCorg's Channel
    • #77
      bad astral beings...
      Originally posted by Jetijs View Post
      They all say that bad astral beings and elementals stay at about 15m radius from the pendants, they just can't get to the people that are wearing those pendants. Also people report increased vitality. Even I can feel something from them
      So does that mean if you, by mistake, turn the coil around 180 degrees,
      bad astral beings will be attracted to you?
      If yes, sounds risky. I'm always dropping my cell phone.
      • #78
        Rodin Wiring Diagram? Where?
        Can someone refer me to a nice URL showing the
        Rodin wiring diagram?
        • #79
          Rodin template
          @ morpher
          J. L. Naudin has a nice diagram of the 360 degree layout for the coil here:
          JLN Labs - TEP Project - Rodin coil test
          It is used here in a video demonstration:
          YouTube - How to build a rodin coil part 1
          For more info as to why it's wrapped this way, go here:
          Vortex Based Mathematics - Marko Rodin - Home
          Good luck and happy winding! I bet you beat my attempts at doing it.
          • #80
            re: rodin wiring table...
            Yes I found those URLs ... but still no details about wiring.
            So what I did was take that image, wrote my own numbers
            around the 10 degrees, and started to think about the way Jamie
            has wired it up -- with two circuits: 9, 18, 27 turns, etc.
            I see others wire with 3 wires together .. with a 3rd wire either
            NOT connected or just plastic empty of wire.
            So I wasn't clear on which approach is best ... or if they are both worth experimenting with.
            Also, I was looking for a more detailed explanation of why you need 9, 18, 27 turns ... since it seems to me that if you are trying to achieve a certain inductance, being restricted to multiples of 9 is an impairment .. unless there is a good reason -- beyond numerology -- for this.
            Also, MUST the shape be a toroid? Can a person wire this using a LOOP form -- like a hula hoop. You end up with what they call in the art world
            a "gods eye", -- more of a flat pancake style coil -- but I would imagine it would have all the same wonderful spinning magnetic field properties -- perhaps more in a widened cone shape above, however.
            Small wire gauges are no good if you want to pump in lots of power and keep resistance down and heat low. So this implies a BIG donut shape.
            Those fisher price plastic thingies are $6 USD or so.
            I was thinking an ART store with "wreath" styrofoam or wood might be cheaper. Don't rob a kid of some important learning toy. :-)
            The geometry of torus shapes can be complex as well. Must the
            tubular cylinder be a perfect circle?
            When you buy POWER toroid transformers, some are actually a squarish geometry which results in straight easy-to-wind wires and probably contains the magnetic field better. The Rodin coil wants a field .. wants it to BURST out of the shape. The Power is put to the field itself.
            Some thoughts on Jamie's videos...
            1. Nassim's suggesting about comparing to a standard coil is a good one .... BUT ... its sort of apples to oranges ... because the Rodin coil is all about "field" creation whereas other toroid coils are more about creating optimum transformers ... or optimum shunts, etc. So I think what should be demoed are various things you can do with this field ... which is an unexplored territory -- at least in the commercial sector.
            2. Plastic donut shapes are not hard enough and you have an air coil... So if your intention is to create a magnetic field that spins, OMG, lets add some ferro material in the mix. You would be amazed how much stronger a field you can SPIN. I think spinning say ONE TESLA ... would be pretty dramatic. Although for this experiment you would need to remove from the room ALL metal objects ... and keep everyone away BEFORE you turn the sucker on. You would need a large shape, and larger gauge wire.
            I was thinking more like an auto TIRE that you get from a junk yard ... and 18 AWG or greater.
            That youtube video would go viral...
            3. The speaker demo is fun ... and yes you can probably produce a speaker that is smaller in geometry with less magnetic material inside. Bose might be interested...
            4. Nassium has an animation for TWO toroids. Perhaps the notion of two Rodin coils facing each other ... might be something to experiment with. The Tesla switch notion of energy passing back and forth between two circuits -- a left and a right -- might be of interest.
            If it is true that once the field gets going, it has momentum and can kind of coast with less power ... and other spins can augment it ... as Jamie attempts to demonstrate with his magnet tops -- perhaps replacing those tops with OTHER Rodin coils ... might provide a way to PULL power from a central field creator coil.
            I'm just brainstorming here ... lots of possibilities with this thing I think.
            • #81
              A simple winding guide.
              Hi Just adding my simple winding guide..
              You have Wire1 (1-7-4), Wire2 (2-5-8) and Wire3 (The Extra-dimentional 3-6-9).
              Follow the numbers and you cant go wrong.. Easy.
              Does not address how many "wraps" to use.
              Cheers..
              • #82
                wire guide clarification
                Cheers..
                I messed around a bit trying to do it and quickly got confused.
                If you have a PIN at some number say, you have a choice when wiring of putting the wire on the left side of that pin, always, or on the right side of the pin, or 3rdly on whichever side feels arbitrarily the most comfortable.
                After wiring it around and around, I started to see the pattern better ... and so what needs to be clarified here is that you place the wire ALWAYS to the right of the numbered PIN (when that pin is pointed UP as you hold the coil in your hand). Lay each subsequent turn to the right of the previous turn... and so on.
                I suppose you could always put it on the left side of the pin and go the opposite way too if you were left brained and not right brained.
                Don't, however, make that choice arbitrarily on each pin...like I first did.
                • #83
                  As a Tesla Coil?
                  Hehe Morpher44,
                  You've got it now though! See you learn these practical things when you give it a go..
                  I have mentioned in a previous post here about winding a RC on a large hoola hoop or something similar. Maybe a monster truck inner tube! Lol.
                  However maybe a regular car tyre's inner tube will do me for now..
                  More interesting thing for me is to see what happens (if anything) if these Rodin coils can be used in a Tesla coil circuits, either as a primary coil, a seconday or perhaps both. Maybe even as an "extra coil" Hmm... Need to start winding.. Could be quite interesting..?
                  Has anyone here tried this before?
                  Cheers..
                  • #84
                    Rodin B fields
                    One Tesla is equal to a newton per ampere-meter.
                    So I think for a very nice B-field effect around the Rodin coil,
                    you are interested in current to the coil not high voltage.
                    Just a hunch.
                    So the "chopper" for a Tesla coil could be utilized to directly power
                    your Rodin coil -- instead of a Tesla coil primary.
                    Take care not to put too much current in so as to MELT your
                    wires ...
                    If you think about where all the wires are going and apply the right-hand rule, you can start to mentally visualize how the magnetic fields will arrange into a vortex.
                    With pulsed DC, you can make the spin occur in a single direction.
                    Someone noticed that if you alter the duty cycle (dc offset),
                    that you can alter the PULL the occurs so that it is off-center
                    in the Rodin coil. So a 50% duty-cycle will keep your magnetic
                    vortex centered.
                    On the outer circumference of the coil will be a SPIN that goes around its periphery.
                    If you use AC to the coil, the vortex and spin will spin left, then right, and possibly manifest on the back side vs. the front side, etc.
                    With high voltage, low current to the Rodin, something different might happen such as a more subtle electrostatic fields or something. Not sure.
                    Experiment experiment experiment...
                    • #85
                      Rodin Coil from Tuna Can Cylinder
                      Here is my first attempt with the Rodin Coil.
                      YouTube - Rodin Coil From Tuna Can Cylinder
                      I used a cylinder (Tuna can).
                      With ferromagnetic material in the coil, there is a dampened oscillation, as the field spins, long after the pulse was provided. Fascinating!!!
                      • #86
                        Rodin Ringing...
                        Here are some more detailed measurements.
                        Pulse width is approx 70usec.
                        Each pulse arrives 760usec.
                        Duty cycle is approx 9%.
                        Dampened oscillation has 4.8usec cycle width -- not sure why yet...
                        Diameter of can is approx. 99mm (*quick ruler measurement*)
                        Circumference 311mm.
                        Wavelength across diameter would estimate to be 330picometers or
                        3Ghz or so.
                        Wavelength around circumference would estimate to be 964.6Mhz
                        (1.0366 nanometers).
                        So I guess I looking for an explanation for why I see 4.8usec oscillation.
                        • #87
                          Spin Circumference?
                          Ok... I have a guess as to what dynamics are at play here for this dampened oscillation.
                          With low current, I see an oscillation of about 4.8uSec per cycle.
                          Boosting the current up a bit, I see an oscillation more in the
                          range of 4.6uSec.
                          This could mean that the shape of the vortex is changing with the change in current.
                          With low current, 4.8uSec, we have 1440 meters traveled approx.
                          With higher current, 4.6uSec, we have 1380 meters traveled.
                          So as the field intensifies, is larger, the spin circumference
                          narrows as would be found with NMR -- Lamor precession.
                          Anyone know physics well enough to know if this is the case?
                          • #88
                            Proton magnetogyric ratio
                            Proton magnetogyric ratio = 42.576 Hz/μT (also written 42.576 MHz/T or 0.042576 Hz/nT)
                            4.8usec is approx 4.89millTesla magnetic field strength
                            4.6usec is approx 5.11millTesla magnetic field strength
                            I guess to confirm this is the case, I would need a very
                            precise Gauss meter or something. This does seem believable though.
                            • #89
                              Rodin squeeze/expand idea...
                              I have an interesting idea here ...
                              The so called "right-hand rule" indicates the direction of the magnetic field relative to the current in a wire.
                              It also indicates the Force vector direction.
                              Around the Rodin coil we have a magnetic field that forms
                              a vortex or cylinder shape.
                              The Force vector can alternately "squeeze" your coil or
                              "expand" it, depending upon current flow.
                              This has interesting implications with respect to
                              piezoelectric materials or Casimir effects on capacitors.
                              Just throwing that idea out there in case someone wants
                              to noodle over that for a bit.
                              • #90
                                Rodin Coil and Bedini SSG
                                I've seen others hook up Rodin coils to the Bedini SSG and use
                                a spinning magnet.
                                With a coil constructed with ferromagnetic material, why bother
                                with something that spins other than just the magnetic field?
                                Who needs all that noise and inertia, wasting power?
                                YouTube - Rodin Coil used with Bedini SSG
                                Yes, you don't have a nice fan blowing on you, or a nice motor
                                to watch ... but perhaps you can use the magnetic field to make
                                monopoles as your batteries charge. :-)
