Marko Rodin
  • #31
    regarding his monopole - Could possibly only that tip be magnetized? the N poking out the end while the S is stuck in the middle? I noticed he did not measure the middle of his drill bit...
    Not to be a pissant skeptic, but thats what came to my mind. I'm planning on tossing him some cheeze anyway.
    • #32
      Hi Farmer
      I was thinking the same thing. As far as I know its impossible to only have 1 pole.
      • #33
        If someone could do a whole bunch of strongly magnetized monopoles, would that not be a first step towards a magnetic motor? Or would you expect that, even if it would work, the magnetism would be drained at high rate?
        Can anyone explain me why the drill bit didn't go crazy sitting in the core of the coil, when magnets can be spun to sickening rpms approaching it? Do all the forces cancel out for a 1-dimension item in the coil's axis?
        • #34
          I wonder if it could be used as a frequency generator to crack water
          • #35
            Pyromaniac generation.
            • #36
              Originally posted by DavidE View Post
              Freezer
              Beautiful! Let us know what you discover.
              Thanks, will do. It does seem to be a vortex field spiraling towards the center and out through the other side, also wrapping around circulating. If you take a small compass you can see that the field continues around in a loop but with this coil it seems to focus the field. Also if you attach the magnet to a string like a pendulum and hit the opposing field inside the hole it twists when it hits, so it seems to be a spiraling field with an opposing spin. I wonder if the coil was wrapped in the other direction would it be the opposite. I can already see that this coil design has a huge potential. I wonder if anyone has any ideas on driving circuits for this? Perhaps this could be used in the paul sprain motor?
              I was also thinking about the speaker idea as well. I wonder what nitinol wire would do? If that doesn't work, stick it in some water and try for hho.
              • #37
                15 >>> 50amps???
                YouTube - Rodin Coil Effects 1
                Note: The comments under the youtube video open some interesting dialog.
                • #38
                  Freezer
                  See if you can duplicate the setup (youtube video) above and report results.
                  • #39
                    did you see what jamie said here in the u-tube video comments
                    From my conversations with Marko the core needs to be air and the wire, whether 9, 18, or 27 turns, needs to be uninsulated because the energy should flow in the entire 10 degree path simultaneously instead of flowing through each individual insulated turn. Also, the wire should be thicker on the outside of the torus and thinner as it goes into the middle.
                    No insulation on the wires?
                    • #40
                      I a recent video, Marko is seen saying that he's been emphasizing the way he thinks the coils should be wound, even off-specification insulated wire winds also end up giving replicators powerful results. Like the around and through coil winding by itself make it all happen. Sorry, my English vocabulary and video recollection are lacking here. One should watch all the Rodin video's on Youtube anyway, even if they become a bit repetitive.
                      • #41
                        Im gonna have to build one, I wonder if it would circulate water in a vortex.
                        Lots of questions, ideas.
                        • #42
                          Should water not react...
                          I'd be interested to learn how much magnetic superfluid that nozzle could pump compaed to more conventional setups.
                          A horizontally placed larger diameter toroid containing the superfluid stuck thorugh the Rcoils. 2 coils yes, as that would be summetrical. Ready to levitate?
                          It seems a 2-dimensionally spinning magnet would never quite be able to take full advantage of the generated field.
                          I'd love to see Rodin's experiment priority list.
                          At least the plan seems to be to get many mangnets spinning off the coil's outer field, running generators, and feeding electrical energy back to source. Very commandable that they dare announce they'll try this.
                          Now, Rodin has mentioned that the coil wires should be thinner when passing through the hole. We see that wire get stacked up in there when wound around a perfect toroid. Compression and expansion. How would the current flow, when the wire narrows? More resistance. But, in a good way perhaps?
                          If there is a 3D printer material that conduct current, it would be relatively easily do, perfect toroid with many layers of wire, evenly wrapped around it.
                          A larger diameter toroid vs cross-section would reduce the amount of stuck-up as I'll call it by lack of vocabulary. Now, you see the donut hole being hardly bigger than the part you eat. Whether the large nozzle would negate the positive effects now seen in the "compact" Rcoils...testing would tell. If total diameter is 3 for a nozzle of 1, the wire variation would need to be factor pi, with a sinal half period of ~3 (wet finger in wind guess).
                          Such wire could be also pre-drawn at very exact specification, to vary in width exactly as it will be wrapped. Not easy for any wire maker I suppose, but technically doable nevertheless. A certain amount of elasticity and thin/thick marks on the wire would enable the builder to wind it ultra-consistent.
                          If the contantly vaying resistance would be unwanted, a thin/thick coating of neutral material could be considered, merely as spacing. The outside would be "insulated" (depending on coating chosen), the very nozzle bit naked wire. I suppose from existing insulated wire, the thickness correction would be relatively easily be carried out. Not the ideal, but worth testing.
                          • #43
                            yes still watching videos every chance I get..
                            Also I think my next one I wind I will use a torus shape with a larger tube dia. so the center where the wires cross is not at as much of a sharp angle. Try to keep all the windings touching the surface of the torus shape.
                            The inside shape being the shape my first coil was.
                            and the outside shape is the one I want to wind.
                            • #44
                              The unseen weapon.
                              Originally posted by barbosi View Post
                              I believe this is new...
                              YouTube - theUMMCorg's Channel
                              barbosi Rodin explains (in video 8 below) how
                              language effects the brain, brain size and which hemisphere is used.
                              The Hopi language uses the opposite hemisphere than that used for English.
                              This is WHY they have molded and distorted English
                              into this bustard language it is, English uses the other hemisphere.
                              This was done to put us into the material world, thinking in images
                              and away from spirit and nature, thinking with feelings.
                              This verifies what others have been saying that sounds
                              are important and how they directly effect the body, our minds and how we think.
                              The sound of the Hopi language causes the opposite hemisphere to be used.
                              Remember, "the words" are the weapons being used against us.
                              Randy
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 1
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 2
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 3
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 4
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 5
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 6
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 7
                              "the coil is baseed upon thirds and you must always have the space." Rodin in video #8
                              Rodin coil Front page Sedona News Marko Rodin & Jamie Buturff interview pt 8
                              Last edited by Vortex; 08-16-2009, 06:13 AM. Reason: added in order interview links
                              • #45
                                DevidE, you did not inform everyone this is Jamie Buturff's video.
                                Jamie Buturff is working directly with Mark Rodin.
                                YouTube - jamiebuturff's Channel
