[QUOTE=wwdotme;71936][QUOTE=Jbignes5;71933] Hey could you make the lower circle closer to the middle section by a half a real inch? that might be closer to my design. What would help you is to take the anagram and look at the length of the straight lines compared to the others. What I know is the longest line is the sum of the other 2 shorter ones on the lower lobes. there are 3 lines that make this design up. Go from 1 to 2 2 to 4 and 4 to 8. Thats the set of wires. The sum of (1 to 2) + (2 to 4) = 4 to 8. No matter what the lengths they will always be correct if you follow that equasion.
........._____ <-grid +
........._____
.......________
...........___
...........___ <-grid -
ok will work on that have to work this afternoon so will be later tonight
beore i get a chance to work on it.
I also noticed the distance from middle loop to bottom loop is twice teh dist. of the top to middle loop
am I correct thier?
The distance should auto correct itself including the circle size if you follow the math. Like I said no matter what the length of say the longest line say 6 inches should be the total of the other two. Start with the logest 6 inches and the others should be 2 and 4 I believe could also be 2.5 + 3.5 <- probably is that... Can you use measurements in your program or are you doing it free handed?
Oh and Thank you for all the help! It is something I never got into was the actual picture design process.
........._____
.......________
...........___
am I correct thier?
