fifteen 20KV caps in the mail !!!........you lucky SOD !!!!!!!! gimme a couple so i can do the tesla hairpin circuit !!!!! lol
Electret experiments
see: Right Angle Circuitry - or - AC Electronics for the Alien Minds - SCIENCE HOBBYIST: Right Angle Circuitry
- - - - - - - - -Originally posted by mikehingle View Postsee: Right Angle Circuitry - or - AC Electronics for the Alien Minds - SCIENCE HOBBYIST: Right Angle Circuitry
Magnetic Shield Corporation / Mu Metal Wire
A-Field Intensifying Coils with Mu Metal
Used for Amplifying Electrets
Magnetic Shield Corporation manufactures and supplies magnetic field shielding MuMETAL®, specialty alloys, custom fabrication, products, and solutions.
Scroll down to the bottom to Co-Netic AA Wire
36 gage = 0.0050" = 0.127 mm @ $70.00 / lb ($100.00 minimum)
22 gage = 0.025" = 0.635 mm @ $47.90 / lb
So, if you wind this Mu Metal wire around your toroidal electret wax mold,
you can provide a constant induced A-Field charge to allow your liquid wax
to solidify within a perfectly aligned & highly charged electret field !!!
Doubling the Mu Metal wire mass windings will double the electret field strength !!!
Mike Hingle
Finally all the correct ingredients
Rosin - Vox
If only I had more time, this'd be done sooner..
Bodkins, myself and the 'x' back together. Mostly all good
- she says hello
no no no nono nnoooonnnoonnnno NO dont up the amp you need current NO amps Im shouting at you about this I have one working remenber i now that amp = Sh*tOriginally posted by Inquorate View Post
Sounds good though. We'll see, once I have one working (I'm going to try a flat disc next), then all sorts of geometries are possible.
I'm also going to up the amps a little, maybe use the mechanical switch to trigger a transistor.
And I found my last 4 20kv diodes. And I have 15 20kv caps coming in the mail...
And going to make hv fly-back too.
Lots of fun coming soon
less than 10 milli amp at the plate Ben big fat resisitor if you what to get it right HV type,
Did you mean high voltage and no amp?Originally posted by Bodkins View Postno no no nono nnoooonnnoonnnno NO dont up the amp you need current NO amps Im shouting at you about this I have one working remenber i now that amp = Sh*t
, now put on your best brummee!
