Hi All
Been busy But wanted to post this for others to think on.
Origanaly in Cloudseeders Gravity wheel threed.
Here's another concept I'm working on.
A wheel with multiple two plate capacitors around the rim with the posative plates in the same direction. (Electret?)
Sense its known that the cap looses 10% of its dielectric weight when charged with high Voltage (in the 25kv range).
Wouldn't this cause spin force????????
I perceive Glass as the best dielectric w Aluminum foil as the plates.
If a wooden ring holding coils on the wheel and two stationary sets of magnets, one on eather side of the wheel all oreanted the same s-n direction. wouldent the coils conected through diodes build a charge if connected to the caps????
What of an ring of electret's
Originally Posted by FrozenWaterLab
Yes I am considering Perm Mags to reduce friction.
The motor mags sold by The Magnet Master should work well they have a curved surface and their are two sizes, where one will fit into the other.
This is a link for a set of 4 ea N-in & S-in You will need "2 Groups"
Use N-in on one side ans S-in on the other
4 Pairs Neodymium MOTOR Magnets 2"ODx1.75"IDx1"L N40SH - eBay (item 370274107375 end time Oct-19-09 14:00:06 PDT)
Then this is the inner set
Neodymium MOTOR Magnets 1.5" OD x 1.25" ID x 0.75" L - eBay (item 320136323294 end time Oct-26-09 15:33:25 PDT)
I will also use Pillow blocks also on the shaft to aline in all directions and the Water floats to add additional suspension that is adjustable to need.
Face it if it wont overcome the friction its not going to generate additional power.
This is alot of fun aint it.
FrznWtr
Originally Posted by TRON
Use maglev bearings at the ends of the shaft...magnets that are self centering in a pair, floating axle, zero friction...is anyone considering this?
FrznWtr
