Hubbard Coil
  • morpher44
    Heterodyne PHI Ratio Frequencies - DOH!
    So over the holidays I started winding some Hubbard Coils again.
    I absolutely KNOW -- somehow -- that Hubbard's PHI relationship matters,
    so I took care to maintain that relationship between the diameter
    of the center core and the 8 smaller cores.
    Now playing around with my pulse-generator and my scope, I can see that these air core coils I made self-resonate at:
    53mm diameter ~ 536.5Khz
    32.76mm diameter ~ 868Khz
    So that is interesting. The frequencies here maintain that PHI ratio.
    It makes sense because Fr = 1 / (2*PI*sqrt(L*C))
    and if you compute the ratio of the two Fr values, substituting
    L*1.618 for one of them, you see that the frequencies will maintain
    that ratio too. NOTE: Assuming the C value is approximately the same.
    This is an interesting property -- and MUST have been intentional.
    I did a quick search of the web for Frequency times PHI, and I found this
    URL:
    Phi: The key to zero point.
    Hubbard you sneaky dude!!!!
    I gotta build me this thing again.
    The claim is that you can get 3x power over your input ...
    and some replicators have claimed that they have gotten this.
    If your coils are nicely matched here such that the PHI relationship
    is maintained physically, with same turns on each coil,
    you should be able to heterodyne the oscillations and
    maintain this strange mathematical magic.
    Wow!
    --morpher44
  • morpher44
    sacred geometry - 8 small circles around 1 large circle
    File:Marsh-chapel-window.jpg - Wikipedia, the free encyclopedia
  • Dave45
    LT superconducting wire
  • Dave45
    Excellent Morpher 44
    Thanks for the link
  • morpher44
    wow - Publication date Oct 3, 2012
    Patent EP2505807A2 - Self-sustaining electric-power generator utilizing electrons of low inertial ... - Google Patents
  • morpher44
    Hi Dave45
    Morpher44 you still around?
    Yes. Youtube is the best place to reach me....
  • Dave45
  • MonsieurM
    Moving to the crystal thread would be fine, I was blown away by the link you posted there about the earths core being a crystal form,
    Falls in line with my research and theory's
    absolutely blown away
    Iv been interested and researching free energy for about four years now, and somehow you just know that you know when something feels right.
    I believe wholeheartedly that this is the path, not that there are not others but this is the true path to free the world from the grip of enslavement.
    When perfected it will be cheap, so cheap that anyone can build it with things that are readily available.
    How do they know which thunderstorms contain the most lightning
    Thank You Lord Jesus for the gifts You bless us with
    Job 38:22
    Glad to have been part of it, and happy you found your answer
  • Dave45
    Job 38:22
  • MonsieurM
    I agree water absorbs energy
    Iv been pondering upon the magnetic field and what it is.
    At first I thought that it was electrons highly energized and high frequency but when an electron that is highly energized moves through matter it causes damage.
    Iv came to conclusion that they are subelectron particles,
    If we pulse a magnetic field we are able to get electrons into a conductor but if the field is not pulsed no electrons,
    I think when the field is shut off the oppositely charged highly energized particles combine and create the electron if indeed it is electrons that constitute electricity.
    I also believe it will take a crystal structure to capture and control this energy efficiently, using the magnetic field of an inductor to bring the particles to the crystal core.
    Dave are you aware of the subquantum kinetics physics by PAUL A. LaVIOLETTE
    The continuous creation of physical reality from the transmuting ether as portrayed in the subquantum kinetics physics methodology
    Scientific predictions made by subquantum kinetics
    ‪TOAFN's Channel‬‏ - YouTube
    see also this post: i present my little theory of reality ( a personal opinion )
    and this post i mention Dr LaViolette's theory:
  • MonsieurM
    Dave45, would you mind we transfer our discussion over to http://www.energeticforum.com/renewa...tml#post148312
    since we have entered the crystal subject, i would think it more appropriate, and leave Hubbard's 2 words research to be continued....
  • MonsieurM
    here is an interesting info for you, just found it and kind of made sense:
    USU geophysicist links quartz deposits to mountains and faults
    Geophysical measurements collected in the western United States USU geophysicist Tony Lowry says quartz is key to rock cycles resulting in large-scale deformation of continents. Image courtesy Tony Lowry, Utah State University.
    USU geophysicist links quartz deposits to mountains and faults | The Salt Lake Tribune
    see also post: http://www.energeticforum.com/148190-post73.html
  • MonsieurM
    you are pretty much agreeing with Edward Leedskalnin, and i think you are using the correct terms
    From the experiment with the car battery you can see the principle how permanent magnets are made by North and South Pole individual magnet currents running in a single wire from battery. How did the magnets get in there? As I said in the beginning, the North and South Pole magnets they are the cosmic force, they hold together this earth and everything on it. Some metals and non-metals have more of the magnets than others. The North and South Pole magnets have the power to build up and take down, for instance in welding, in electroplating they put one metals on the other, and if you burn a metal too much in an electric furnace the metal will disappear in air.
    Edward Leedskalnin: Magnetic Current
    see also: http://www.energeticforum.com/renewa...tml#post148305
  • Dave45
  • MonsieurM
    The fractal of the electron is all around us expressed in creation as the golden mean or the fibonacci sequence in nature.
    In Total Accordance with you, if you consider an "electron" with a high energy- high frequency spin is radiation, Radiation being part of The electromagnetic spectrum, it would naturally mean that the electron with its energy and frequency is the electromagnetic spectrum
    so in the picture i posted earlier, just replace the words eletromagnetic spectrum with electron energy/spin
    pretty unconventional isn't it? (see the conventional table of electromagnetic spectrum here: http://www.energeticforum.com/147365-post58.html
