Tesla Attempt
  • #16
    a lil update
    just tested the circuity posted in my last post with the ignition coil
    and it works great :-)
    got high voltage on the coil side.....NO HV on the 55 side :-)
    Thanks for the suggestion Aaron !!!!!!!!!
    • #17
      Originally posted by rave154 View Post
      heres my latest attempt with my pathetic knowledge of electronics
      even IF this sschemtic is correct...
      what are the values of R1, R2, R3 ?
      Thanks for any help.
      David. D
      That is'nt pathetic!
      You can try to use Potentiometers as Resistors for the first,
      till you find the right Value, and when you dont use to big Current, what can destroy the Pots.
      Advantage is, you can play better around with.
      • #18
        Well done
        Stage 1; signal generator - complete
        Tnx for the schematic, it'll go in my file for 'working schematics'
        Love and light
        • #19
          Thanks for this great little thread
          Love and light
          Rave154, Ren, Inquorate, Bits, Joit, and Arron-----Thanks for this. Like Inquorate this circuit will go into my circuits file. I wish that I had been using this way back during the CFL projects. It would have saved alot of 555 chips from their smokey death.
          I think that I will build this signal generator as a separate unit in a box of it's own and just run it off a 9 volt battery. Maybe use a CMOS chip.
          This optoisolator idea was a good one. May all 555s live a long and healty life now.
          Rave---you might want to heat sink your 2n3055. She is going to get pretty hot. I put two 2n3055s together ( just bolted them) in parallel. That seemed to work. At least it was an easy heat sink.
          Lidmotor
          • #20
            thanks guys
            Inq & Lidmotor,
            its quite an honor to have you guys make permanent something i made, especially you lid, you'll have to come up with a name for it, Maggie, Hewey, Dewey, Lewie ...and.........i dunno?
            Ive got a lightning storm happening as i type this......how appropriate :-)
            Lid, it willl run off 9V nicely as i already tried that before taking the plunge and using my lovely two new YUASA 12V(7AH) batts that i aquired from work for nothing...*clears throat*
            yes i will heatsink the 3055/s now that i managed to remove a heatsink from the circuit board of an old CRT, at first i tried to de-solder it !!....DUH !!!!sitting there with the solder iron pressed tight against the solder for about 10 minutes until it dawned on me what was happening !! DUH !!! lol
            i am now going to try the avramenko plug on the end of the HV lead, later i will try using my other ignition coil in "anti-parallel" with the first one.
            in closing just to say thanks for all the help, thanks for this forum and the bringing together of all the bright, open, free-thinking minds that use it ( I barely just about include myself in that list !)
            here is the first replication of Karl Palsness's replication of Tesla's hairpin circuit that ive come across ... good viewing........especially that spark gap......ferocious it is !
            YouTube - xc power transmission with tesla hairpin circuit
            Thanks a lot,
            Adios & Ahimsa,
            David. D
            • #21
              just noticed something
              Amid this lovely raging lightning storm that is right over me here!!! i just noticed something..
              when the circuit is running, i was using my trusty lil neon held with insulating pliers by one of the legs to check for HV over the various parts, i placed the neon over the CFL and let it rest on top of the glass of the CFL...it barely glows...however...when i touch one of the legs of the neon with the pliers even though they are insulated the neon lights up......also...
              when i run the tip of the pliers up and down the glass of the neon, the illumination inside the neon follows where the tip of the pliers is.
              dont know if this is significant or not, just thought id report it.
              just out of curiosity, i just rested another CFL on top of the first CFL(Which is wired to the HV), glass-to-glass(no electrical connection)....it doesnt light......however...
              i rested the neon on top of the 2nd CFL as dewscribed above..and again....when i touch the tip of the pliers to the glass of the neon...both the CFL & the neon light up....also get the same effect in the neon with the orange glow following the pliers movement. :-)
              • #22
                Pretty lights
                @ rave - fun finding all these quirky, unexpected phenomena innit?
                Here's some vids from me finding more of the same.
                YouTube - Inquorate 21
                YouTube - Inquorate 22
                YouTube - Inquorate 23 detector
                I have to admit, I hoped I was playing with radiant energy - but if so, I now expect that it was less than 10% radiant, and still tangled up in the more run-of-the-mill HV RF electromagnetic waves.. Hot electricity.
                Love and light
                • #23
                  From Singularics.com:
                  We expect that given time and resources for further research and development, Singularics will one day lead the market in next generation power transmission systems.
                  And WTF is XC Technology and XC Power Transmission?!
                  Where do these people get off?!?!?!
                  Tesla discovered the Radiant energy and perfected the system of its utilization 100 years ago and now some jokers put a video up on YT without a mention of Tesla, then go on their website how they'll "lead the market" - by rebranding something that has been done 100 years ago?
                  Do they think that nobody remembers or knows about it??
                  XC Technology?
                  ARGH!
                  • #24
                    inq, yes it is fun,
                    btw....i should mention, that most if not all of my messages are "real-time" as in.....im typing this stuff either as im doing an exp' or just after an exp' and just before another exp as ideas pop into my head........and on that note.....ill brb sec...
                    ouch, that tingled a bit lol
                    damn...hmm......ill be back
                    Ahimsa,
                    David. D
                    • #25
                      hmm
                      see the circuit attached,
                      if i turn the circuit on, for maybe, a second or so, then disconnect the battery from the 555 side....and also disconnect the battery from the HV side...
                      if i hold one leg of a neon to touch one of the ends of the bi-filar..the neon glows, not very bright....but its glowing....and it stays glowing for maybe 20 seconds or so....hard to carry on longer as hand vibration disconnects it. this coil is powering this neon...and it isnt connected to ANYTHING at all.
                      for some reason, its reminding me of the Ed Leedskalnin PMH, which was an electro-magnetic-inductive effect.....this appears to be the same.....but a HV-capacitive effect in a coil?
                      • #26
                        oops
                        i should mention, the blue zig zag thingy in the diagram......is a spark gap, two brass screws etc.
                        • #27
                          addendum
                          re my last 2 posts, the neon only lights from the left hand wire of the coil,
                          which is the wire which has the diode in opposition to the HV supply so to speak.....on the other wire.......doesnt light......bring it back to the left hand wire...lights up ( not bright but lit )... also..lit the neon for maybe 10-12 seconds........took the neon away..and touched both ends of the coil........zap on my finger!
                          • #28
                            Since this is a thread about Telsa technology and it hasn't been mentioned yet, let me recommend to you "Secrets of Cold War Technology" by Gerry Vassilatos--well worth the effort! That may go for his "Lost Science" as well, I haven't acquired that one yet.
                            • #29
                              shamus,
                              thanks for the tip, however, i am already aware of the book & contents though i havent actually read it ( I may welll get it ), and have read a number of Tesla's patents and lecture texts.
                              Just putting stuff together to try and find my feet so to speak :-)
                              • #30
                                reply to amigo
                                Amigo,
                                I agree totally with you, the whole " XC " new thing kind of pissed me off too, at least Karl Palsness gave complete credit to Tesla over & over and called it by what it is, radient / scalar / longtitudinal......why do we need to change that to "XC" ?????
                                as you so perfectly said amigo.....ARGH !!!
