Perpetual Motion Holder | Edward Leedskalnin
  • Coral Castle Code Broken ( i would tend to agree with him )
    The Last Stoic: Coral Castle Code Broken
    My name is Jon De'Pew and after a long road of research and much hard work I have recently discovered a visual code and I would like to share it with everyone....
    ...Ed Leedskalnin's revealed code is a perfect match to the clues left behind by so many ancient cultures such as the Golden Section, Golden Ratio, Phi, Flower of Life, Time measurement among so many other titles . I have found the same clues of this lost science in all the main cultures around the globe, on every continent. What Ed's code is leaving us with is that this ancient science Sacred Geometry was representing an advanced knowledge of Two Magnetic Currents and the Neutral particles of matter, they orbit as a common core.
    Signs and symbols -Confucius.
    • just FYI: Ed Leedskalnin agrred with Tesla when he mentioned in his book:
      Science says energy is canceled when Positive and Negative connect, but Ed said there is still something there when the electric is not. Ed Leedskalnin said that science is misled by this false electron principle. He said there are no electrons and the false conclusion came about by giving the cathode in a vacuum tube a double dose of negative, from an unbalanced power source that was used by Thomson
      Ed Leedskalnin wanted to call it magnetricity
      interview with Dr. Tesla from
      Popular Science - Nov 1928 - Page 16
      BESIDES his world power scheme, Dr. Tesla says he is devoting his time chiefly to his vertically rising flying machine. This aerial flivver is to weigh less 200 pound...
      ...On the whole subject of matter, in fact, Dr. Tesla holds views that are startlingly original. He disagrees with the accepted atomic theory of matter, and does not believe in the existence of an "electron" as pictured by science or, he maintains, if it can exist at all, it does so only in perfect vacuum...
      ...Even before the discovery of radium, Tesla expressed his belief that radioactive rays were of this sort, a view ridiculed at that time. When radium was discovered it was found actually to emit particles of matter ....Tesla has maintained ever since that radium is not a generator but a transformer of energy, the emanations being caused by cosmic rays of immense power capable of penetrating all obstacles however thick.
      Popular Science - Google Books
      • one more Comment on the website i previously posted:
        CORAL CASTLE CODE / JON DEPEW / FORMULA of ENERGY
        If you look close, when observing the broken code illustrations at my website, you will see the tubes that connect each center, this seems to be what these magnetic structures of nature use to distribute the energies within themselves and beyond. When these magnetic structures connect to other magnetic formations, they attach into a whole network linking all the centers to each other forming grid like patterns that seem to unite all into one unit.
        The Following is the definition of the Constructal Law (also called fractal law )
        The constructal law puts forth the idea that the generation of design (configuration, pattern, geometry) in nature is a physics phenomenon that unites all animate and inanimate systems, and that this phenomenon is covered by the Constructal Law stated by Adrian Bejan in 1996: "For a finite-size (flow) system to persist in time (to live), its configuration must evolve such that it provides easier access to the imposed currents that flow through it."
        Constructal theory - Wikipedia, the free encyclopedia
        • I've read through the thread and I don't see anything about what I'm going to suggest here. Has anyone put a third coil on the cross bar on a PMH to see if they get any readings or any output from that coil? I was just curious. I know I've had a PMH I made several years ago and I never thought to try that. If no one has done that I might have to drag out my PMH and give it a try, just for giggles. I can think of several different things I would like to try with that third coil, so I think I will do that over the next couple days. First, I have to clean out my basement to FIND my PMH.
          • Hi Turion,
            i did play further around with it, tried 2 U shaped Cores to connect with 4 Coils,
            2 for drive, 2 for pickup, tried a third Coil at a Bar, closing this U Core.
            Best i got with the 4 Coils set up in a kinda JT Style was a nice ringdown,
            and a Led did last few Seconds.
            The 3 Coils setup was not to amazing.
            One Reason i suppose was, when you put Power on the 2 Drive Coils,
            you close the Magnetic Field around the Core, the Pickup gets a Push but not more,
            its like a half Sine wave, thats why i tried 2 Pickups, that i can use them alternating,
            and with Load on it, it breaks the Path again, to restart the Cycle again.
            I had big Cores and about #30 Wire, maybe the Results are different with other Sizes.
            • I was wondering about that four coil idea. Using 2 to complete the circuit, then breaking the circuit and using the back EMF to hit the second 2 and complete the circuit again, switching back and forth. Meanwhile a 5th coil across the gate to receive the charge whenever the circuit is broken. Those are the kind of things I want to try.
              I still have my bike wheel with the 16 double magnets with the north poles glued together on it to use with the PMH. Or maybe it was some with North Poles glued together and some with South. I can't remember. Will have to get that out of the pile of crap too. I need a bigger basement!
              • To use PHM as geneerator you need to look at Daniel McFarland patent. Any simple pickup coil placed on magnetic path will drain energy by lenz law rule and stop stationary wave pattern. Only resistive load imho can be connected as resistance in the electrical part of PHM.
                • boguslaw,
                  Many thanks for that. Yet another thing to build and play with. Ain't life grand?
                    boguslaw,
                    it means you are alive
                    • Have you heard of the Kybalion , in my research, i found this interesting video which talks about it , and eerily reflects Edward Leedskalnin thinking (amongst many others ), you should check it out, it might inspire you , listen to it with the ears of an electrical engineer
                      The Kybalion: Hermetic Philosophy is a 1908 book claiming to be the essence of the teachings of Hermes Trismegistus, published anonymously by a group or person under the pseudonym of "the Three Initiates".
                      Kybalion - Wikipedia, the free encyclopedia
                      vid link in this post:
                      http://www.energeticforum.com/149310-post110.html
                      • perpetual electric motor
                        Hi, I was wondering if anyone has tried to charge a pmh with the discharge from another pmh and found out if there is any loss. If not you could make an electric motor that you dont need to power just by discharging into the next one on the wheel and reverse charging.
                        If one-half of the force that makes up the atom is in the core, and the other half of the force run around the core, then in that case the atom could not join the other atoms to make a metal that could hold two magnet poles. - Edward Leedskalnin
                        • PMH to PMH
                          i have been able to lock one PMH with pulling the keeper from another one. i do not know if there any loss but there was enough energy to lock the other PMH. they were both the same size
                          • Thats what i needed
                            cool, thank's, i'm about to go full scale test. I have made a small one with 100 ft 18G wire with steel but i want to replicate 'cause it will work better.
                            • Originally posted by Loadstone View Post
                              Hi all.
                              When the keeper is pulled of the PMH the flux changes and induces the coils.
                              Because of Lenz's Law the coils produce a current that runs the same way as it did from the battery.
                              So if you put a little D/C motor in series with the battery and charge the PMH the motor will turn, say CW. If you then remove the battery and connect those wires together, you can pull off the keeper and the motor will spin the same way.
                              Nobody ever talks about WHY Ed made the PMH.
                              He wrote about it in 2 of his published papers, but nobody has noticed.
                              Ed was able to study the ionosphere and wave reflection, plus he worked with radioactive materials, doing his own Alpha, Beta, and Gamma ray tests with film.
                              I think we can say that he knew what an electromagnet was.
                              "The hanging magnets that hang up and down, they show that there is motion inside the bar." Ed.L
                              Physicists Measure Elusive 'Persistent Current' That Flows Forever
                              So let's see if I understand this article as we currently know. When charged the magnetic current continues to flow, but only within the confines of the core circle, correct?
                              Also, I had a question for cody, when you switch polarities on a closed unit, does that cross bar still attract, or does it fall off freely? I am looking to see if you can switch the direction of magnetic current with having to physically break the circuit?
                              • Please ,can you put ammeter in series with coils then energise and watch what happen with current in coils and if PMH holding action is impaired ?
                                I bet everybody are curious about that ...
