High Voltage from Thin Air?
  • Things to think about
    @All
    Because the normal supply line for LED's is so expensive, most will not explore this, yet it is a good mind question. (Yes I have done it with UV LED's)
    Do the photons from the LED's influence the local excited environment? What I mean is, what might the effect be if a large number of excited LED's were arranged to focus on the area between two communicating towers.
    Now think of this also, the communications is capacitive (not inductive) turn one tower 90' and see if it has any affect, it does not and I will post a short vid showing this. Anyway will the photos cause an increased or decreased spatial disturbance?
    • Tower Coils and Communications
      See this, I just put it up.
      YouTube - Tower Coil Positions and Information Transfer
      See this RadioMan232 for conventional LC Resonance and how different this is from Spatial Resonance both is how it acts and in the energy transfer. Hey look at parts count
      YouTube - LED burning on electromagnetic waves / resonance
      I was told via PM that someone wants to post some damming info on ESEC
      • Photons and coherence
        I can vouch for the capacitive link between the towers, not inductive.
        And while 60 x 70,000 mcd LED's at full brightness didn't noticeably change the coherence for me (measurement methods quite dodgey and LED's driven by the Exciter), early Cat's Whisker radios and also Germanium diodes supposedly work better in sunlight, in that they become more radiowave sensitive.
        Sunlight being why I think you mentioned uv?
        it depends on what you mean by 'spatial disturbance'; sensitivity to change or difference in coherence?
          So, my guess is increased coherence. I'd love to see a definitive experiment though.
          @Inquorate and ALL
          Last post I can get in today, but think and try this.
          Can you see a difference in diode reaction (1N4148's and LEDs) based on positioning in reference to the capacitive top hat, can a difference be found by moving the legs of the AV Plug farther apart. Go back and look at the video where I place the LED's between the towers using two diodes each leg and the tin plate at the end, this is the idea to follow.
          Now assuming you can see what I would like you to see, why would the way the (wave) hitting the diode have an impact???
          • wave hitting diode
            Because the way to capture (convert to 'electron' movement) longitudinal waves is via capacitance and mass, whereas conventional EM waves is via inductance.
            And because longitudinal waves flow along capacitive / mass differentials, not magnetic.
            • Wish Circuit
              YouTube - SEC Exciter Lockup and Input Energy Required
              • Pure potential
                @ all, remember when lidmotor ran one tower off a wire from the first? That was running off the potential, no current.
                just like the one wire is the popcorn sphere or two metal bowls, or if both towers have ground wires (or the earth itself) or thru a common capacitive coupling like in my setup (the metal plate under my breadboard)
                So long as the towers can get in synch like this, then the scalar waves will cause electron movement in the tophat.
                This is where the cec>1 comes from, and why the receiving tower doesn't load the first tower (although it may change the capacity of the first tower's tophat and throw it out of resonance) whereas a pure electromagnetic coupling would load the transmitter.
                Correct me if I'm wrong
                • Two Tower Resonance experiment ---and the "floating eyes"
                  @`Dr. Stiffler and All
                  I have been fascinated by your last few videos so I tried to replicate some of the things using my trusty SEC 15-3. I tried the resonance experiment where you turn the tower 90 degrees to the first tower and the lights stay on and also the experiment where you wirlessly light up LEDs between the two towers and show the energy flow there. It worked. Here is the video of it.
                  YouTube - Dr. Stiffler Resonance experiment--- The floating eyes
                  Cheers,
                  Lidmotor
                  • cool videos
                    Hi folks,
                    again great vids and info being published lately.
                    Inquorate's latest
                    YouTube - observations of sec with RF suppression to psu
                    with the piezo-kick and showing the effect of the filter/choke behind the power supply was very interesting to me.
                    and @Lidmotor
                    What is the explanation for the fact that the hand held led "gets auto switched off" for a moment a 4:40 in the vid
                    It's like there was a hole in the field !?
                    • Connecting towers
                      Cheers,
                      Lidmotor
                      @ Lidmotor & all - can ppl who are connecting towers pls show how they are connecting them?
                      I did a schematic of my 'wireless' (now I think 'parasitic capacitive') connection here;
                      YouTube - how to hack tune the sec and run another wirelessly
                      Love and light
                      • Missing SEC18
                        @All
                        If you are waiting receipt of a 18x board and have a Tracking Number (US Only), please check the status. We have found some available but were not deliverable for whatever reasons. PLEASE check that number it came to you via email when it was shipped. If you have lost the mail contact Stiffler Scientific.
                        Hey a few of you dropped you email address right after ordering (Black Ops??) anyway because of this you did not receive confirmation and did not receive a link to the documentation that is sent via email when board is shipped. Contact SS if you want the documentation.
                        Non-US orders, if you have concern contact SS. All orders have shipped, no problems there, contact SS with any concerns.
                        • If you have SA, Need Help
                          If you have a Spectrum Analyzer that can see down to <100dbm and are willing to invest an hour, I request your assistance. This info from many different physical locations is needed to fine tune the self running systems. Contact me via my email at SS, NOT PM on this forum.
                          Thanks....
                          • not capacitive
                            investigating how non-conventional the energy transfer is with the sec 15-3 and two towers. Energy can be transmitted thru a broken wire and appears not to be capacitive either. It's life, jim, but not as we know it..
                            YouTube - sec 15-3 tophat communication, not inductance, not RF, not hv, not capacitive either?
                            Love and light
                            • Hanging one's flag in the wind
                              Hi Inquorate.
                              nice effect with your aluminum-flag sensor in
                              Dr. Stiffler and also Lidmotor have demonstrated that there is evidence for a 'capacitive field' created by the exciter in between the towers, that can power leds via AV plugs.
                              But you are lighting the led on the aluminum-flag "straight" without a proper AV plug, right?
                              I think the magnetic flux created by the earth magnetic field is involved in your result.
                              I suppose your aluminum-flag may pick up the interaction of "two forces", that is of the capacitive field created between the top-hats and of the flux from the earth magnetic field.
                              If that is true then it would make sense that this flag/catalyst has to be oriented/aligned properly with regard to the two forces.
                              Or in other words,
                              the aluminum flag (probably) gives out a current - when placed in the electrostatic field created between the towers if at the same time it is aligned at the proper angle in regard to the magnetic field of the earth.
                              I hope that further experiments will reveal what is really happening.
                              Looking forward to it.
                              edit: would be interesting how a flag from copper would behave. And/or whether it would light the led at the same angle, considering copper being diamagnetic and aluminum paramagnetic.
                              • Tower connection &amp; energy field shape
                                @ Inquorate
                                I have the towers on this SEC15-3 hooked up like this:
                                Tower (1) start of coil is connected to the collector with the end of the coil (bottom of top hat) connected to the start (bottom) of the coil on tower (2). The center taps are not used.
                                I tried all kinds of ways but this worked the best for me.
                                @ Marxist
                                The energy field around the SEC is uneven and might actually be moving. There are hot spots and dead spots. I think that all the objects near the field are affecting it. Maybe EMF, RF,and stray capacitance are all doing their thing to scramble it up to. If we could see it, it might look like the ocean on a stormy day. I'm just guessing here and Doc probably has a much better sense of what is happening.
                                Lidmotor
