@ Nick and all,
That's a big question I can't answer yet. I'm not sure you can run 50 off the E-C junction. The LED can appear as bright as "normal" without it's required full stated current. There is a point where adding more current makes it no brighter which is why the Base is tweakable. The JT takes a low voltage that won't light an LED and rings it up through the toriod to 30+ volts on the primary side and many hundreds of volts on the secondary. Jenna stated 7v on the secondary per LED. It appears that the higher voltage is being used to "trigger" the potential to light the LED and then comes the fun. You adjust the resistor of the JT transistor Base to charge the toroid till you get the brightness you desire. This will increase the current load of the circuit. That's where the 555 is so beneficial. It takes time for the toroid to charge and collapse magnetically. So, rather than have the LED's on the primary side constantly loading the battery, its actually flashing the LED's on the secondary faster than the eye can see. But, it only has to be "on" abt 15-20% of the time. Not much different than regular lights in your house. They cycle 60 times a second and you never see it. The low power 555 does require 3v min to work so 2 AA are needed. I'm pretty sure I have a schematic saved that adds a second transistor to pulse the JT Base so a single AA can still be used.
This is where the ratio of windings, the wire size and core size come to play. The scope pics show a huge spike on the primary & secondary as the magnetic field collapses. A standard meter will not catch it as its to fast. Normal teachings say when you cross a transformer stepping voltage up, the current is reduced. You can increase current by stepping the voltage down just as well. The JT is utilizing ignored things that happen which traditional thought felt non-useful or not worthy of notice. So, it was wasted as an "excepted loss".........till now.
This is where the JT, Bedini and its associated add-ons intrigue me so much. They are squeaking everything possible, so far, from what was once thought useless making it now useful. My having a background in the field actually makes me no better than anyone else building these. It was never taught. It may give me a better understanding of what is happening, but I'm as much as a neophyte as others are here. This is all out of the box thinking and I love it. A person with no electronics background isn't bound by the rules that were forced to learn as "the absolute law". Many new discoveries are made by people with no background because they haven't been mentally handcuffed.
This is where reading the entire threads means so much to me and there are so many. You see the start, improvements, failures and growth. You'll also see trends like I described of what leads to better outcomes. They are better but not necessarily the final best as everyone is using materials available many times. When you can make such things from scrap others throw away, all the better.
Thanks for the comment on the toroids, all were bought from ebay. The 10 2 3/8" cost me $2ea after shipping. Not a bad score. I need to contact the seller to see if I can get a part number or try to find the material type. My guess is they are "J"s. If I get something going well, I now know I can do much better by just repeating it with a "W" core and less wire. The Fuji camera transformer is a JT circuit. It's less than 1/2"sq "E" shaped core. Look what it can do and read the comment below the vid. 400 leds from an AA! YouTube - Modified Fuji Circuit Joule Thief circuit lighting 40 watt tube with AA battery
Makes me wonder what can be done with a Goldmine or 2 3/8" core!
My apologies to all for the long posts. It's just my passion showing through. I will try to do better.
I agree with you about (" The Absolute law ") I've had people to get mad over me saying It is not written in stone just to find out I was right a year later. And don't worry about the long post's I enjoy reading a well written paper,and it give's my mind a work out
Tec
This pic is in a fully lit room.
Thank you for all the help sorry I cant get on has much as I would like too.I looked at your build great work
