Flunn paralell path!!!
  • #91
    Originally posted by Jetijs View Post
    Hi sciencisto
    Lol, I think I will have learned Polish language from your videos soon!
    Great stuff. I am impressed. So have you any ideas on how to recover the energy directly to the input? Maybe this circuit of my attraction motor will help:
    It uses bifilar coils so that one strand of each coil can be used to power the motor and other strand is used for the recovery. If you don't have a separate winding for the recovery, it is very tricky to recover the power to the input directly. This might work in your motor also, but additional strand of coil could be needed. This way your motor might reach OU, I certainly hope so.
    Thank you!
    HI Jetijs,
    Bifilar coil is necessary for "absorb" all energy released from Parallel Path motor, also Prof. Kanarev us similar method but different motor/generator.
    You need to update circuit and use two battery pack, one for motor one for generator.
    Sorry but I don't understand your circuit, you use two transoptor ITR8102 for powered in different time coils? An your reply is appreciated. Regards
    • #92
      Hi Alex,
      I used that circuit only because I am familiar with it. Two optoswitches are there just because I did not know better how to make a bipolar circuit that would use only one winding, so I made two windings on the coils and used two identical circuits to power each coil at exact moments, one for the positive half cycle and other on the negative half cycle. Circuits that sciencisto uses are better, because you can use only one winding to do the same thing
      Hope this helps.
      • #93
        Hi Alex,
        Hope this helps.
        HI Jetijs,
        But that circuit work fine with your PP motor 2 coils or have problems?
        • #94
          I am not sure, my motor has many problems, starting from too small square area for the magnetic flux to pass through causing magnetic resistance and stray flux and core over saturation. The best efficiency was around 40% and I am not sure if it was because of the design problems or because of the circuit I used. The motor is now given away to a friend who will test static force measurements without any circuits. I am not in the beginning phase of building a new 6 pole motor without those design problems and with calculated power of around 2kW. Will test all the circuits I can get on that thing
