Flunn paralell path!!!
  • Flunn paralell path!!!
    Looks like somebody as come to an interesting motYouTube - motore di flynn 12 polior!!!
    Take a look at this and enjoy!!!!
    Have a nice day!!!!!
    Alain D
    Hope die last!!!
    You should fix the link.
      Thank you !!!
      The link is fix now!
      Alain D
      Hope die last!!!
        Thanks to God!!!
        Now, there are many people with open eyes !!!
        The ideas!! Charles Flynn motor!!!
          Originally posted by darkwizard View Post
          Thanks to God!!!
          Ye, and i wonder, that you didnt post the Link and used it in one of your Phrases,
          but at last, seems you are the one with the open Eye, even only, when you expect a OU-Device behind this Thread.
          Now you can rebuilt it, and show us a Result, as instead only Links and your Ideas.
          This Vid comes anyway from Overuntiy to us, like much other Ideas.
          But i posted about Flynn's Paralell Path at my first Posts,
          but seems noone was interested at it, and he allready wrote at Peswiki, that he will know, that one Day,
          someone will come, and connect a Generator to his Motor.
          You even can buy his Motors over theyr Webpage.
          Anyway, his parallel Path is interesting, and worth to Think about it.
          There must be more, what you should can do with it, as to build a Motor with it.
            The Flynn Parallel Path technology is a very efficient way to direct magnetic current, and consequently lends itself to any application involving magnets. The Flynn technology takes advantage of the tendency of magnetic current to continue flowing within an established path, even though other paths are available. Unlike electrical current, which will take any and all routes available, magnetic current works differently. Magnetic current will only flow when the ferrous molecules are aligned properly. In an established path this is the case. Outside that path, molecules are aligned randomly and present a higher impedance to the current.
            Directory:Joseph Flynn's Parallel Path technology - PESWiki
            PPMT TechnologyDirectory:Hilden-Brand Electromagnet Motor - PESWiki
              Joit!!
              You seem pretty frustrated,do i did something wrong?????
              Alain D
              Hope die last!!!
                Hi Peper,
                If you did something wrong? No, Why?
                I did not even Quote you at my Post.
                You did only post the link from the Vid. What can you do there wrong.
                And i am not frustrated, just wanna point out too, that there are more then one Posibillity, what you can make with Parallel Path.
                But therefor, i need no Phrases, like Now there are Peoples with open Eyes
                and endless advices, what leads into Dead Ends and start celebrate from a Vid, what shows nothing, when you dont get a real Proof.
                No Problem with you, Peper.
                  I`m currently on a project Joit, please!!
                    Alain D
                    I posted about this awhile back. topic: Video shows 175% output
                    I did not know what I was looking at but
                    I thought someone else at the forum might know.
                    I'm glad this got some attention with your posting Alain .
                    Randy
                      Hi Randy!!
                      That`s so much new technologi on youtube, I was sure someone else
                      ad seen this..
                      BTW;this motor is not the average home builder project!!!!
                      I`m sure that [KEKKO guy] is from a university in italy.
                      I have seen this guy somewhere else for sure.
                      Anyway i`m verry happy that this motor catches our eyes..
                      As Joit say`s:this technologi can take place with another form.
                      I hope you have a GREAT DAY my friend.
                      Alain D
                      Hope die last!!!
                        It seems to little Bedini on DVD, uses 9 volts battery.
                        Too is like magnetic gate, is good, that produce good torque. Have you the schematic to look the switching system?
                        Steve Jobs. Apple CEO
                          @Ted
                          Do you get any Idea of the Generator, what you want to share ? :P
                          i am still looking for a Setup for a Generator, and right, the Egbert Generator seems still have some drag at the Iron.
                          Right now, i dont have a good Idea, how to use the 4th Side from the Parallel Path.
                          Seems there is a new Entry at Peswiki for making a Motor with simple Transformator Layers
                          Directory:Flynn Parallel Path OEM motor - PESWiki
                          • #14
                            @Ted
                            I'm just about to build and test a generator concept based on the Flynn and Hildenbrand technologies.
                            As you can see in the drawings, the magnets are encased in a steel jacket, around which is wound a coil, just like the Hildenbrand electromagnet. This coil would be a bifiler wind with an energizing coil and a collection coil.
                            Normally the magnetic current will travel from the magnets and through the jacket from one pole to the other, as in #3. However, when the inner coil is energized, it reverses the domains in the jacket, cutting off that return path for the magnet's current (#2). The current is then forced into the outer coils where it is used for power. This current (flux) is twice the current of the magnets alone since the inner energizing coil is adding at least as much as the magnets to be able to reverse the current flow through the jacket.
                            For one unit of magnetic force I get two units traveling through the outer coils. This is where we pick up extra energy. We also pick up some energy from the inner collection coil since any change in current direction produces power.
                            The next pulse is in the opposite direction through the inner coil. This is necessary since the domains in the jacket won't switch all by themselves (won't switch quickly anyway). This "reset"pulse only needs to be a very short duration in order to realign the domains. Once the current flows from the magnets, the inner collection coil again produces power.
                            The pulse frequency, voltage, and power would all have to be figured out. The engineering of this unit will take a while to get dialed in. However, there is undeniable gain every time the magnets get "switched". Increasing the efficiency will only produce more power.
                            I'm going to start construction this weekend. I need to design the outer cores to handle the increased current and efficiently transform that into power. Lots of parameters to consider but I think the basic Idea is workable.
                            I need to figure out a switching circuit to control the coil, but I have to do some tests first to determine the amount of power needed to switch and reset.
                            If you or anyone else wants to build one of these things that would be great.
                            Sharing ideas and solutions is always more productive.
                            Here are a few basic drawings I made. I put them in a public photo folder if they don't appear for you below: Picasa Web Albums - Ted - Hildenbrand F...
                            Cheers,
                            Ted
                            • #15
                              Great idea Ted !
                              I think we are very close to understand devices like Steven Mark TPU and Sweet VTA.
