Its complicated
and involves a lot more than just vaporising gasoline.First of all, it has to do with the nature of gasoline, and with the nature, or how it works, of infernal combustion engines.
Firstly, gasoline; for comparison, you have a gallon of 100% pure alcohol; each drop in that gallon is exactly the same as every other drop, and each molecule in a drop is the same as every other. (I'm not a chemist, just trying to explain a concept, here.)
Gasoline is very different.Its composed of something like 2000 different compounds, each with different qualities; and I'm not even talking about the additives.These different compounds are called 'Fractions'; some vaporise very easily and are called 'lighter' fractions, some not so easily, and some are very difficult to vaporise'; medium and heavy fractions.
Each drop is composed of light, medium and heavy fractions.
To see this, pour 1/2 oz. or so of gasoline in a bowl, and set it outside. Just the air over the surface will encourage the lightest fractions to vaporise, and eveaporate fairly quickly.Within 1/2 hr. or so, depending on wind and ambient temp., the bowl will 'loose' 1/2 its volume. In another hour or so, the remaining amount will decrease by 1/2, and so on.But, if it remains undisturbed, a week later there will STILL be a small amount of liquid remaining in the bowl; these are the heaviest fractions.
Now, don't need to do this, cause others have already done it, but; Take a small metal pan, an electric hotplate, and a long extension cord.Run the cord out away from anything flamable, hook the hotplate up, set the pan on it, and turn it on and put a small amount of gasoline in the pan.As it heats up, the gasoline will begin to vaporise.Actually, the lightest fractions will begin to vaporise at ambient temps.Anyway, if you succed in heating it up to 1000 degrees F., you will vaporise all of it, and will see a blue grey vapor that looks like smoke, in the pan.It isn't smoke, its vaporised gasoline.If you tilt the pan you can pour it into another container, cause its considerably heavier than air.If you stick your finger in it, it will be cold; damn cold.Vaporised gasoline absorbs a tremendous amount of heat.And, unless you continue to put a lot of energy, in the form of heat, into it, it will re-condense into a liquid.
2 things vaporise gasoline; heat and vacuum (or negative pressure).And 2 things will cause them to recondense; lack of sufficient heat, or positive pressure.
So, you've got this vaporiser, that uses heat and or negative pressure to vaporise the fuel totally; now you've got to get this vapor into the cylinder of the engine; How? Its heavier than air, so doesn't move readily in.You can't pump/squirt it in, like propane, etc. cause any attempt to pressurise it will cause it to re-condence.And, whatever piping you use to transport it from your vaporising vessel to the cylinder has to be heated up to around 1000 degrees F., because if it 'cools' it will re-condense.
And, lets say you manage to get it into the cylinder, on the intake stroke of the piston.Next thing is going to be the compression stroke, and guess what? All this has been fruitless, because your vapor is going to be compressed, and re-condense into a liquid.
In point of fact, an infernal combustion engine DOES vaporise gasoline; liquid fuel doesn't burn. If there weren't some vaporising going on, the engine wouldn't run.
Whether from a carburetor or fuel injection, minute drops of gasoline are squirted into a negative pressure airstream.The negative pressure and some engine heat encourages the lightest fractions to vaporise off the surface of the droplets, even as the droplet is moving thru the intake manifold, and even some of the light/medium fractions.The heaviest and light heavy fractions remain in droplets.They are sucked past the intake valve and into the cylinder, where they absorb some heat from the piston top, valves left over from the last combustion stroke.
At the completion of the intake stroke, you have a stratified charge; the heaviest fractions, those which are 'hardest' to vaporise, end up in a layer right on top of the piston.And there are progressively 'lighter' layers, as you move up the cylinder.The lightest fractions, those that will vaporise at ambient temps and with the negative pressure caused by a slight breese blowing across the surface, are in a layer right up against the top of the cylinder, where the sparkplug is.The compression stroke has the piston come up the cylinder, compressing all the layers, but, unless you introduce 'swirl' into the cylinder, these stratified layers remain. Although, the compression does cause some additional re-condensing to droplet form.
Then, the spark plug fires, and the lightest still a vapor fractions at the top of the cylinder ignite.As they burn, the heat up the droplets in the next layer down, which has the lightest fractions on the outside of the droplet 'boil off' or vaporise. As they vaporise, they ignite, in turn boiling off the heavier fractions in the interior of the droplet.As this layer ignites, it then does the same thing to the next layer, and so on.
The last layers, laying down on the top of the piston, actually ignite at the very end of the combustion stroke, and during the exhaust stroke.
Thats why if you disconnect the exhaust manifold you can see flames coming out the exhaust port.These are the fractions that are being burned in a catalyctic converter; they burn so late that they don't impart any usable energy to the piston or the engine.Part of the idea of 'swirl' is to intermix the stratified layers, so as to get usable energy from these 'heaviest' fractions.
Anyway, this is some of my understanding of the complexities involved in making an infernal combustion engine run on 'vaporised' gasoline.An ICE DOES run on vaporised gasoline, at least in part; has to.Cause liquid gasoline doesn't burn.The challenge is to make the process more efficient.But vaporising the gasoline, and then trying to get the heavier than air vapor into the cylinder, while keeping it a vapor, is an excercise in frustration, which many have tried for years.I think the more promising area involves trying to vaporise the gasoline more completely in the cylinder.
For instance, by using gapless top rings, and closing the intake valve well before BDC. By closing the intake valve early, you are reducing the amount of fuel in the intake charge, and then are subjecting that fuel to negative pressure.Gasoline vaporises with negative pressure, so it vaporises. Vaporised gasoline absorbs heat, so it 'sucks' the heat out of the valves, piston top.As the piston starts back up the cylinder, the 'extra' energy required to draw a vacuum, (once the intake valve closed on the intake stroke) is 'offset' by the vacuum which pulls the piston up, initially, on the compression stroke.The cooler cylinder means you no longer have to be concerned with 'detonation' or 'pre-ignition' which means you can have much higher compression ratio. The more tightly you cna 'pack' those stratified layers of intake charge, the more complete the ignition.I think thats what 'TheOldOne' is doing.Anyway, gota go. Jim
Jim
My idea on the whole vaporization of gasoline was the foundation of my earlier understanding of how to get better mileage out of gasoline and extract the full potential of energy from it. Ever since I bought a car Ive been experimenting with new designs on how to make the process work on my vehicle. As some may have seen my new video I posted on YouTube I was attempting to run my car on just pure vapor from gasoline.
So far I haven't tried heating the gasoline up to maintain the temperature to a reasonable degree, but so with my only set up I was able to get my car running on the first 5 to 10 minutes on it before shutting down. I have had my car on the road with this set up, and have had it slowly accelerated to 25 to 30 mph, then slowly dieing down. My next design im looking on trying some stronger spark plugs to ignite such a lean mixture and may be get the water spark plug design working hand and hand with this set up, maybe better results! I was thinking that the plasma spark plug would be working on the principle of catalytic cracking and producing smaller molecules made of hydrogen gases that gives more power and effeciency?
