Hi all.
Since I am experimenting with gasoline vapors I have searched around the web a little and found a web site with info about a gasoline vapor carburetor. The author explains how the current carburetors and injection systems wastes fuel, because only the gasoline vapors burn, not the liquid itself, this is why it is so inefficient to inject small gasoline droplets in the combustion chamber rather than gasoline vapors. Because in the combustion chambet the gasoline turns into vapor completely only after the explosion and the unburned fuel is then burned into the catalyst converter. So the gasoline vapor is the key to get all the power out of gasoline. Using a gasoline vapor carburetor you can get up to 200mpg on a car. There is also explained how the oil companies reformulated gasoline so that gasoline vapor carburetors no longer could work properly.
Here is the link:
Sepp Hasslberger: Pogue Carburetor, 'Gasoline Vapor Maker' Increase Mileage
The author also suggests a rather simple carburetor design to increase MPG.
What do you think?
Here is the link:
What do you think?
I have been running straight water through the inlet manifold for a while now with the positive effect that I believe it has helped clean the cylinders. No change to fuel economy up or down and no - I haven't run my plugs with this mix! If you can, could you make up a gasoline water mix and re-run your experiment with the vapouriser please. I believe that the extra energy released from the gasoline vapour may have a positive effect on the water vapour. Add to the equation the water spark plug circuit and we could be on the money!
