I'm not a chemist, or an engineer
My understanding is that jetsis is talking about catalyctically cracking the fuel, to turn it into a gaseous mixture of hydrogen and methane, and then run the engine on that.
My understanding is that any petroleum product; Gasoline, diesel, propane, kerosene, etc. will catalyctically crack.
If the cracking is done in the presence of oxygen, it will ignite.No oxygen, its a gaseous vapor, which could then be fed to the engine thru a propane carb.
jestis plasic to fuel project produces 3 products; a gasoline type substance, a Diesel type substance, and a propane or butane type flammable gas.
So, I can see where having a car that 'cracked' the fuel would be good, as he could run all 3 fuels, or at least the 2 liquid ones, interchangeably.
Anyway, I was just talking about catalyctic converters in that context.
Actually, since the plastic to fuel process is anerobic, you could pipe the gas off from the reactor vessel with exhaust pipe diameter pipe, to a catalyctic 'converter', heat it with an external burner to get it up to 1000 degrees F., and crack it right there.Might be great for a stationary generator type set up.
However, I suspect for a car your wanting to fill the tank with a liquid fuel, and crack it onboard, using waste heat from the engine.Otherwise too much energy in compressing it, etc.Jim
) However,many have got an engine to run on vaporised gasoline; run with any power, run for very long, run without leaving behind a residue of heavier fractions, or getting clogged up with heavier fractions, thats another story.Again, if thats what the video is 'demonstrating', already been discussed.
