The marvellous's Cole generator under the Occam's Razor
- Following of my previous small post -
Occam's razor is the principle of parsimony of the immense Aristotle, redrafted in 1319 by William of Ockham (or Occam).
This principle of simplicity, and of elegance of solutions, can be formulated thus : the sufficient hypotheses the most simplest are the most plausible.
(Mr Ockham was an English logician, he has studied at Oxford and Paris, where he became a teacher. This is how he was the professor of Jean Buridan, another big shoes already met in previous post.)
So, Mr McKay teaches us that until the hold-up by the police in July 1974, Hack disposed of an extraordinary generator, static (no moving parts except the blade of a vibrator) and COP staggering|*| between 6000 and 23000 !
(Her owner being EV Gray, I named him "EV's box". It was small and black|**|.)
For one year Hack has had every opportunity to dissect him, analyze, test and evaluate it. And to draw a detailed plan.
It follows quite logically that it is by according to the dissection of this wonderful EV's box that Hack would have built his 1st converter in 1973 (black-box), and his 2nd in 1974 (blue-box). And not from an arduous and delicate analysis of motor EMA-4.
Look at all this more closely.
Classically the blade vibrators operate in push-pull, and therefore steer the current in a transformer double primary.
The simplest converted DC to square AC 100Hz, that diodes rectified if necessary.
There existed a more subtle version, with double contacts and transformer with double secondary, called synchronous vibrator, where the push-pull produced artfully DC square. (A topology DC to DC, then.)
1 vibrator, 1 transformer, 1 filter, are the only components. It is therefore easy to identify which non-classical pieces are present.
Impossible, in this case, to imagine that Hack could be mistaken ...
So how explain the COP < 1 of the boxes that he copied ? And whose Hack showed himself perfectly satisfied.
(The GD's recording shows indeed that the Hack's boxes have no virtue, cf. my posts of May 31.)
Well then we find ourselves here in front an unacceptable contradiction.
We are no longer in principles : we are in the simple common sense. See an engineer satisfied with its mediocre copy in a hand, while holding the divine original in his other hand, this doesn't add up !
The Occam's razor imposes a vigorous simplification, by example the EV's box is nothing more than a vulgar trickery : a hidden cable linking this box to the mains.
It's easy to mystify people: bigger is better it passes ; this is well-known.
For example here the feet of the great TV were rigged, and constituted 2 contacts, pressing two other contacts hidden on the shelf, connected to the mains via a big HV transformer ...
Warning : I don't designate Marvin Cole ; is Mr Gray that I designate|***|.
(Only Spokane1 talking about M. Cole. The man who saw this Ev's box in 1972-73 is Dowd Cannady. Now Mr. Cannady speaks exclusively to Edwin Gray in his testimony.)
Our friend Edwin may very well have designed this fake generator used as gorgeous cheerleading girl. (For him this is not swindling, since the engine is really "magic".) The result is ensured, see, in my first note, Cannady's emotion.
Edwin is the genius of pragmatism. The authentic superpower of the motor EMA-4 always remains completely invisible. We does not take off the cerebrality. While a breathtaking cheerleader showing his baits twiddle senses.
Arker
_______________
|*| Dowd Cannady was radio-mechanic in US Air Force. He explain in essence :
.(Total approx. 1400 watts.)
. "She functioned on a 12 volts small battery 2.5cm x 10cm x 13cm"
- (It's clear, there is here only this unique and tiny battery -not two like Spokane1 wrote.)
- This would correspond to 2-3 A-h nominal.
- Suppose with overstatement that this batt. can debited 3 amp under constant 13 volts, for 1 hour.
- The energy that she contains would be : 1h x 13V x 3A = 39 Wh. (Theoretically, but 10 Wh would be more likely.)
. "Mr. Gray asserted we that consumption is so derisory that even without recycling on input, this small battery will maintain all equipments lit for 7 days."
- 7d x 24h = 168h,
- and 39Wh / 168h = 0.23 watt.
- The minimum COP would thus : 1400W / 0.23W = 6000 !
- (And in taking 10Wh instead of 39Wh is reached 23000.)
|**||***| His patent of a magical trigger #4595975 (Gray's tube) is in a neighboring tonality.
_ e n d _
___________
___________
___________
Arker
_______________
- 7d x 24h = 168h,
_ e n d _
