Originally posted by Spokane1
Makes more engineering sense to me too ..
Since we don't have a clear picture of the internal connection of the grids, I thought I might initially at least try connecting the grids the following way:
Assuming three grids.
From inner(1) to outer grids(3): I take the bottom of 1 to the connector, top of 1 to top of 2, bottom of 2 to bottom of 3, then take top of 3 to the connector. This connects the grids as a 3-turn inductor. Because of the holes, all grids will be acted on by the radiant electrostatic energy as well(capacitive), so I think we can treat the two wires as a parallel resonant circuit and extract the energy from that ..
Question: Did anyone ever see an inductor wound around the outside of the CEST? If this was done on at least one model, then that would validate my assumption that the grids can be treated as an inductor/capacitor ...
By the way. I played around last night tying to figure out the best location for my Thyratron switch in the LV circuit. As you know I have a Bifilar wound inductor in there. I found that the arc could be stop/started much easier if the switch was at the center point of the inductor, i.e. there is 1/2 the inductor either side of the switch/Thyratron .. it did not seem to work as well at the "cold" battery end of the LV circuit.
Bernie
