Gray Tube Replication
  • Aaron
    switch
    Originally posted by aespinola View Post
    Hi, I'm experimenting with the engine. Use a capacitor bank of 2000 volts 63 uF with a coil of 1000 turns. I have a problem with part of the switch that opens and closes the SCR, I tested with blister Reeds with unfavorable results since bo managed to tune blister downloading and walked the engine to stumble.
    I wonder if Aaron can give me information on the type of switch you use or where to get it.
    Does anyone know anything about this collection waveform on the oscilloscope in XY-shaped torus axis?
    Here some pictures.
    Can you post a schematic of your setup and point out the switch in question?
  • aespinola
    Gray Tube
    Here some pictures.
  • eldarion
    Originally posted by Spokane1 View Post
    Dear Wicaksono,
    I was building a Tesla Coil in 1980 for a carnival Fun House following the 1964Popular Electronics plans. It had a secondary 4" diameter x 48" long. I was using a sheet of 1/4" plate glass from a pin ball machine and aluminum foil as a capacitor. The NST was 15KV at 60mA. The primary was about 28 turns of neon conductor around a 5 gal plastic bucket. The spark gap was made from 4" galvanized box nailes (thin). I didn't have any Terry filter, EMS, or other filtering. The base of the secondary was connected to the case of the NST (Big Mistake). The spark gap electrodes (the nails) were set parallel to each other about 1/2" apart. The discharges were loud, intermittant and stacco like.
    It operated for about 10 minutes before the NST blew. During that time every metal object in the shop was emitting blue arcs to what ever surface it could find. Tools on the shelf and on the counter were arcing to each other. Even a nail that was in the plywood wall was sending out spider web thin arcs that didn't connect to another object. In the dark there were at least 100 blue arcs taking place all at the same time at various places in the shop. Fortunatly there were no electronics at this same location.
    At the time I figure this is what Tesla Coils do and decided against making repairs since I was planning to use computer chip sound sources in the Fun House as well. The Tesla Coil I thought would destroy these devices.
    It was about 10 years later that I learned that this is not a common feature of Tesla Coil operation.
    I still don't know what was going on there. I have been reluctant to follow up due to the high price of NST's and the dangers of repeating the faulty connection to the case of the NST which is the center tap for the NST secondary.
    I have thought that the zinc electrodes had something to do with the anomalous action.
    Mark McKay
    Was the NST case connected to the local electrical ground via a ground wire in the 120V power cord for the NST, or was it left floating (e.g. using only the hot/neutral wires for the 120V power to the NST)?
    If the NST case was grounded to the local electrical ground I can see how you would have had...ahem...spectacular effects. The electrical ground connection in many structures is relatively high impedance at HF and would have acted as a gigantic antenna!
    Eldarion
  • wings
    Originally posted by thx1138 View Post
    CEST at University of Missouri?
    Plasma Device Could Revolutionize Energy Generation and Storage
    Appears to use a spark gap of some kind and notice the wire grid on the device and the vertical coil in the background.
    Randy Curry : Atmospheric Plasma Generator -- Articles & Patents
  • thx1138
    Energy generation via plasma
  • aespinola
    Gray Tube
    Hello again I have replicated the water circuit smw1998a spark plug. Thank you very much for your input. Not a lot of electronics, so I limited myself to build it as scheduled. The problem is that when I turn the circuit begins to oscillate but with flashes of light up and switching off until it stops scrolling, the time begins again and so on buqle. The only thing that changes are the potentiometer circuit are 10k instead of 20k, but that does not think that's the problem, someone else has replicated?. Here I upload some pictures of the circuit and the inverter circuit that feeds the microwave transformer that charges the capacitor bank.
    I hope answers. Thank you.
  • aespinola
    More images.
  • aespinola
    Gray Tube
    Good, here are the pictures. This is the scheme used to observe the radiant effect. With this configuration I managed to raise approximately 20cm neodymium magnet 11kg of clamping force.
    At last I could get, but I still do not understand what is really happening:
    A mixture of high voltage and low amperage (static) with a source of low voltage and high-current (DC)? Or is this ZPE?
    Thank you.
  • Aaron
    Gray Tube
    Hi, I come to the forum. It's the first time I write but I've been following your steps for several years.
    I managed to successfully replicate Gray Tube, radiant energy. Thank you very much for your help and especially Aaron.
    I will upload photos soon.
    Hi Aespinola,
    That's exciting to hear - looking forward to seeing your work!
  • aespinola
  • Aaron
    Jerry Volland - False Allegations Debunked!
    Recently, Jerry Volland (Electrotek) accused me of banning him from this forum because I accused him of plagiarizing my circuits. He gave his testimonial to Techzombie (Ray Savant) of Aether Force (Aether Farce) to help in their false allegations against Eric Dollard and I.
    This video has proof that Jerry Volland is the one that accused me of plagiarizing him. My circuits in the Gray Tube Replication thread were based on my simplified plamsa ignition circuit that I posted an entire year BEFORE Jerry Volland ever posted his circuits in this thread.
  • lvleon
    Об изменениях на российском сайте "Realstrannik.ru"
    Dear All!
    I inform, that on Russian site "Realstrannik.ru" - "The Energy Converter of Edvin Gray" - from a dynamic part of this site rearrangement of a branch has been lead to the fixed part.
    Therefore in my messages at this forum all former links on this site have appeared void.
    I have tried to correct this annoying misunderstanding in the messages.
    If I somewhere have passed the incorrect link - write on mail [email protected]
    Input on the site Realstrannik.ru, section: "The Energy Converter of Edvin Gray" (with Google translation on English):
    Respectfully
    Leonid Volkov
    Ukraine
    Zaporozhye
  • antigraviticsystems1
    break close arc magnetically inspired in Tesla Radiant work:
    fraccionamiento inductivo 1 - YouTube
    fraccionamiento inductivo - YouTube
