Gray Tube Replication
  • Yes, I will indeed be grounding the ignition coil from this point on, thank
    you Aaron. Would it also be prudent to have the inverter (-)AC input pole
    connected? I'm thinking that it would be somewhere on the way to the (-) battery
    post and would supply it with a portion of what isn't absorbed into Ground.
    • configuring for recovery
      You've shown this inverter connection in a couple of diagrams already, but I'm
      currently unaware whether this will in fact send energy back to the battery.
      If not then I must configure it to be a dual-battery system with either
      a Run/Charge automatic swapper, or otherwise find a different way to accomplish
      the recovery of what is produced in a useable form.
      At this point I've found that in any configuration with the Output connected
      to a battery also in contact with the inverter supply cables will produce a
      voltage warning and temporarily disable the system. Then again I've not yet
      had a go at it with the ignition coil (-) primary connected to ground. I would
      hope that doing so would supress whatever is causing these malfunctions.
      • WHY ignition coils? They have that annoying internal bind between Primary and Secondary! What about those HV transformers out of copy machines or strobes? They have an unbound secondary.
        • solution to ground
          Ok, as it turns out, my problem with the inverter was due to a faulty
          ground connection. After properly reconnecting it there are no more
          voltage warnings.
          Even with the Output rod connected directly to the (+) Battery on the
          inverter and the LV caps charging onto the (-) pole it still keeps running.
          I'm guessing this is probably not the best idea to keep the battery
          charged up in a longterm sense, so I'll be adding a recovery-cap system.
          In regards to collecting the bEMF from my single coil of 30g, the following
          parallel connection is what I had in mind. It seems as though it may reduce
          the amount of magnetic force generated around the coil ... ?
          • 3 grounds - that is it
            The only grounds that need to be connected are the 3 blue dots I showed.
            If you do it that way, you will get results.
            • only the recent diagram edits
              The most recent diagram I posted superceeds everything else.
              I may not have interpreted your diagrams correctly each time
              but your last diagram that I made edits to was the clearest and most
              accurate to date.
              • autotransformer
                You are defining an autotransformer - it is not an issue. Feel free to post
                your replication attempts with another transformer, there are many possible
                ways to do it. Would like to see it.
                • developments
                  Whereupon completing a number of experiments I've found that while the
                  battery feeding the inverter will accept the output directly from the
                  pickup rod onto its (+) pole with the (-) side connected to return it
                  to the Cathode of the LV-side capacitors without throwing an error on
                  the inverter, it is not possible to do so by first sending the Output
                  into charging the motor coil.
                  This being the case I have put together the only other option for a
                  quick demonstration. On top of my motor there is a 2000ft spool of 25g
                  hooked to charge up a bank of three 450V 10uF capacitors in series.
                  They are in the standard fullwave bridge arrangement.
                  In order to further expand the recovery system I'll be rewinding the
                  current motor coil as bifilar and adding the second half also as a bifilar
                  winding. In addition to this, the ignitor will be triggered by a reed
                  switch, and once the driveshaft is straightened will be utilized to provide
                  mechanical work output for spinning an alternator of some kind.
                  With the construction of a second electrode array or tube, it will mean
                  perhaps even more recovery with a second burst being generated only to go
                  back to the battery without first being picked up by a coil.
                  I'm not sure what has happened to the yTube video service, but it
                  will not allow me to upload citing an 'Unknown Error', thus I have made
                  the demonstration available as a download-only file.
                  [ video demonstration ~ 9mB avi ~ 1:10 ]
                  • Reference Pics
                    • video error
                      Video doesn't work. It is only 8.something kb.
                      • Appears to be an outdated browser glitch.
                        It is now uploaded for viewing online. [ HyperLink ]
                        • @Geotron
                          Geotron, that looks great!
                          Any chance to get a video with sound?
                          Also, how sealed is that box you have the gap in?
                          • Thanks! It's going to be a whole lot spiffier before its done... I've been
                            thinking about what kind of energy would be picked up on a secondary
                            of the same guage wire when having it wound bifilar as a ratio of the amount
                            going in to the primary. One-to-one seems a bit optimistic, although wouldn't
                            it stand to reason being somewhere near this value?
                            With the flux of the magnets providing energy in addition to the primary
                            windings, I'm thinking this could easily take off with the added bonus of
                            mechanical output and a parallel electrode array just for the purpose of
                            punching some batteries with a second LV cap bank and string of diodes.
                            Currently I've disassembled the motor and will be adding layers of the 25g
                            wire from the video. The arms holding the bearings are a bit close to touching
                            the sides of the motor tube so in order to fit the whole spool on there it
                            will likely need to have a wider base fitted. At this point I'm not sure that
                            winding the entire 2000ft spool on the outside would be practical due to the
                            falloff of magnetic flux from the 30g primary.
                            I'll see about getting the audio in future clips, it would really add to
                            getting a feel for how much force is being generated. I'd like to reinforce
                            that while the concrete cinderblock may look like overkill it is almost not
                            enough weight. When running it will eventually thump its way along the floor
                            due to the intense vibration.
                            The electrode box is nearly airtight except for the circular holes where
                            clearance has been left for adjusting the copper rods.
                            • recovery / audio
                              1:1 is what I used for most of my tests. Mine actually most used
                              trifilars.
                              If you can post with sound, it will add so much more to the presentation!
                              • With a bifilar coil it is now showing around 158ohms on each of the
                                them with two similar 30g 1600ft spools. In order to verify the concept
                                of Energy Conversion caused by this repulsion effect initiated by the
                                HV plasma ignition onto the positively charged anode pole of a diode
                                capable of fully blocking the voltage emitted at it, whereupon it initiates
                                a cascade of energy through the HV plasma carrier onto Ground, the following
                                is a representation of what has now been captured for viewing online.
