Hi all,
Aaron has posted several times about the similarities between the Gray tube and the water spark plug, for example in this circuit:
As far as I understand, it appears to be possible to combine a HV low current source with a LV high current source, which would give you under certain conditions a HV, high current pulse trough your spark gap. According to Frolov, you may see a negative resistance in a sprak gap under certain conditions:
Frolov on resonant tuning and the Avramenko plug
If we then take a look back at Aarons circuit, then it would be worth to try moving the load from the booster-cap line to the ground connection of the spark plug, as Aaron shows here in his "2 point silent plasma" (bottom-right):
So, what I'm trying to say comes down to this: there appear to be significant similarties between gotoluc's water spark plug circuit and Gray's tube.
So, has anyone actually tried to replace the Gray tube with such a "water" spark plug to power a load, like popping magnets or powering a motor, where the load is connected between the plug ground and earth ground ???
Code:
Towards the end of the 1960s Prof. Alexander V. Chernetsky and Uri A. Galkin,
Institute of Electrical Engineering, Moscow, carried out experiments using
strong arc currents and observed a phenomenon they called, the "self-
generating discharge". Figure 1 shows the voltage U and current I for this
special case of arc.
_ _
/ \ current I
_ / \ \ _ _
----------------\--------------------------- t
\ _/ voltage U
Figure 1
Note that for part of the cycle the current is increasing while the voltage is
decreasing.
dI/dt>0 for dU/dt<0 F.1
Negative resistance takes place
R = U/I F.2
This fact means that in the process of the self-generating discharge, by
Chernetsky, the power
P = I U F.3
is the inflow into the system from an outside source.
