Wood Gasification
  • #61
    In mathematics (specifically in differential geometry and topology), a smooth manifold is a subset of Euclidean space which is locally the graph of a smooth (perhaps vector-valued) function. A more general topological manifold can be described as a topological space that on a small enough scale resembles the Euclidean space of a specific dimension, called the dimension of the manifold. Thus, a line and a circle are one-dimensional manifolds, a plane and sphere (the surface of a ball) are two-dimensional manifolds, and so on into high-dimensional space. More formally, every point of an n-dimensional manifold has a neighborhood homeomorphic to an open subset of the n-dimensional space Rn.
    In physics and mathematics, the dimension of a space or object is informally defined as the minimum number of coordinates needed to specify any point within it.[1][2] Thus a line has a dimension of one because only one coordinate is needed to specify a point on it (for example, the point at 5 on a number line). A surface such as a plane or the surface of a cylinder or sphere has a dimension of two because two coordinates are needed to specify a point on it (for example, to locate a point on the surface of a sphere you need both its latitude and its longitude). The inside of a cube, a cylinder or a sphere is three-dimensional because three co-ordinates are needed to locate a point within these spaces.
    In physical terms, dimension refers to the constituent structure of all space (cf. volume) and its position in time4-dimensional "spacetime", (defined as a Minkowski space). Modern theories tend to be "higher-dimensional" including quantum field and string theories. The state-space of quantum mechanics is an infinite-dimensional function space.
    In mathematical physics, Minkowski space or Minkowski spacetime (named after the mathematician Hermann Minkowski) is the mathematical setting in which Einstein's theory of special relativity is most conveniently formulated. In this setting the three ordinary dimensions of space are combined with a single dimension of time to form a four-dimensional manifold for representing a spacetime.
    In theoretical physics, Minkowski space is often contrasted with Euclidean space. While a Euclidean space has only spacelike dimensions, a Minkowski space also has one timelike dimension.The spacetime interval between two events in Minkowski Space is either space-like, light-like ('null') or time-like.
    In mathematics, spherical harmonics are the angular portion of a set of solutions to Laplace's equation. Represented in a system of spherical coordinates, Laplace's spherical harmonics are a specific set of spherical harmonics that forms an orthogonal system, first introduced by Pierre Simon de Laplace in 1782.
    Spherical harmonics are important in many theoretical and practical applications, particularly in the computation of atomic orbital electron configurations, representation of gravitational fields, geoids, and the magnetic fields of planetary bodies and stars, and characterization of the cosmic microwave background radiation.
    RM
    • #62
      Compressible vs incompressible flow
      All fluids are compressible to some extent, that is changes in pressure or temperature will result in changes in density. However, in many situations the changes in pressure and temperature are sufficiently small that the changes in density are negligible. In this case the flow can be modeled as an incompressible flow. Otherwise the more general compressible flow equations must be used.
      Mathematically, incompressibility is expressed by saying that the density ρ of a fluid parcel does not change as it moves in the flow field.
      where D/Dt is the substantial derivative, which is the sum of local and convective derivatives. This additional constraint simplifies the governing equations, especially in the case when the fluid has a uniform density.
      For flow of gases, to determine whether to use compressible or incompressible fluid dynamics, the Mach number of the flow is to be evaluated.
      As a rough guide, compressible effects can be ignored at Mach numbers below approximately 0.3. For liquids, whether the incompressible assumption is valid depends on the fluid properties (specifically the critical pressure and temperature of the fluid) and the flow conditions (how close to the critical pressure the actual flow pressure becomes).
      Acoustic problems always require allowing compressibility, since sound waves are compression waves involving changes in pressure and density of the medium through which they propagate.
      Viscous vs inviscid flow
      Viscous problems are those in which fluid friction has significant effects on the fluid motion. The Reynolds number, which is a ratio between inertial and viscous forces, can be used to evaluate whether viscous or inviscid equations are appropriate to the problem.
      Stokes flow is flow at very low Reynolds numbers, Re<<1, such that inertial forces can be neglected compared to viscous forces. On the contrary, high Reynolds numbers indicate that the inertial forces are more significant than the viscous (friction) forces. Therefore, we may assume the flow to be an inviscid flow, an approximation in which we neglect viscosity completely, compared to inertial terms.
      This idea can work fairly well when the Reynolds number is high. However, certain problems such as those involving solid boundaries, may require that the viscosity be included. Viscosity often cannot be neglected near solid boundaries because the no-slip condition can generate a thin region of large strain rate (known as Boundary layer) which enhances the effect of even a small amount of viscosity, and thus generating vorticity. Therefore, to calculate net forces on bodies (such as wings) we should use viscous flow equations.
      As illustrated by d'Alembert's paradox, a body in an inviscid fluid will experience no drag force. The standard equations of inviscid flow are the Euler equations. Another often used model, especially in computational fluid dynamics, is to use the Euler equations away from the body and the boundary layer equations, which incorporates viscosity, in a region close to the body.
      The Euler equations can be integrated along a streamline to get Bernoulli's equation. When the flow is everywhere irrotational and inviscid, Bernoulli's equation can be used throughout the flow field. Such flows are called potential flows.
      Steady vs unsteady flowLaminar vs turbulent flowNewtonian vs non-Newtonian fluids
      Sir Isaac Newton showed how stress and the rate of strain are very close to linearly related for many familiar fluids, such as water and air. These Newtonian fluids are modeled by a coefficient called viscosity, which depends on the specific fluid.
      However, some of the other materials, such as emulsions and slurries and some visco-elastic materials (e.g. blood, some polymers), have more complicated non-Newtonian stress-strain behaviours. These materials include sticky liquids such as latex, honey, and lubricants which are studied in the sub-discipline of rheology.
      Subsonic vs transonic, supersonic and hypersonic flows
      While many terrestrial flows (e.g. flow of water through a pipe) occur at low mach numbers, many flows of practical interest (e.g. in aerodynamics) occur at high fractions of the Mach Number M=1 or in excess of it (supersonic flows). New phenomena occur at these Mach number regimes (e.g. shock waves for supersonic flow, transonic instability in a regime of flows with M nearly equal to 1, non-equilibrium chemical behavior due to ionization in hypersonic flows) and it is necessary to treat each of these flow regimes separately.
      Magnetohydrodynamics
      Magnetohydrodynamics is the multi-disciplinary study of the flow of electrically conducting fluids in electromagnetic fields. Examples of such fluids include plasmas, liquid metals, and salt water. The fluid flow equations are solved simultaneously with Maxwell's equations of electromagnetism.
      A shock wave (also called shock front or simply "shock") is a type of propagating disturbance.
      Like an ordinary wave, it carries energy and can propagate through a medium (solid, liquid, gas or plasma) or in some cases in the absence of a material medium, through a field such as the electromagnetic field.
      Shock waves are characterized by an abrupt, nearly discontinuous change in the characteristics of the medium.[1] Across a shock there is always an extremely rapid rise in pressure, temperature and density of the flow. In supersonic flows, expansion is achieved through an expansion fan. A shock wave travels through most media at a higher speed than an ordinary wave.
      Unlike solitons (another kind of nonlinear wave), the energy of a shock wave dissipates relatively quickly with distance.
      Also, the accompanying expansion wave approaches and eventually merges with the shock wave, partially cancelling it out. Thus the sonic boom associated with the passage of a supersonic aircraft is the sound wave resulting from the degradation and merging of the shock wave and the expansion wave produced by the aircraft.
      When a shock wave passes through matter, the total energy is preserved but the energy which can be extracted as work decreases and entropy increases. This, for example, creates additional drag force on aircraft with shocks.
      , which turns a supersonic flow around a convex corner. The fan consists of an infinite number of Mach waves, diverging from a sharp corner. In case of a smooth corner, these waves can be extended backwards to meet at a point. Each wave in the expansion fan turns the flow gradually (in small steps). It is physically impossible to turn the flow away from itself through a single "shock" wave because it will violate the second law of thermodynamics.
      Across the expansion fan, the flow accelerates (velocity increases) and the Mach number increases, while the static pressure, temperature and density decrease.
      • #63
        A supercritical flow is when the flow velocity is larger than the wave velocity. The analogous condition in gas dynamics is supersonic.
        Information travels at the wave velocity.
        This is the velocity at which waves travel outwards from a pebble thrown into a lake. The flow velocity is the velocity at which a leaf in the flow travels. If a pebble is thrown into a supercritical flow then the ripples will all move down stream whereas in a subcritical flow some would travel up stream and some would travel down stream.
        It is only in supercritical flows that hydraulic jumps (bores) can occur. In fluid dynamics, the change from one behaviour to the other is often described by a dimensionless quantity, where the transition occurs whenever this number becomes less or more than one. One of these numbers is the Froude number:
        A hydraulic jump is a phenomenon in the science of hydraulics which is frequently observed in open channel flow such as rivers and spillways. When liquid at high velocity discharges into a zone of lower velocity, a rather abrupt rise occurs in the liquid surface.
        The rapidly flowing liquid is abruptly slowed and increases in height, converting some of the flow's initial kinetic energy into an increase in potential energy, with some energy irreversibly lost through turbulence to heat. In an open channel flow, this manifests as the fast flow rapidly slowing and piling up on top of itself similar to how a shockwave forms.
        The phenomenon is dependent upon the initial fluid speed. If the initial speed of the fluid is below the critical speed, then no jump is possible. For initial flow speeds which are not significantly above the critical speed, the transition appears as an undulating wave. As the initial flow speed increases further, the transition becomes more abrupt, until at high enough speeds, the transition front will break and curl back upon itself. When this happens, the jump can be accompanied by violent turbulence, eddying, air entrainment, and surface undulations, or waves.
        There are two main manifestations of hydraulic jumps and historically different terminology has been used for each. However, the mechanisms behind them are similar because they are simply variations of each other seen from different frames of reference, and so the physics and analysis techniques can be used for both types.
        The different manifestations are:
        The stationary hydraulic jumpThe tidal boreA related case is a cascade
        • #64
          The shock tube is an instrument used to replicate and direct blast waves at a sensor or a model in order to simulate actual explosions and their effects, usually on a smaller scale.
          Shock tubes (and related impulse facilities such as shock tunnels, expansion tubes, and expansion tunnels) can also be used to study aerodynamic flow under a wide range of temperatures and pressures that are difficult to obtain in other types of testing facilities.
          Shock tubes are also used to investigate compressible flow phenomena and gas phase combustion reactions. More recently, shock tubes have been used in biomedical research to study how biological specimens are affected by blast waves.
          A shock wave inside a shock tube may be generated by a small explosion (blast-driven) or by the buildup of high pressures which cause diaphragm(s) to burst and a shock wave to propagate down the shock tube (compressed-gas driven).
          A simple shock tube is a tube, rectangular or circular in cross-section, usually constructed of metal, in which a gas at low pressure and a gas at high pressure are separated using some form of diaphragm. See, for instance, texts by Soloukhin, Gaydon and Hurle, and Bradley.
          The diaphragm suddenly bursts open under predetermined conditions to produce a wave propagating through the low pressure section. The shock that eventually forms increases the temperature and pressure of the test gas and induces a flow in the direction of the shock wave. Observations can be made in the flow behind the incident front or take advantage of the longer testing times and vastly enhanced pressures and temperatures behind the reflected wave.
          The low-pressure gas, referred to as the driven gas, is subjected to the shock wave. The high pressure gas is known as the driver gas. The corresponding sections of the tube are likewise called the driver and driven sections. The driver gas is usually chosen to have a low molecular weight, (e.g., helium or hydrogen) for safety reasons, with high speed of sound, but may be slightly diluted to 'tailor' interface conditions across the shock. To obtain the strongest shocks the pressure of the driven gas is well below atmospheric pressure (a partial vacuum is induced in the driven section before detonation).
          The test begins with the bursting of the diaphragm. Several methods are commonly used to burst the diaphragm.
          A mechanically-driven plunger is sometimes used to pierce it or an explosive charge may be used to burst it.
          Another method is to use diaphragms of plastic or metals to define specific bursting pressures. Plastics are used for the lowest burst pressures, aluminum and copper for somewhat higher levels and mild steel and stainless steel for the highest burst pressures.
          These diaphragms are frequently scored in a cross-shaped pattern to a calibrated depth to ensure that they rupture evenly, contouring the petals so that the full section of the tube remains open during the test time.
          Yet another method of rupturing the diaphragm utilizes a mixture of combustible gases, with an initiator designed to produce a detonation within it, producing a sudden and sharp increase in what may or may not be a pressurized driver.
          This blast wave increases the temperature and pressure of the driven gas and induces a flow in the direction of the shock wave but at lower velocity than the lead wave. The interface, across which a limited degree of mixing occurs, separates driven and driver gases, is referred to as the contact surface and follows, at a lower velocity, the lead wave.
          The bursting diaphragm produces a series of pressure waves, each increasing the speed of sound behind them, so that they compress into a shock propagating through the driven gas. This shock wave increases the temperature and pressure of the driven gas and induces a flow in the direction of the shock wave but at lower velocity than the lead wave.
          Simultaneously, a rarefaction wave, often referred to as the Prandtl-Meyer wave, travels back in to the driver gas.
          The interface, across which a limited degree of mixing occurs, separates driven and driver gases is referred to as the contact surface and follows, at a lower velocity, the lead wave.
          A 'Chemical Shock Tube' involves separating driver and driven gases by a pair of diaphragms designed to fail after pre-determined delays with an end 'dump tank' of greatly increased cross-section. This allows an extreme rapid reduction (quench) in temperature of the heated gases.
          In addition to measurements of rates of chemical kinetics shock tubes have been used to measure dissociation energies and molecular relaxation rates they have been used in aerodynamic tests. The fluid flow in the driven gas can be used much as a wind tunnel, allowing higher temperatures and pressures therein replicating conditions in the turbine sections of jet engines. However, test times are limited to a few milliseconds, either by the arrival of the contact surface or the reflected shock wave.
          They have been further developed into shock tunnels, with an added nozzle and dump tank. The resultant high temperature hypersonic flow can be used to simulate atmospheric re-entry of spacecraft or hypersonic craft, again with limited testing times.
          Shock tubes have been developed in a wide range of sizes. The size and method of producing the shock wave determine the peak and duration of the pressure wave it produces. Thus, shock tubes can be used as a tool used to both create and direct blast waves at a sensor or an object in order to imitate actual explosions and the damage that they cause on a smaller scale.
          Results from shock tube experiments can be used to develop and validate numerical model of the response of a material or object to a blast wave. Shock tubes can be used to experimentally determine which materials and designs would be best suited to the job of attenuating blast waves. The results can then be incorporated into designs to protect structures and people that might be exposed to a blast wave. Shock tubes are also used in biomedical research to find out how biological tissues are affected by blast waves.
          RM
          • #65
            HHO Linear Piston Engine powered by Water Pressure
            When you have constructed a basic Turgo turbine (or variant such as a Pelton), powered by water pressure from the standard house tap.
            The turbine will rotate a permanent magnet alternator, and the electrical AC output filtered through a full bridge rectifier will produce Direct Current.
            The DC will be fed into a HHO cell, either wet or dry cell design, doesn't matter for testing purposes at this stage.
            The HHO will be pumped under it's own low expansion pressure to an outlet such as a small bore pipe creating a HHO torch, or water fuel supply.
            The waste exhaust water from the turbine will gravity feed into a Kelvin generator reservoir.
            The water will drip and create an electrostatic potential that will discharge across a spark gap, creating an ionised plasma arc of approximately 15,000 Volts.
            The spark gap, if arranged at the HHO torch tip will detonate the gas.
            Now look at this video:
            HHO Test Device © - YouTube
            HHO Test Fixture Lift-Off © - YouTube
            The basic principles here are sound, you can charge a piston chamber with HHO and then detonate that charge using a Kelvin generator electrostatic discharge event.
            The resultant detonation wave will be confined into a limited volume and the pressure will rise inside the chamber until peak chamber pressure is reached.
            This is the fundamental basis for a linear piston engine running on Hydrogen, with the energy required for fuel processing provided by your water supply, or any suitable head of low pressure.
            We all having fun ?
            Be careful with this, it is dangerous if not done correctly!
            Rob
            • #66
              What are the possibilities ?
              Well detonating the Hydrogen in a chamber is a great idea, because the product is heat and a pressure increase through expansion. This will drive a piston.
              If that piston was connected to a fire tube filled with air the resultant linear force would compress the air and generate heat. The back pressure as the air expands again would reset the HHO piston for charging.
              Many of these pistons submerged in a water reservoir would create lot's of heat, and also space out the timing so you can charge each HHO piston.
              Hydraulic pistons typically have high pressure ratings and very close bore tolerances so seals are not essential.
              If you can boil the water then you can use it to heat a boiler, which will produce steam.
              And the steam can run a Pulsometer, which will replace the water pressure head, currently supplied by your tap.
              A possible self looped system primarily powered by gravity.
              Be fun testing this!
              RM
              • #67
                I just had a better idea!
                Hydraulic Tees, All Male and all Female... like these rated to 3000 psi:
                Cotswold Engineering Supplies Online Store &ndash; Hydraulic Adaptors &ndash; BSPP Male Equal Tee Coned Seal
                Cotswold Engineering Supplies Online Store &ndash; Hydraulic Adaptors &ndash; BSP Swivel Female Tee
                When connected together via cone seal in a cross arrangement will create 90 degree sharp turns. You can also step up and step down sizes using converters.
                This will create compression and expansion phases in the gas flow.
                Now you can bolt the assembly down solid and point the structure down submersed in water.
                The water will seek to equalise level and fill the assembly.
                Attach your HHO supply to the inlet, monitor the gas charge fill like in the video, and the HHO will displace the water and seal the bottom of the chamber.
                Now when you detonate it will blow the hot gas through the water, transferring heat.
                The chamber will then refill for the next cycle, cooling it in the process.
                The added beauty is that a hydraulic cross will give you opposing fixtures to mount your spark gap:
                Cotswold Engineering Supplies Online Store &ndash; Hydraulic Adaptors &ndash; BSP Male Cross
                Really simple, and no pistons to worry about!
                RM
                • #68
                  A pulse detonation engine, or "PDE", is a type of propulsion system that uses detonation waves to combust the fuel and oxidizer mixture.The engine is pulsed because the mixture must be renewed in the combustion chamber between each detonation wave initiated by an ignition source.
                  Theoretically, a PDE can operate from subsonic up to a hypersonic flight speed of roughly Mach 5. An ideal PDE design can have a thermodynamic efficiency higher than other designs like turbojets and turbofans because a detonation wave rapidly compresses the mixture and adds heat at constant volume.
                  Consequently, moving parts like compressor spools are not necessarily required in the engine, which could significantly reduce overall weight and cost. PDEs have been considered for propulsion for over 70 years. Key issues for further development include fast and efficient mixing of the fuel and oxidizer, the prevention of autoignition, and integration with an inlet and nozzle.
                  To date, no practical PDE has been put into production, but several testbed engines have been built and one was successfully integrated into a low-speed demonstration aircraft that flew in sustained PDE powered flight in 2008. In June 2008, the Defense Advanced Research Projects Agency (DARPA) unveiled Blackswift which was intended to use this technology to reach speeds of up to Mach 6.[4] However the project was cancelled soon afterward, in October 2008.
                  Concept
                  All regular jet engines and most rocket engines operate on the deflagration of fuel, that is, the rapid but subsonic combustion of fuel. The pulse detonation engine is a concept currently in active development to create a jet engine that operates on the supersonic detonation of fuel.
                  The basic operation of the PDE is similar to that of the pulse jet engine; air is mixed with fuel to create a flammable mixture that is then ignited. The resulting combustion greatly increases the pressure of the mixture to approximately 100 atmospheres (10 MPa),[5] which then expands through a nozzle for thrust.
                  To ensure that the mixture exits to the rear, thereby pushing the aircraft forward, a series of shutters are used to close off the front of the engine. Careful tuning of the inlet ensures the shutters close at the right time to force the air to travel in one direction only through the engine.
                  The main difference between a PDE and a traditional pulse jet engine is that the mixture does not undergo subsonic combustion but instead, supersonic detonation. In the PDE, the oxygen and fuel combination process is supersonic, effectively an explosion instead of burning.
                  The other difference is that the shutters are replaced by more sophisticated valves. In some PDE designs from General Electric, the shutters are eliminated through careful timing, using the pressure differences between the different areas of the engine to ensure the "shot" is ejected rearward.
                  The main side effect of the change in cycle is that the PDE is considerably more efficient. In the pulse jet engine the combustion pushes a considerable amount of the fuel/air mix (the charge) out the rear of the engine before it has had a chance to burn (thus the trail of flame seen on the V-1 flying bomb).
                  Even while inside the engine the mixture's volume is continually changing, which is an inefficient way to burn fuel. In contrast the PDE deliberately uses a high-speed combustion process that burns all of the charge while it is still inside the engine at a constant volume.
                  This is said to increase the amount of heat produced per unit of fuel above any other engines, although conversion of that energy into thrust would remain inefficient. A combustion process able to produce more heat per unit of fuel would, of course, be incredibly valuable in countless applications.
                  Another side effect, not yet demonstrated in practical use, is the cycle time. A traditional pulsejet tops out at about 250 pulses per second due to the cycle time of the mechanical shutters, but the aim of the PDE is thousands of pulses per second, so fast that it is basically continuous from an engineering perspective.
                  This should help smooth out the otherwise highly vibrationaldetonations are many times louder than deflagrations.
                  The major difficulty with a pulse-detonation engine is starting the detonation. While it is possible to start a detonation directly with a large spark, the amount of energy input is very large and is not practicaldetonation can be sent around a circle and valves ensure that only the highest peak power can leak into exhaust. This process is far more complicated than it sounds, due to the resistance the advancing wavefront encounters (similar to wave drag).
                  DDTs occur far more readily if there are obstacles in the tube. The most widely used is the "Shchelkin spiral", which is designed to create the most useful eddies with the least resistance to the moving fuel/air/exhaust mixture. The eddies lead to the flame separating into multiple fronts, some of which go backwards and collide with other fronts, and then accelerate into fronts ahead of them.
                  The behavior is difficult to model and to predict, and research is ongoing. As with conventional pulsejets, there are two main types of designs: valved and valveless. Designs with valves encounter the same difficult-to-resolve wear issues encountered with their pulsejet equivalents. Valveless designs typically rely on abnormalities in the air flow to ensure a one-way flow, and are very hard to achieve in a regular DDT.
                  NASA maintains a research program on the PDE, which is aimed at high-speed, about Mach 5, civilian transport systems. However most PDE research is military in nature, as the engine could be used to develop a new generation of high-speed, long-range reconnaissance aircraft that would fly high enough to be out of range of any current anti-aircraft defenses, while offering range considerably greater than the SR-71, which required a massive tanker support fleet to use in operation.
                  While most research is on the high speed regime, newer designs with much higher pulse rates in the hundreds of thousands appear to work well even at subsonic speeds. Whereas traditional engine designs always include tradeoffs that limit them to a "best speed" range, the PDE appears to outperform them at all speeds. Both Pratt & Whitney and General Electric now have active PDE research programs in an attempt to commercialize the designs.
                  Key difficulties in pulse detonation engines are achieving DDT without requiring a tube long enough to make it impractical and drag-imposing on the aircraft (adding a U-bend into the tube extinguishes the detonation wave); reducing the noise (often described as sounding like a jackhammer); and damping the severe vibration caused by the operation of the engine.
                  RM
                  • #69
                    Gas Laws - The Physics Hypertextbook
                    The gas laws are a set of intuitively obvious statements to most everyone in the Western world today. It's hard to believe that there was ever a time when they weren't understood. And yet someone had to notice these relationships and write them down. For this reason, many students are taught the three most important gas laws by the names of their discoverers. However, since the laws are known by different names in different countries and (more importantly) since I can never remember who gets credit for which law without referring to notes, I will not follow this convention.
                    Ideal Gas Law
                    An ideal gas is defined as one in which all collisions between atoms or molecules are perfectly eleastic and in which there are no intermolecular attractive forces. One can visualize it as a collection of perfectly hard spheres which collide but which otherwise do not interact with each other.
                    In such a gas, all the internal energy is in the form of kinetic energy and any change in internal energy is accompanied by a change in temperature.
                    An ideal gas can be characterized by three state variables: absolute pressure (P), volume (V), and absolute temperature (T). The relationship between them may be deduced from kinetic theory and is called the
                    Ideal Gas Law: P V = n R T = N k T
                    n = number of moles
                    R = universal gas constant = 8.3145 J/mol K
                    N = number of molecules
                    k = Boltzmann constant = 1.38066 x 10-23 J/K = 8.617385 x 10-5 eV/K
                    k = R/NA
                    NA = Avogadro's number = 6.0221 x 1023 /mol
                    The ideal gas law can be viewed as arising from the kinetic pressure of gas molecules colliding with the walls of a container in accordance with Newton's laws. But there is also a statistical element in the determination of the average kinetic energy of those molecules.
                    The temperature is taken to be proportional to this average kinetic energy; this invokes the idea of kinetic temperature. One mole of an ideal gas at STP occupies 22.4 liters.
                    Adiabatic process - Wikipedia, the free encyclopedia
                    Adiabatic changes in temperature occur due to changes in pressure of a gas while not adding or subtracting any heat.
                    In contrast, free expansion is an isothermal process for an ideal gas.
                    Adiabatic heating occurs when the pressure of a gas is increased from work done on it by its surroundings, e.g. a piston. Diesel engines rely on adiabatic heating during their compression stroke to elevate the temperature sufficiently to ignite the fuel.
                    Adiabatic heating also occurs in the Earth's atmosphere when an air mass descends, for example, in a katabatic wind or Foehn wind flowing downhill. When a parcel of air descends, the pressure on the parcel increases. Due to this increase in pressure, the parcel's volume decreases and its temperature increases, thus increasing the internal energy.
                    Heat engine - Wikipedia, the free encyclopedia
                    Engineers have studied the various heat engine cycles extensively in an effort to improve the amount of usable work they could extract from a given power source. The Carnot Cycle limit cannot be reached with any gas-based cycle, but engineers have worked out at least two ways to possibly go around that limit, and one way to get better efficiency without bending any rules.
                    1. Increase the temperature difference in the heat engine. The simplest way to do this is to increase the hot side temperature, which is the approach used in modern combined-cycle gas turbines. Unfortunately, physical limits (such as the melting point of the materials from which the engine is constructed) and environmental concerns regarding NOx production restrict the maximum temperature on workable heat engines. Modern gas turbines run at temperatures as high as possible within the range of temperatures necessary to maintain acceptable NOx output.
                    Another way of increasing efficiency is to lower the output temperature. One new method of doing so is to use mixed chemical working fluids, and then exploit the changing behavior of the mixtures. One of the most famous is the so-called Kalina cycle, which uses a 70/30 mix of ammonia and water as its working fluid. This mixture allows the cycle to generate useful power at considerably lower temperatures than most other processes.
                    2. Exploit the physical properties of the working fluid. The most common such exploitation is the use of water above the so-called critical point, or so-called supercritical steam. The behavior of fluids above their critical point changes radically, and with materials such as water and carbon dioxide it is possible to exploit those changes in behavior to extract greater thermodynamic efficiency from the heat engine, even if it is using a fairly conventional Brayton or Rankine cycle.
                    A newer and very promising material for such applications is CO2. SO2 and xenon have also been considered for such applications, although SO2 is a little toxic for most.
                    3. Exploit the chemical properties of the working fluid. A fairly new and novel exploit is to use exotic working fluids with advantageous chemical properties. One such is nitrogen dioxide (NO2), a toxic component of smog, which has a natural dimer as di-nitrogen tetraoxide (N2O4).
                    At low temperature, the N2O4 is compressed and then heated. The increasing temperature causes each N2O4 to break apart into two NO2 molecules. This lowers the molecular weight of the working fluid, which drastically increases the efficiency of the cycle. Once the NO2 has expanded through the turbine, it is cooled by the heat sink, which causes it to recombine into N2O4.
                    This is then fed back to the compressor for another cycle. Such species as aluminium bromide (Al2Br6), NOCl, and Ga2I6 have all been investigated for such uses. To date, their drawbacks have not warranted their use, despite the efficiency gains that can be realized.
                    adiabatic (no heat is added or removed from the system during adiabatic process which is equivalent to saying that the entropy remains constant, if the process is also reversible.
                    The Pulsometer uses a fluid piston in an oscillating reciprocal cycle.
                    RM
                    • #70
                      Some helpful tips on getting your spark generator to produce impressive results:
                      High voltage device: Kelvin's Thunderstorm
                      Electrostatic device: Kelvin's Thunderstorm, 'Inline' version
                      RM
                      • #71
                        "The major difficulty with a pulse-detonation engine is starting the detonation. While it is possible to start a detonation directly with a large spark, the amount of energy input is very large and is not practical for an engine."
                        This is why Lord Kelvin's electrostatic spark generator is so important to us, for a stationary engine, it is perfectly suitable as prime mover source, and energy cost to you is zero!
                        RM
                        • #72
                          New Biorefinery Converts Grass Straight to Gasoline
                          • #73
                            Vortex tube technology is important so you need to know about it, if you do not already.
                            Think about how you could use it... where could this be useful ?
                            Vortex tube - Wikipedia, the free encyclopedia
                            Vortex Tube History
                            RM
                            • #74
                              @ashtweth
                              Very cool article that looks very promising.
                              • #75
                                RM
                                What frequency do you think is possible with drips of water?
