  • All observable effects are important without a detector available.
    Oh Bodkins 41.AVI reveals sound has gone away when a cap is collecting?
    Does this mean the sound is due to pressure or something like that ..
    if given a place to hide out it stops making sound?
    Was it just a fluke or does disconnecting the cap make the sound return?
    Or does connecting a cap change the sound or does NOT change the sound
    Both are another puzzle piece / clue and both could occur.
    In Bodkins 42.AVI you Tuned it but the sound came back?
    Does the whine sound indicate unused / untapped energy?
    In Bodkins 43.AVI you say "I took the meter off .. proper bang!"
    Yes, I saw a video, don't remember which one and I don't think it was on
    this thread, showing that the volt meter WILL drain the cap, a LOT,
    down to a level but not down to zero... it levels out.
    At least that is what the video showed.
    • i too feel like we are being guided......i was compelled to do braindumps on to this forum...otherwise i couldnt get any sleep...
      i agree i think the main focus is to master aether. We master that we master antigravity.....but in doing so we need to release the info on this forum so that it can never be buried or lost again....its almost 2009 and i dont see free energy anywhere...and i dont think anyone will be alllowed to make money from it....theres too many powerful interest groups that will block it at every corner.....release it to the public....then it cant be stopped or blocked
      • oh about the solitons.....my opinion is that they are longitudal waves.....have a look at meyl book scalar waves....i dont have it handy so i cant post the page number....it quite clearly shows it in one of his drawing
        • In cor ate
          I always thought this was funny, relates to my state of mind for the most part......
          inquorate definition - Dictionary - MSN Encarta
          • Originally posted by Bodkins View Post
            http://www.free-energy-info.co.uk/Chapter11.pdf
            page 16
            that why I put this up Broli
            Just to get back to you. I got to read the main parts of that and wow it changed my world literally. The explanation of gravity was very simple and logical from an aetheric universe.
            Even beyond that I started discussing it with a friend and he casually said "If it's pushing on everything from all directions then it's the stuff that holds everything together?". Which made me suddenly realize that this theory could also apply to the strong electromagnetic force that's holding nuclei together. Since they're really small little aether gas/current/wind... passes through them and thus are held more tightly together.
            Thanks bodkins for pointing this cool insight out.
            • Originally posted by Inquorate View Post
              Dammit. Well, to begin, the ignition coil and salt water capacitor and electromagnet and glass eyedropper spark gap tube and cfl are all 'glued' with one of those arts and graft hot glue guns, to a piece of (maybe treated?) pine wood. That wood is sitting on the table you see, which is thin veneer of probably pine, and chip-wood.
              The system would be on but not jumping the spark gap, and I could put my hand 5 cm from setup and hertz measured from (unconnected, due to spark not jumping) ground would lower, but spark started jumping and cfl would light up... When I held hand 30cm away just above wood of workbench, no change. When touched wood of bench, sparks started jumping. I noticed this yesterday but didn't really twig that wood was amplifying / channeling my aetheric disturbance ? further from me?
              An EXTERNAL event, touching the Bench which is wood and your circuit is wood caused the bulb to light.
              Does the effect due to the external event, touching your bench, happen
              any where on the bench, from any point, from any distance?
              Is the effect/event distance related or not related to distance but related to
              wood/wood contact as in wire/wire contact would be?
              More study must be done... Try holding long metal pipe -insulated - and touching far end to various places, versus wooden pole versus plastic pipe.
              Curious if the effects are related to only like materials wood/wood
              or can move via unlike materials from a distance.
              Like a wood screw into the bench at the edge/corner
              connected to earth ground?
              Effects and lack of, clues , puzzle pieces.
              I think, This is not just about through the AIR or through the WIRES.
              Events can be conveyed / triggered through any material... ??
              Looking for ways to open the "conduits" of energy flow .
              The circuit is like a valve that allows the energy to flow,
              but this valve can be opened/closed external to the circuit.
              Aromaz showed us this also. On/Off by just touching the circuit.
              Turning it On externally is an increase or decrease of something pushing
              something over a limit which causes the light to glow.
              It might not be an On/Off happening.. it might be an increase
              in flow of energy happening. Kinda like the breaking of surface tension
              in a small tube of water with your finger on the edge to allow the water to flow.
              Could not the flow be made smaller or larger external from the circuit as
              well? You can tweak the circuit externally.
              At least that is what I think I could be seeing in the videos you guys
              are making.
              Tell me to be quiet if I'm annoying anyone
              Just
              Randy
              • Detector
                Interesting, Please try this someone?!
                Take needle nose pilers and burn a match totally and hang it from
                a string under a glass jar to detect if torsion waves are in the area.
                Source link
                Since Inquorate's circuit is compact it would be great
                for testing this detector.
                I have plenty of spider webs, but I don't know how well they
                will travel in snail mail.
                Thank you
                Randy
                • Inquorate schematic
                  In case anyone wants to duplicate, just hot glue transistors to coil (quite easy to remove, transistor type shouldn't make much difference so long as high rating..) and salt water cap easy to make. Or use baking soda, Alfoil, everything hot glued to piece of wood... Cap just sitting with foil on end of wire, I spread out thin wires for contact and glued only around outside edge. Electromagnet is .25 mm wire on ferrite coil.
                  Hopefully I'll have time for more testing tonight :-)
                  YouTube - Inquorate 17
                  • YouTube - Aromaz 025 - Lab notes with bamboo, capacitor and water.MP4
                    Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
                    • Hho
                      Originally posted by broli View Post
                      ..........Something as trivial as hho production would be obsolete then........
                      @Broli, there is still many legs of this energy to explore. It is a real mystery on how it works. I tried a series of experiments with water today, very small amount of that is presented att he end of video #025.
                      It was quite a remarkable observation I had when considering:
                      High Voltage, Pulsing effect, salty water, frequency around 3k Hz - well, usually that gives HHO.
                      However, I tried it with this effect and used three different sets of electrodes - Aluminum, Copper and 304 Stainless - NONE of them made HHO bubbles; not even a little after more than one hour.
                      It failed the HHO - but it makes me more curious as to why?
                        Hi Luc,
                        Nice job! Are you able to adjust the frequency super specific?
                        If you can do it at 357116hz then you will have a multiple a universal healing frequency.
                        Hi Aaron,
                        thanks for the positive comment
                        Yes I can adjust to a specific frequency. Yesterday I found some very interesting effects and I just finished uploading a new video to show this.
                        You want to see this. However I could feel that it was better to start a new topic. Please go here to get the newest video test 6: http://www.energeticforum.com/renewa...one-share.html
                        @everyone, you are all welcome to come
                        Luc
                        • Wood
                          Haven't seen Aromaz 025 yet, just quick thought... Tesla's magnifying transmitter, with semi-toroid top had wooden supports... Or is that all they did???
                          • Final video on Sparks ....
                            My final video has gone alive - this is more about sparks and the purple corona. Time to move on. Now I am targeting to undertand the phenomenon of wireless transmission and receiving better - plan still to use this same circuit.
                            Video #026 - Final Lab Note on Sparks, Coran and Water.
                            YouTube - Aromaz #026 - Final Lab Note on Sparks, Corona and Water
                            • The Nevada Lightning Laboratory have succesfully been able to wirelessly power 800 watts of light bulbs at a distance of 5 meters.
                              Lightning Lab - Wireless Power Study
                              Not quite there yet. RF is not really Aether now is it. With these big setups tesla probably could have broadcast the power to many miles far away. But good to see big facilities doing experiments.
                              • wood and water
                                ok,
                                in an attempt to post something constructive.
                                WOOD
                                as an instrument maker i want to point out that WOOD is very responsive to frequency.. so, looking at it that way, it seems obvious(or does it?) why your sparks/energy/frequency/resonance are going through wood.
                                a long time ago i saw a documentary on wood, and under a very powerful microscope, with a frequency added to the wood, certain particles of the wood align. now i'm talking "dead" wood here, cut and dried, not "living" wood.
                                hmmm, makes one wonder whats really dead or/and alive, but thats another subject i'm sure.
                                so, is the frequency carrying the energy? hmmm
                                WATER
                                yesterday i came across this guy, after watching loads of his vids, i think these four are very relevant to this thread. and maybe someone senior here should ask him aboard.
                                YouTube - dielectric constant of water and an oscillator on 3.5 MHz
                                YouTube - dielectric constant of distilled water/oscillator 3.5 MHz
                                YouTube - how to calculate and build a capacitor
                                and my personal favorite, because i love the coil and cap made from the same tiny piece of wire:
                                YouTube - searching for resonance
                                ok, hope this helps.
                                many thanks from
                                andy
                                stringguy, not because i understand string theory,(which i dont), but because i used to wind harp strings with a machine i built once, similar to winding long skinny coils. theres a thought
