Imhotep's Radiant Oscillator Video
  • #46
    Originally posted by elias View Post
    Hi,
    I managed to light the florescent light with my ignition coil, and the picture taken seems that the light is so much, but it is not even half as much it appears to be, anyway just an attempt for lighting with high voltage. I was pulsing the ignition coil primary with 4700Hz, 18V, 0.37A. It was lit totally cool.
    High voltage is really fun, but I wonder that in order to get better efficiencies we may be obliged to stick to one wire lighting or even no wire, with pure aether and less current, like Tesla did back 100 years ago.
    Lets see what Imhotep's circuit will provide! eager to see! More the Radiant higher the efficiency.
    Elias
    Thats really good low current and i was wondering when you were going to go ahead and do it. I dont know the frequency I am running mine at, its free running and right now im finalizing the part list so every can get the same parts, and it should be released in the next couple of days. Remember mine is only one method. This is gonna be everyones circuit to modify and do with what you like. I am sure with all the talent in the forum you will have it wireless drawing little to no current in no time :P
    The concept is Tesla's The idea of hitting a fluorescent is Peters and the unique way it was done was my idea which will become your idea.
    **~Imhotep~**
    Nikola Tesla
    http://www.imhotepslab.com
    • #47
      **~Imhotep~**
      Yes! Radiant Energy is wonderfully detected by neon and florescent lights and it is totally amazing, I think that I was lighting it with around 20 KV or so, But higher voltages should give us even more efficiencies. I used the simplest way one can imagine, pulsing the primary of my ignition coil with 18 volts, by using a 900v mosfet, and connecting the bulb to the output of the coil. I wonder about the efficiency if I cascade one more coil to step the voltage upto 1 million volts or so, what the effects would be?
      The florescent bulbs simply light wirelessly around a piece of metal attached to the output of the coil, Higher voltages may not even require direct connecting to the output. Basically no current is being used for lighting the bulbs I suppose.
      Elias
      http://blog.hexaheart.org
      • #48
        Too is detectable by capacitor and tester, capactor is get charget very fast with radiant energy.
        Steve Jobs. Apple CEO
        • #49
          Imhotep; I'm ready! I went out last evening and picked up a couple of 125 W CFL's, They didn't have 150's, Anyway I did the modification and it was just as you showed on your Utube Video. It was actually quite easy to do the mod. I found it easier to just desolder the Hot and nutral wires off of the cuircut board found inside. I also did an extra step before soldering the wires together and that was to take some emory cloth to the wires from the tubes. They appered to me to have a lot of corrosion or junk on the copper wires. This helped the solder to flow much easier. I taped the wires up and snapped the base back to the bulb. I was surprised as to how many parts are inside of these CFL's. Several diodes a couple of transistors and a nice size capacitor that is a 200V, 33 uf. several resistors but most are surface mounts and no use. So what are we going to do with these parts? I did notice that one of the diodes was a 1n4007! The next largest item in here outside of the capacitor is what looks to be wire wound transformer. I can't wait for the rest of the plan and to light these suckers up! I hope we are using our SSG's to power them. That would be totally COOL!
          Stephen
          • #50
            well you get 4 1n4007's which you can use for energy recovery . yes the circuit will be expanded. very soon the basic concept will be revealed . which is a little bit ev grey inspired and a little bit tesla . the caps also can be used some of them are very good poly 1500 v on some of the bulb circuits and some good electrolytics ,the 2 pin choke that looks like a thansformer can be used also.
            on the ge bulbs the caps are high grade and there is a current limiter that will be used later . how they can provide all these parts for so little money is too cool. the small toroid also can be rewound and used for later projects . keep watching this forum and Imhotep's Laboratory | Renewable Energy for weekly expansions on circuits.
            Nikola Tesla
            • #51
              i did not use ssg's to power them but the ssg can be used in Aarons water spark plug to charge the cap in a few seconds isolated .i have previous commitments and am being stretched thin so i have not been able to complete his experiment yet .also a power correction circuit will emerge for the cf bulbs to get the real power savings as revealed by Dr. Peter Lindemann
              Nikola Tesla
              • #52
                Hi thanks for your great work just finished my first every circuit thanks to your SSG bedini video
                I was wondering because i'm from the UK will the voltage difference of the bulb make any difference to this setup?
                • #53
                  i am not sure .we are going to the heart of the bulb so the step up from house current /voltage circuit should be different in each area not the tubes .that is a good question . i would imagine it will not matter.you will be throwing some serious hv at these tubes i am sure my circuit will light the tubes from anywhere but we will see tomorrow aug 1st . please inform us if it dosen't work with your tubes.
                  Nikola Tesla
                  • #54
                    ok i'll let ya know. Just finished step 1.. counting down the hours now
                    • #55
                      I think someone was up late last night! It is 8:00 am here on the East Coast USA, August 1st. Can't wait to see your post, Imhotep. This is going to be a great weekend project for me. Bulbs are ready to go.
                      Stephen
                      • #56
                        !!Yippee!!
                        It is August First
                        • #57
                          twiddling thumbs
                          • #58
                            This is Shiva
                            **~Imhotep~** is currently working on the video. As we speak the video is being compiled it should be uploaded later this afternoon early evening. Just a quick update
                            Nikola Tesla
                            • #59
                              As we are having daily blackouts here, the circuit is greatly appreciated...
                              • #60
                                Good News, Video is on its way! Yippie!!
                                Gees, I was begining to wonder if the MIB's had taken our Imhotep and Shiva away! I'm happy they did not! Anticipation!!!! is making me wait.
                                Elias, where are you on planet earth that you are having black outs? Spain? I heard in the news that Spain is cutting back on lights and electricity. You really need Imhotep's plans.
                                Stephen
                                Do the thing and you will get the energy to do the thing!
